08-14-2017, 05:01 PM | #23 |
Rep 39
I think the B&O system is getting a lot more abuse than it deserves. The source input matters a great deal. It's significantly better with a high quality source, and setup with the proper distribution. I find that the default studio/surround settings just aren't quite right. They're decent but you need to really dial in the settings and it can sound pretty fantastic.
Definitely the best production car audio system I've ever owned. I think the B&O in the F10 M5 sounds better, but I think this really boils down to the harmonics of the vehicle itself. The sound distribution and acoustics caused by the design of the interior has a much better feel in the M5 than the X5M. Both are great, but do require tuning. Once tuned with a high quality source, it's pretty fantastic for a production car system. |
08-14-2017, 10:08 PM | #24 | |
Rep 600
So here is my dumb question? Where are these 16 speakers? I count 8 on all the doors and 2 on the dash. Where are the other 6? Mines a week old so I am still learning. |
1230vani650.00 |
08-15-2017, 06:46 AM | #25 | |
///M
133
Rep 184
Drives: M8C/Taycan Turbo/Roadster 2.0
4 = 1 mid on each door 2 = 1 tweeter in each "D" pillar (in trunk) 2 = 1 mid in each "D" pillar (in trunk) 2 = 1 Subwoofer (8") under each front seat 1 = 1 tweeter pop up on dash 1 = 1 mid pop up on dash |
08-15-2017, 07:44 AM | #26 | |||
///M
133
Rep 184
I had B&O in a B8.5 Audi S4 and it had the same problem no bass. I also currently have B&O in an Audi Q5 and the bass is acceptable but not great. Just like iconoclast said it's clear at all levels but lacks bass. The speakers are decent (way better than BOSE) and the amps are really quality. B&O has designed a system that will play loud and clear. I find this to be true to B&O no matter what car it is installed nor how much the upgrade cost ($800 in S4, $500 in Q5, $3700 in F85 ) In the S4 I replaced the 8ohm joke of a 10" sub (really a 8" sub in a 10" footprint) with a $100 Kicker 4ohm sub. The weight and magnet of the Kicker was triple what came out. The reduction in resistance to 4ohm increased the power output of the B&O amp and it handled this massive 10" woofer no problem. The bass went from almost nothing to incredible. Best $100 upgrade I ever did to a car. The amp handled it all day long never missed a beat, never overheated or did anything funny in the 2 years I had the setup. So when I got my F85 I found I had the same issue with B&O...lack of bass overall but especially at low volume. No matter what you do with the bass setting and EQ there isn't anything at normal listening levels. The B&O subs can make some bass with the right music and with the system CRANKED but then everything else is so loud it is TOO loud and still out of balance. Plus with the bass dial maxed it gets too boomy and sounds funny. I wanted to have some bass while being able to play the system at normal levels with my family in the car and be able to have a conversation as well. Quote:
When I came across the BAVSound Ghost sub and I thought wow this is great ez mode drop in replacement and someone else already solved the problem. I also noticed how low profile the subs were and figured BAV was the only choice due to the odd sub shape/style and factory wiring connector. But I did not like the specs (or lack of) I did not like that they were 8ohm and I certainly did not like the price. It also didn't look like that much of an improvement in terms of air moved/woofer travel. So I decided to investigate on my own. I removed the passenger seat bolts and leaned it back against the rear seats so I didn't have to disconnect anything. Removed the grill, then the cage and got down to the sub and it's mount. Pulled that out and removed the connector and realized there was no way I was dropping a "normal" 8" sub in this spot. But it did confirm that the stock sub is a joke and has barely any woofer travel so it's just not going to move a lot of air. I was surprised at how heavy it was, but once you get it out you realize it's just using a huge cheap magnet and the cage that holds it in is designed around just that. But at least I had an idea of what I was working with and the sub design is VERY cool how the body of the car acts as an enclosure and they have a ported "tube" that runs along the side of the car (under the carpet by the doors). So I started searching and came across this one company in CA called Earthquake Sound that has a drop in subwoofers for BMWs and has all these patents on their design and uses neodymium magnets so it doesn't have to be so huge and heavy but still can handle power. 300w power handling 4ohm and 1.5" woofer travel had me at hello, but most importantly it was drop in fitment for this location. Amazon has everything you need: Earthquake Sound X84SWS 8-inch Shallow Woofer System Under-the-Seat Subwoofers 4-Ohm (Pair) $230 https://www.amazon.com/gp/product/B06X41HPJJ/ and Earthquake Sound R8SWS Installation Ring Adapter for Speakers (Pair) $25: https://www.amazon.com/Earthquake-So...dp/B00G2MKGOU/ So for about $250 you have everything you need. Half the cost of BAVSound and more importantly half the ohms! (4 instead of 8) Now you can actually double your bass Here are the trade offs: You have to do a tiny bit more work than the BAV upgrade because you have to cut off the OEM subwoofer connector to use the bare wiring. Not a big deal and I think most of us would just leave these in the car and not bother to swap back to stock parts (but you could get the factory subs to work with the bare wiring if you needed/wanted to) The other trade off is you can't put the factory cage back over the sub (the 1.5" range of travel would have the SWS-8X aluminum cone cap/heat sink hitting it) and without the cage you cannot put the grill back on top. This is better for sound because there is less plastic obstructing it (trust me there is a lot when you see the cage) but it's bad because dirt/crumbs/toys etc could make their way into the sub from the rear footwell area and damage it or cause it to make noise as it vibrates. Good all weather mats with a lip and/or some vacuuming should be all you need. The front seat footwell/floor mat area is lower than the sub so this isn't a concern from the front. The only other thing I did besides the 2 subs and the ring adapters was to add some sound insulation to the metal "floor" of the car in the area that the sub sits in. I was careful NOT to put this on the rolled area that leads into the port as I didn't want to mess with the port tuning or air flow. Dynamat works but it's too expensive (IMHO) so I use GTMAT and find it to be the same thing at a great price. This kit for $15 will do several cars and you only need a tiny bit for the X5M: https://www.amazon.com/gp/product/B008KNL1BG/ So in the end you'll end up with 2 crappy B&O subs, 2 huge plastic cages and 2 top speaker grills left over (save or toss your call) in exchange for a huge improvement in bass you can feel! I was VERY pleased when I fired up my tunes and had KILLER bass at loud levels and great bass at lower levels. It is the kind you feel in your gut/butt and with the windows closed you can feel the pressure. I was also pleased with how easy a DIY it was and the improvement in bass vs how little I spent on parts. Sad B&O can't get that right and that BMW charges $3700. I am sure people would be more pleased if they increased the cost to $4000 and just used these subs instead! I hope others who are looking to improve the B&O system give this upgrade a shot before trying to swap amps or fill up the trunk with huge sub enclosures. Unless you need a car show style stereo this is really all you need for a great system with no compromises and low effort and cost. Last edited by Jenner; 08-15-2017 at 02:40 PM.. |
5
08-15-2017, 07:48 AM | #27 | |
Rep 190
Drives: 2020
Thanks |
08-15-2017, 08:04 AM | #28 | |
Rep 242
Edwin
2017 CB X5m
08-16-2017, 08:23 PM | #29 |
Self-Deprecating Narcissist
7266
Rep 6,561
Hahahah... that is the best joke I've heard regarding automobiles and the most accurate... The B&O audio system is just about clarity (IMO)... it offers the best sound at ANY volume (when dialed in properly)...
11-10-2017, 03:11 PM | #30 |
Rep 62
I appriciate that I found this thread, I am looking into getting an X5 and was thinking finding one with B&O, but after reading this I will save the cash. I am big into EDM, Hip-Hop & Rap, so bass is VERY important.
(I also am posting this to subscribe to this post) -R |
11-10-2017, 10:28 PM | #31 | |
///M
133
Rep 184
The MSRP for the option is too high, but it's a great system and event better when you didn't pay the MSRP and enhanced it with a 4ohm sub upgrade |
11-11-2017, 06:16 AM | #32 | |
Rep 637
Couple better subs in a system that's already incredibly clear and accurate in sound reproduction and you'll be happy you spent the money. |
11-12-2017, 07:39 PM | #33 | ||
Rep 16
SaNGRia984.50 |
11-13-2017, 07:37 AM | #34 |
Rep 637
I am interested though in the quality of the Earthquakes. Mostly related to type of cone material, responsiveness (ie speed), accuracy, etc. Since the B&O system is all about accurate sound reproduction and clarity, I think it would be fairly important for any replacement woofer to be in the same league.
I had a 10" Diamond Audio HEX in a previous vehicle and it was incredibly accurate/responsive. The unfortunate thing is that there aren't many shallow mount 8" woofer that fit our OEM enclosures... |
11-13-2017, 09:46 AM | #35 |
Rep 62
I'm always nervous about replacing OEM parts. Not because of the reliability. I'm just not knowledgeable when it comes to replacing anything lol. Thanks, I will keep it in mind!
11-30-2018, 01:57 PM | #36 | |
Rep 31
This is very strange .. I did exactly with the Earthquake brand . I replaced passenger side first and had to wait to install the driver side. I was impressed with the first swap. I replaced the driver side and it sounds like shit?! Is there a different setting or fine tuning I need to do ? Last edited by Johngm45; 12-03-2018 at 11:40 PM.. Reason: Anybody?? Do i need to adjust settings? |
11-30-2018, 03:09 PM | #37 |
Rep 1,456
The HK system in my f80 M3 sucked. The HK in the X5M is way better. I was going with BO for the X5M until my salesman told me to listen to the HK in the X5M. I was amazed at the difference. I have purchased at least 7 BMW's from this salesman so he might not have been looking for a quick buck off me.
12-01-2018, 08:44 AM | #38 |
7266
Rep 6,561
The H/K L7 system I had in my RRSC was amazing... especially with the RSE movie playing through it.
12-15-2018, 10:13 PM | #41 |
Rep 84
Compared to the Harmon Kardon in my 50i, my X5M B&O is WAY better.
All around more crisp and balanced sound. The bass I agree isn't the loudest of any premium system I've heard but it is a great sound system and much more clear in my opinion. However I would like more bass (if you mess around with the custom Tone settings, you can get more of a punch from the midtones and bass), if any BMW sound engineers are reading! lol I need to check out the Burmester? That's the upgraded Mercedes option? |
12-18-2018, 02:15 PM | #42 |
Rep 512
Not a huge fan of mine honestly. The Mark Levinson in my GSF was worlds better. Its not terrible but not as good as it should be for what it cost. The systems in Audi and Lexus are much better.
12-18-2018, 02:16 PM | #43 |
Rep 512
i did this on my M3 and the HK system sounded better for sure. How do you do it on the X5M? The M3 i just unplugged it under the trunk liner.
12-18-2018, 05:33 PM | #44 |
Rep 239
I've deactivated the ActiveSound and it definitely improved the B&O in my 2018. Honestly I prefer the stock non-upgraded speakers in my 2009 5 series. Admittedly I doubt I have what would be considered a refined musical palate. I think it does largely have to do with the bass.
