01-10-2015, 03:42 AM | #45 | |
Rep 160
Just found the following on German tuber Hartge's webpage E70 8speed 245HP -> Tune brings to 290HP/640NM (more or less as default setting with RC). 0-200km/h down from 51.4 sec to 35.3 sec F15 30D 8 speed 258HP -> Tune brings to 302HP/655NM 80-200km/h (not same as with the E70) down from 32.2 sec to 27.4sec Btw, they rate the std X6 40D (306HP/600NM 8 speed) to 35.4 sec 0-200km/h - same as the tuned E70 30D, so my feeling when racing against my buddy's X6 was right |
01-10-2015, 03:47 AM | #46 |
Rep 17
Thanks for posting your results..i am confused with your settings,
1) E/2 means s1 : E and s2 : 2? 2) what did not allow you to increase the setting?, CEL, detonation, etc..? Regards.. |
01-10-2015, 05:24 AM | #47 |
Rep 3,990
This isn't relevant for your 35i. You will start with S1=1 (do not change this for petrol engines) and S2=B (this is the value you change - mine is currently at C and it's a huge improvement). They have diesel engine so their S1=0 and their S2=E as stock, so the only thing they change is S1 from 0 to 2.
01-10-2015, 07:39 AM | #48 | |
Rep 17
01-10-2015, 07:42 AM | #49 |
Rep 3,990
Ah ok, good deal . Well, the info is there now regardless, lol. Best of luck.
01-10-2015, 12:45 PM | #50 | |
Rep 155
E/2 means: S2=E S1=2 The reason I didn't bother testing higher/lower settings or different combinations is for the following reasons: - I did not want to throw a CEL as many do beyond E/2 setting - more runs will be more $$$ outta my pocket - my intention as 42pilot accurately stated was to determine if the racechip performs as advertised
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
5
01-10-2015, 12:56 PM | #51 |
Rep 155
To keep things short and simple, here are the reason why we did not dyno the car in 6th gear(1:1) and only to the rear wheels. Also some might have noticed why the dyno curves starts at around 2,200 rpms:
- Though we turned off DSC the car kept turning it back on and diverting all power to the rear wheels - When trying to run in 6th(even with the level held back to keep it in 6th constantly) the transmission would bog down and also turn traction control on for all 4 wheels. - When full throttling anywhere below 2,200 rpms on the dyno would also turn traction control back on for all 4 wheels. The only thing that worked was starting the runs at 2,200 rpms in 4th and the car only allowed the rear wheels to spin. Even then, it took us several tries to get clean runs. Again, I will analyze the numbers for the other two settings and post the results. I will also consolidate all this information to my original post.
01-10-2015, 01:27 PM | #52 | |
Rep 3,990
01-10-2015, 02:53 PM | #53 |
Rep 4,102
I have been in E/3 for the last two days. Feels really good and strong and no cel yet.
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
01-10-2015, 03:02 PM | #54 |
Rep 3,990
For those of you changing your settings, it would be helpful to others if you explained the changes in detail from throttle response in each mode (EcoPro, Comfort, Sport) from complete stop and also rolling speeds, RPMs leveling off or not (is power consistently increasing), and your mpg changes, etc. These are the things people can actually note and understand. Of course, driving the vehicle is the best way to know, but for contemplating going up or not, this knowledge is much more useful.
01-10-2015, 07:19 PM | #55 | |
Rep 710
01-11-2015, 10:18 AM | #56 | ||
Rep 512
01-11-2015, 10:03 PM | #57 | |
Rep 710
But seriously, you shouldn't feel a thing or something is wrong. Why would you think breaking in would result in better power? What do you think is going on inside your engine? At the same time, I used to unplug all the power to my Powerstroke Ford diesel engine overnight which discharged the ECU. This would get the ECU to learn my type of driving all over again which would affect things like throttle response, but not more power. Nothing physically happens to our cars after break in to provide a noticeable increase in performance.
01-11-2015, 10:50 PM | #58 | |
Rep 265
01-12-2015, 02:29 AM | #59 | |
Rep 160
I have been driving diesel cars since 2004 - and all from new. Brands have been Toyota (4) and since 2011 BMW (X3 F25 20D and X5 E7 30D). I have actually on all felt the engine 'opening up' when cars passed around 10.000km. This on both the Toyotas and the BMW's. It feels like the car gains more HP - but not in the 20% level, but enough so you can feel it. I have been told that modern diesels are somehow coded to deliver less power until the engine has done some thousands (up to 10K) km, but not sure if it is a story or not. |
01-12-2015, 07:21 PM | #60 | |
Rep 710
Why would a manufacturer possibly do that? In today's world of high horsepower car/SUV wars, what could possibly be the motivation to start low and add HP in 10k miles/km's? Mechanically speaking, nothing changes at 10k. Within 1k miles, the bearings and rings are settled, but that might give you 5 hp from reduced friction - maximum. As for software, I assure you there is nothing that happens at some point in the future to give more HP. You could get your ECU flashed and a new/better tune could be installed, and that would make a difference. Modern diesels are tuned to the max from day one. I have a 6.0L power stroke putting out close to 400hp and 750 lb ft of torque. That's huge and known to be tuned near 100% of it's potential from the factory. That's why so many fail - too many people push them over the limit with tunes and/or overheating. New 6.7L Powerstrokes are producing over 450 hp and over 850 lb ft of torque. In a pick up truck! On the other hand, the US BMW diesel is de-tuned for our EPA emission laws and poor fuel quality. That's why I chipped it.
01-13-2015, 02:21 AM | #61 | |
Rep 160
? Sorry, but can not read my comment as 'an attack to your reply' I was simply telling about my own experience - and this is an experience you will find from many diesel drivers in Europe. I was also saying it was not in the +20% range, but it was/is enough so you can feel it. At the same km mark, most people (my self included) also see an improvement in fuel consumption with up to 15-20% extra (how to explain this?). And finally which was notable on all the 4 bangers (not the 30D), the engine sounded more smooth and less noisy - we all know the BMW 4 cyl make more 'hard' diesel noise compared to the Audi etc. Why is it like this? I don't know - but I have heard several people (among others engineers working at Land Rover and Peugeot) claiming that this is what is happening. But as said, I do not know if this is a story or not - but I do know my own experience. About modern diesels already tuned to the max. I am sorry, but not sure you are aware of what is going on in the car industry at the moment including BMW. Many of the engines today are identical but with different software ending in different power. Take for example the 4 cyl BMW: Same engine whether they mark is as 1.6 - 1.8 - 2.0 (two versions) and 2.5 (forget about the US noise with 2.8). All is the SAME 2.0 engine with different software (and the 2.5 with different turbo and cooling). And I bet you - we have not seen the last, using same 2.0 but with even higher output. Take the new VW Passat, their current top of the range is a 2.0 diesel with 240HP (last version had 170). Skoda use same engine in their new Superb (not launched yet) - same engine have 280HP. I will also bet, that the BMW 50D (3 liter) with currently 381HP will be presented with even higher power from the factory in the future. All car manufactures are now following this down-sizing trend - smaller engines but with higher (and higher output) So, modern diesels today are NOT at their max. |
01-13-2015, 07:11 AM | #62 |
Rep 16
01-13-2015, 05:49 PM | #63 | ||
Rep 512
01-13-2015, 08:22 PM | #64 | |
Rep 710
I'm quite aware of the various engine configurations, called platform manufacturing. My biggest customer uses this method to build agricultural equipment. But such differences in performance are not normally just software related. They almost always hang an extra turbo or two, larger injectors, different valve train , etc., then match the tune. The base engine is basically the same. In any event, we'll agree it makes no sense (or is odd at the very least) why engines magically gain significant horsepower after breaking in. In the meantime, if you get any empirical proof, I would appreciate if you could share.
