03-18-2015, 02:48 AM | #1 |
Rep 156
Pirelli Scorpion Zero Assimetrico vs Vredestin Ultrac Sessanta
Which tire is better suit for hot climate?
No rubber cracking issues etc.. Pirelli Scorpion Zero Assimetrico 305/35 R22 110W Vs Vredestein Ultrac Sessanta 305/35 R22 110Y Any help will be appreciated |
03-18-2015, 02:14 PM | #3 |
Rep 156
Hi, yes I'm sure this is the size I'm looking for.
Since my other car's front tire is 265/40 R22 So, I need a 305/35 R22 to have the same side wall height for the staggered set up. So which tire is better suited for hot climate? Vredestein or Pirelli? Pls help me decide |
03-18-2015, 02:44 PM | #4 |
Rep 18,726
@bmwstve, what you may want to achieve is the same overall rolling diameter, not the sidewall thickness.
Unless if you don't mind the computer and traction control goes crazy on you.
03-18-2015, 11:28 PM | #5 | |
Rep 156
What tire size should I go with? Because I only plan to change the rear tires. My front tires is 265/40/22 What should the rear tires be for a 10.5 inch rear rim? Hope to hear from you soon. |
03-18-2015, 11:51 PM | #6 | |
Rep 156
They seem to have the same Overall rolling diameter only 0.2% difference. Will this mess up the computer and traction control? |
03-20-2015, 06:46 PM | #7 |
Rep 18,726
bmwstve , sorry, forgot to reply on your post.
Your overall diameter is off by 1.5"+. You want to maintain OEM overall diameter, which is 28.7" to avoid any rubbing or sensory problem. I believe opasha is running 285/35/22, which has 29.85" overall diameter. His setup still didn't trigger any sensory issues, but he has some rubbing on a full turn.
03-20-2015, 08:52 PM | #8 | |
Rep 3,990
