      04-07-2016, 10:54 PM   #1
Jokerk
Drives: x7
X5 35i dash cam installation help!
Try to put a dash cam in the car, and hardwire in the fuse box on the passenger side, so it can be parking mode. But don't know which fuse wire on, any recommend fuse to use?
      04-07-2016, 11:15 PM   #2
Find my DIY. I think it is there.
PM for Everyday DEALS!!
      08-12-2016, 10:21 AM   #3
SMC23
Drives: Subaru XTrek / X5 40e
Is your DYI stickied anywhere?
      08-12-2016, 10:59 AM   #4
MarkG_M5Comp
Supreme Being
MarkG_M5Comp's Avatar
United Kingdom
1804
Drives: M5 Comp
http://f15.bimmerpost.com/forums/sho...hlight=Dashcam
I'm off to have a read now as I had the Thinkware in my F30 and need to plan for reinstall in the F15 in a few weeks.
PDF file:
http://f15.bimmerpost.com/forums/att...2&d=1418781422
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring
SMC23180.00
      08-12-2016, 12:49 PM   #5
quad_drive2
Drives: 2014 BMW X5 35i M-Sport
Exactly what I am looking for. Thanks.
      08-12-2016, 02:31 PM   #6
SMC23
PDF file:
Thx! I'll be doing the same, moving my Thinkware F750 from the F30 to the 40e.
      08-12-2016, 06:45 PM   #7
MarkG_M5Comp
Supreme Being
United Kingdom
1804
Drives: M5 Comp
PDF file:
http://f15.bimmerpost.com/forums/att...p;d=1418781422
Have you seen the new 770 model? Nice and slim, uses the same rear camera. Tempted to treat myself to one...
      08-14-2016, 02:45 PM   #8
wifesbimmer
Drives: '20 X5 M50i, E92 M3, '16 F150
Simple! The fuse you should always use for hardwiring dashcams is the hazard light fuse in order for your dashcam to work while parked.
      04-05-2017, 08:21 AM   #9
skim7x
skim7x's Avatar
Drives: 335i, C63 AMG
2007 335i  [10.00]
First of all, thanks to r33_RGSport for the DIY. Threading the wire for the rear view camera was a PITA.
But I got it all wired up now. Problem is that the DIY's that I'm finding online all connect to the full size ATO fuses, but per blackboxmycar, I was provided with a mini-fuse fuse tap (their Add-A-Tap wire). I tried using the 150 fuse as it was trunk related, but it appears that's a constant power fuse, not an ACC fuse.
Does anyone know which mini-fuse would work that is ACC (only on while ignition is on, but turns off when car is off)?
Thanks!
      04-05-2017, 03:39 PM   #10
Neuera09
Drives: 2016 X5 Xline with MPPK
Just did mine several months back. I'll check my rear fuse panel setup when I get home in 4 hours.
UPDATE:
I tapped into fuse slot 143 using a mini fuse tap. Good luck.
