10-01-2015, 10:45 AM | #1 |
Rep 4,309
X5M (F85) & X6M (F86) Personal Tuner Solution | Velosdesignwerks
Featured on BIMMERPOST.com Our Personal Tuner solution for the F85 X5M & F86 X6M platform. This particular solution is completely plug and play and ready to go out of the box. Install is also straight forward and our team is available for technical support. Installed it on our X5M that first week we received it a few months ago as well as a few others to gather more data. The F85 X5M & F86 X6m boast an amazing maximum output of 575HP at roughly 6200 rpm which is a 4% increase over the previous model. Peak torque is increased by roughly 10% giving this version roughly 70 lb ft of torque over the previous model. While BMW has done an amazing job with the vehicle and not to mention the new 8 speed transmission there was still some power left on the table and our engineering team has spent countless amount of hours in R&D to provide a reliable tune while keeping all safety parameters in tact. The Velos Personal Tuner will boost your X5M & X6M performance by an impressive 97hp and over 108lb ft of torque. We have done testing in both favorable and unfavorable conditions and bring you the results from the unfavorable conditions exceeding temperatures of 105 degrees Fahrenheit. The Velos Personal Tuner requires no cutting and the simple install can be done in under an hour. Benefits include improved power throughout the entire rpm band, sportier throttle response, smooth power delivery, as well as a slight improvement in MPG. With our preset calibrations the power delivery from 3200 rpm is smooth so traction is still possible with a gradual increase that will unleash your M’s true potential to the 7500 redline, providing you with useful power in an RPM range where the vehicle will spend the majority of its time. Optimized for vehicles using gasoline with an average octane rating of 90-93 peak gains are realized at 5400 rpm. The Velos Personal Tuner for the F80, F82, and F83 platform is engineered with a multi channel controller that uses RPM based integration which enables our team to provide a refined power curve much higher than that of the factory. With an M our engineers felt it was necessary to maintain the factory like characteristics even when increasing the vehicles HP&TQ output over 15%. All of this is accomplished well within factory safety parameters making this upgrade a must for the enthusiasts looking to maximize their M’s performance without any compromise.
PM FOR BEST PRICING http://velosdesignwerks.com/product/...software-2015/ Last edited by carlos@velosdesignwerks; 06-10-2016 at 03:44 PM.. |
10-01-2015, 02:56 PM | #2 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Nice! So is this a breakthrough and a gateway for hand held flashers for the F platform vehicles. Until not it was piggy backs or flash.
FBO-PS1 and stuff
10-01-2015, 03:29 PM | #3 |
Rep 4,128
Drives: M235i & G30 540i
Wow its fast as stock can only imagine what 100HP more would be like.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
10-01-2015, 04:18 PM | #4 | |
Rep 6,653
Unless I'm really reading their website wrong, this is a piggyback. |
10-01-2015, 05:00 PM | #5 |
Rep 3,834
Piggyback, similar to RaceChip. Very nice gains here.
10-01-2015, 09:37 PM | #7 |
Rep 3,200
10-01-2015, 09:49 PM | #8 | ||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
10-05-2015, 08:06 AM | #11 |
Rep 562
Drives: 2011 1M VO
Power to 7500rpm? I don't think so...Out of breath (and redline I think) well before 7000.
10-05-2015, 11:24 AM | #12 |
Rep 2,036
Remember the power delivery needs to be follow the factory curve to not overwork the turbos. So while the boost does taper off towards redline the throttles also begin to close around this time before the vehicle is ready to shift. So yes there is an increase all the way to redline but the boost has to taper off at some point before the shift.
11-01-2015, 04:58 PM | #17 |
Rep 41
what is the difference between your piggyback, than jb4 / dinan / racechip / manhart?
than you for your answer. iam very interresting to buy it, but i don't know wich.. |
11-03-2015, 10:40 PM | #18 |
Rep 114
+1! I would also appreciate Velos to comment on their piggyback programming vs others....
11-04-2015, 11:40 AM | #19 |
Rep 41
...i am very surprised about the price og piggy back..500$ for a jb4, to 1999€ velos , 2999$ dinan, 5000$ manhart, ac schnitzer......11 500$..
what is the difference...? is better to have the middle range like dinan or velos, or is better manhart... |
11-11-2015, 10:51 AM | #20 | |||
Rep 2,036
There are different products on the market for these vehicles in the form of "piggy backs" or "Tuning modules". I do not use the term piggy back because over the years a piggy back is typically resistor based and adjust the way the vehicle thinks it is working to get the results we want. i.e. X5 thinks it is at X - 4 psi to force the ECU to get an increase of 4 psi. I do not want to speak on any of the other brands but I do have experience with Manhart and Dinan and I believe they work similar but I think they are best to respond. Our unit is a communication device of sorts using OE connectors. The programming is specific to vehicle and can be altered depending on modifications (slightly). The Unit is sealed with a tamper proof label and is programmed and shipped within 48hours of receiving an order. The strong point is that it has RPM integration so we have control throughout the rpm band to deliver factory like power at a much higher level opposed to a spike in the beginning and then the vehicle falling on its face. As with the E70 X5M our goal is to use our vehicle as well as other we work with to create gains where the majority of the time is spent driving. We used testing from our E70 X5M and our new X5M to create boost curves / power curves that will not necessarily throw you back in your seat at 2500 (the vehicle does that on its own) but rather give you a strong "freight train like" pull throughout the rpm band. Best Regards, |
11-15-2015, 07:56 PM | #21 |
Rep 3,998
This is so true, I don't drive a X model but an F82 and have been running the Velos tuner for almost a year now and it always puts a smile on my face when I drive my M4, very smooth like factory power delivery throughout the entire power band. These guys got the formula right!
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
11-15-2015, 10:07 PM | #22 |
IG @bmwF9xG80
3812
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Sounds/Looks like a great product!
Very identical to RaceChip, is it using the same module ? Nothing wrong if so, since RC is very known (established in Europe) and respected. Can you post more pics of the module? Thanks
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
Tags |
bmw, software update, tune, x5m, x6m |
