05-08-2017, 12:00 AM | #1 |
Rep 8,808
||| Alan's Mineral White X5M - BBS SV \ RKP \ DINAN \ IND |||
Featured on BIMMERPOST.com Shout out to some of the vendors here that helped with this build. Nothing but great experiences with these guys Entire IND Crew Hendrik at Baan Velgen George Javier over at Rallye BMW Ben@RGsport Nick at www.nicksblastingandpolishing.com Evan at www.getbmwparts.com 2016 Mineral White / Mugello Red X5M 22" BBS SV in Custom Brush Aluminum Finish 295/30/22 and 335/25/22 Continental Sport Contact 6 Summer Tires H&R 13mm Rear Spacers RKP Carbon Front Lip RKP Carbon Mirror Caps RKP Carbon Rear Diffuser RKP Carbon Bumper Inserts RW Carbon Side Skirt Extension IND Black Out Badges / Roundel Package BMW M Performance Roof Spoiler BMW M Pedals Racechip Ultimate Dinan Carbon Intake Eisenmann Race Exhaust w. 102mm Black Chrome Tips
17
Violator4587.50 ddm4471.00 ckren550.00 secondlook46.00 m5 guy1691.50 AlexGT419.50 r33_RGSport12966.00 Samurai of 2day2115.00 Mr.blue223.00 FSociety3812.50 Aust350z243.00 VPGNS117.00 ORIGIN M.3159.50 Deep Powder54.50 Installsplus458.50 IND-Distribution9585.50 jeff@autocouture965.50 |
05-08-2017, 06:44 AM | #2 |
Rep 4,532
Very nice.
Badboy881346.00 |
05-08-2017, 07:36 AM | #3 |
Rep 2,775
Drives: F95 X5MC
Nice photos!
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
05-08-2017, 12:17 PM | #9 | |
Rep 8,808
I only have this iphone pic i took recently.
05-08-2017, 12:22 PM | #10 | |
Rep 8,808
Thank you
Thanks! Thank you for always giving me exceptional service and prices for the past decade. Thank you. Thanks Bart. Can't wait to see what you do to yours. Based on all of your other cars it will be sick. Quote:
Alan
05-08-2017, 02:03 PM | #12 |
Rep 18,713
Looking good as always.
05-09-2017, 02:22 AM | #14 |
96
Rep 374
Love the wheels!!! And overall complete package!
I would redo the rear red stripes though, it doesn't seem line up perfectly
992 Turbo S
X7 M60 |
05-09-2017, 10:01 AM | #16 |
Rep 944
Alan nice job on the project. Are you running only rear spacers?
Trying to figure out spacer sizing and heard several times that only a 5 and 15 fit the front and 5, 15 or 20 in the rear. No sizes in between. See that is not the case with you which gives me some hope Did you try a bunch of different sizes and just figured out what worked? Guess it's something with the hub shoulder. Don't understand it A 15 is perfect in the rear but need something in between a 5 and 15 in the front |
05-09-2017, 10:26 AM | #17 | |
Rep 8,808
Not sure if any of the spacer companies changed their design for the current generation X5's but I was one of the first people that found out that we can not use spacers with a lip up front on this platform. BMW made the hub lip up front taller preventing spacers designed for the last generation X5 not sit flat on the rotor making it dangerous to use. Flat spacers without a lip is fine as long as its not too thick preventing your wheel from centering/touching the hub causing vibrations. This is why typically you can only use a 5mm spacers up front. I've tried even a 15mm up front and it still won't clear the hub. Its possible that bigger spacer would fit but then your front wheels would be sticking out way too much. I ran a 5mm up front but honestly it was barely noticable and it caused my wheels to shake slightly on the highway. I even got my wheels road force balanced with the same result. Once I removed the spacers the vibration went away. Not worth the trouble to me. For the rears I went with the 13mm for two reasons. 1) because RAD makes extended wheel locks that can accommodate up to a 13mm spacer and 2) because 20MM was too much. I ran a 20mm spacer with my BBS wheels before and it was sticking out just too much for my liking. Keep in mind every wheel will be different depending on the width of the wheels and the offset so what works for me might not be perfect for you. Hope that helps. Alan
05-09-2017, 10:34 AM | #18 | |
Rep 8,808
Thanks all
Alan
