10-22-2021, 01:05 PM | #155 |
Rep 1,066
Drives: 2015 X5 50i M Sport
0.028"
2019 Cayenne Turbo
10-25-2021, 08:09 AM | #156 | |||||
Rep 7,165
2) gap now or uninstall all of them and gap when you decide to tune.
12-03-2021, 12:10 AM | #157 |
Rep 112
Thank you to OP for posting the change procedure, it was very helpful to understand what’s required to complete the job.
My spark plugs have done about 40,000 kms and some look terrible. The largest gap is 0.95mm, and others are 0.8mm or less. The X5 50i really chews through oil and plugs. Also, I had some difficulty getting two of the coils out, because the BMW Stealer who did the job last time broke the clips on them. New plugs are gapped to 0.8mm as standard and I went with the non-M plugs. There is a noticeable change in the smoothness of acceleration in higher gears with low rpms. |
12-03-2021, 02:01 AM | #158 | |
Rep 1,038
12-03-2021, 02:55 AM | #159 |
Rep 112
05-15-2022, 07:34 PM | #160 | |
Rep 7,165
I'm changing mine again. My oem M plugs have gone 50k miles without a single hiccup with a tune. Changing now because I had free time this weekend and my wife drives it as a daily since I moved to an M5. Also decided to replace the coils as well since I don't want to have to open it all up in 20k miles should the coils start to go. Picked up a set of Eldor and decided to give NGK a try as I could source them for cheaper than OEM M plugs. I'll post picks on what they look like.
05-15-2022, 08:06 PM | #161 |
Rep 112
05-16-2022, 02:30 PM | #162 | |
Rep 7,165
On a side note for everyone else. Here is a pic of the plugs after about 50k miles.
05-16-2022, 02:33 PM | #163 |
Rep 7,165
Here's the oem Bosch and new eldor coils. They look pretty good for 80k miles.
05-16-2022, 11:27 PM | #164 |
Rep 7,165
So in typical bmw style a plastic coupler broke when I was moving tubes around. It's to the oil return line so not under pressure so I simply used some JB plastic weld. Shouldn't be an issue but I'll check back in a couple days to see if any oil is leaking.
Other than that everything is great. Could immediately tell a difference on start up. Very quick and smooth. Only snag was it took a bit more focus to get the coils to seat all the way down. I remember the last time they seemed to just pop back on. These gave a bit of resistance that last mm or 2.
05-16-2022, 11:42 PM | #165 |
Rep 112
05-18-2022, 10:51 AM | #166 | |
Rep 1,340
05-19-2022, 10:07 AM | #167 |
Rep 7,165
05-19-2022, 11:54 PM | #168 |
Rep 112
05-20-2022, 08:36 AM | #169 |
Rep 1,340
FCP euro offers the same non-M spark plugs for F85 as well. I did some digging recently before I bought the non-M ones for my 2017 F85 (haven't installed it yet). Here's a thread with good info: https://f10.m5post.com/forums/showthread.php?t=1605952
From the info in the thread, it appears that both plugs are identical except in center electrode diameter. |
Maverik2594150.50 |
05-20-2022, 06:19 PM | #170 | |
Rep 7,165
classic_erik2811.50 Edwardsc1255.50 |
05-20-2022, 06:36 PM | #171 | |
Rep 7,165
All I can do is provide personal experience. That's the point of a forum that seems to get lost on these new comers as of late. At 20k miles I increased boost with a race hip and within weeks my plugs were fouled and I was bogging down under WOT. I Put in the M version and ran them for another 55k miles without issue. At $4/ idc if they were almost the same. They were clearly better. So idk what to tell y'all. Either way doesn't matter, we only used the M version years ago because they were cheapest available! I used NGK this go around. But I'm sure someone will tell me they're the same as oem too. Haha
bmwx5er359.50 |
08-30-2022, 09:09 AM | #173 |
Rep 42
Can't detail the usefulness of this thread enough. to the OP for the amazing amount of detail and great pics. Recently purchased bm3 and plan on tuning soon. I'm at 40k miles now so will probably stick with the "if it isn't broke don't fix it" approach. If I'm lucky stock plugs will last till 50k to 60k which would have been time to change anyway. Already plan to refer back to this thread as soon as I need to replace plugs/coils.
2017 (F15) X5 50i M-Sport
2015 (I01) i3 2010 (K46) Motorsport S1000RR Retired: 14 (F25) Alpine White 3.5i MSport, 2005 (E53) Imola Red 4.8is, 95 (E36) Boston Metallic 325i |
Maverik2594150.50 |
09-02-2022, 09:31 PM | #174 | |
Rep 7,165
09-03-2022, 01:21 PM | #175 |
Rep 13
Thanks for the diy, it helped me out.
Maverik2594150.50 |
04-21-2023, 05:53 PM | #176 |
Rep 111
Nice DIY, saved me some time for sure. Plugs on my stock 50i were definitely toast at 67k. Their gaps were all over the place. New Bosch plugs came out of the box a little tight at less than .030...all of them. Gapped to.030 plus a little.
Didn't bother with coils at this time but did manage to break one clip. No worries, you can secure the plug with a zip tie and little effort if you do. Amazing about of pickup restored. Shocking amount actually. |
Maverik2594150.50 |
