      04-03-2015, 08:43 PM   #221
Taran.J
Taran.J's Avatar
Drives: BMW, LEX, MBZ, RAM, TESLA
Originally Posted by Kzang
I was thinking the same about the rear hatch spoiler ( not the M performance spoiler strip ) should have been wrapped to continue the flow ad keep the M performance spoiler black.
If you wrap the antenna would there be some negative affects to the reception?
Maybe something to consider.
I've thought of that. That's why I'm plasti dipping it to see if there is an issue.
If there is not I can take the time to properly wrap it. If not the dip will come off quick
      04-03-2015, 08:50 PM   #222
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
okay that makes sense! Good luck!
      04-05-2015, 01:33 PM   #223
Taran.J
Taran.J's Avatar
Just ordered some more 3M gloss black vinyl and knife less tape to finish up my roof or the trunk's deck lip portion.
Also iND Gloss Black rear trunk BMW badge so shoutout to them once again.
Waiting for R33 to come up north to help with the Painted Reflectors
      04-05-2015, 07:39 PM   #224
Taran.J
Taran.J's Avatar
Performance pedals installed. I like the look. Clean and simple.
      04-05-2015, 07:42 PM   #225
Taran.J
Taran.J's Avatar
My plasti dipped antenna
4 coats of matte black
2 coats of Glossifer
      04-05-2015, 07:45 PM   #226
Taran.J
Taran.J's Avatar
My front end view now with the roof wrapped.
Gives the perception of a lower vehicle
      04-05-2015, 09:04 PM   #227
I'm here in Portland already, lol. Soon.... Hahaha
PM for Everyday DEALS!!
      04-05-2015, 09:18 PM   #228
Kzang
Kzang's Avatar
3240
How is the reception on the antenna on your radio? No changes? Looks great!
      04-05-2015, 09:22 PM   #229
Taran.J
Taran.J's Avatar
Nope have not had an issue, was in downtown Seattle earlier and then I live a little out in the country and its fine
      04-05-2015, 10:30 PM   #230
ZuerstBMW
¡Viva España!
ZuerstBMW's Avatar
373
Drives: 2023 230i Mineral White
Looks GREAT!!!
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
      04-13-2015, 12:59 PM   #231
Taran.J
Taran.J's Avatar
F15 services required
-Driver door, lock switch cover is loose
-Knocking sound coming from under belly of car over rough roads/bumpy roads. Like a socket moving around down there.
-Open front windows and thudding and whistling occurs. Possibly due to side mirror housing design.
-Open Sunroof, or windows at speed and luggage cover start thudding in trunk.
UPDATE:
At my dealership now. The shop foreman has it on the rack for the noise below first and lock trim next.
As for the window and sunroof noises they told me more X5 owners need to report the same issues I am having to BMW through their service advisors as they did for me in front of me.
Once my main issues are sorted we will be driving two M sport ones they have on the lot to test the similar wind noise issues and they will contact BMW from there accordingly.
As we were speaking we find the mirror housings to be at fault and the magnet for the luggage cover to not be strong enough at 40+ mph full open element driving.
      04-13-2015, 02:05 PM   #232
puckybadger
Drives: 2024 X6 M60i LCI TBII/Tartufo
the whistle noise w/drivers window open is really annoying. dealer says too bad. was thinking of jamming a tennis ball between the mirror and window frame.
      04-13-2015, 02:35 PM   #233
Taran.J
Taran.J's Avatar
So dealer removed the free roaming socket from my undertray.
Ordered the lock switch plastic cover and agreed they most likely broke it removing the door stuff to install my broken window.
As for the windows the other X5's on the lot had the same issues so the Shop Foreman said it didn't make sense to replace the side mirror housings to my X5.
So they have submitted an official F15 complaint to BMW North America on my behalf and my SA did say I should put the word out because he has had a few others say the same thing but they know me personally and took my complaint seriously.
      04-17-2015, 03:41 PM   #234
Taran.J
Taran.J's Avatar
Thank you iND for another quality part for my X5.
-OEM Rear emblem
--Painted in Gloss Black
      04-18-2015, 12:12 AM   #235
Taran.J
Taran.J's Avatar
Installed. Took about two minutes, new 3M tape came off in one piece. Looks wayyyy better since the only thing silver on my X5 is my exhaust tips.
      04-18-2015, 07:20 PM   #236
clemsonee
clemsonee's Avatar
Drives: 2015 BMW X35d
Very cool! Adds nicely to the shadow line (gloss black) trim on our M-Sports. What was the cost from r33? Would consider getting one myself.
      04-18-2015, 07:59 PM   #237
Taran.J
Taran.J's Avatar
This was sent to me by iND, I would check their website or do you mean something else from r33? He didn't send me the rear emblem.
      04-18-2015, 11:18 PM   #238
I tried making that rear emblem in black. But, it didn't came out right.
      04-19-2015, 05:49 AM   #239
Kzang
Kzang's Avatar
3240
If I am understanding you correctly, you drive around with the trunk private/security cover opened causing it to make noises on rough roads? I always have this covered closed because it would make noises on my previous X5 as well. I haven't driven with the cover open yet in my new X5.
      04-19-2015, 07:27 AM   #240
Taran.J
Taran.J's Avatar
Yes it is in its stationary position. I have yet to use it
      04-19-2015, 07:41 AM   #241
Kzang
Kzang's Avatar
3240
I always keep it closed and have no issues with noises.
      04-19-2015, 08:22 AM   #242
Taran.J
Taran.J's Avatar
I'll give it a try at highway speeds. I like fresh air so that's why I'm pursuing the issue.
Honestly I wish BMW made under trunk storage for the luggage cover so if it wasn't needed like for myself I can always have it in the BMW if needed but tucked away for daily purposes for optimal trunk space.
