09-25-2018, 11:57 AM | #1 |
Rep 196
Hey just curious is anyone else has had this issues.
I don't often drive the x5 at night. But was picking up a friend on a fairly hilly rural road over the weekend As went up and down some hills it was Almost scary at times how slow it seemed the headlights reacted to move up/down as the elevation changed. It almost left me in the dark a few times. Even my passenger who tagged along made a comment about it. I had an issue with my e46 with the auto levelling system. The bar/sensor which if I remember was under the car around the sway bars was broken and they would almost be permanently pointed 10' in front of the car at the ground. Do the f15 xenons work the same way? I wouldn't mind trying to diagnose this myself before bmw Has it and has to replicate this during day light hours. Is there anywhere to manually adjust the sensitivity of them? Thanks.
2015 X5 35d M sport
2017 340i M sport 1991 M5 1988 M5 |
09-25-2018, 12:04 PM | #2 |
Rep 535
I have noticed this too, no error codes ever, not sure how to diagnose.
Present: 2014 X5 50i
09-25-2018, 03:12 PM | #4 |
Rep 196
Sorry, I guess my wording is wrong. What I'm referring to is the adaptive headlights.
2015 X5 35d M sport
09-25-2018, 03:16 PM | #5 |
Rep 110
I think this is about the headlights, not the X5 air-suspension. The OP headlights can compensate (within a narrow limit) for certain uphill/downhill roads or the car load imbalance. I think the Xeon ones may not react fast enough compared to the LED
09-25-2018, 03:20 PM | #6 |
Rep 1,270
Adaptive headlights (LED or Xenon) swing left or right to follow the road, basis the steering angle sensor, not up and down. It would be difficult for the car to predict if the road ahead will go up or down before the car starts to pitch...
09-25-2018, 11:40 PM | #7 |
Rep 196
Im a little confused now. The way I worded it, I understand , i was incorrect.
But that doesn't erase the fact when I go up a hill the lights aren't following me they just seem like they are lazy. I'll try to get a little more seat time at night and see if I can better describe the issue. I drive my e46 with xenons daily on a very hilly road and I don't get left in the dark the way I have been with the x5. Thanks for the input from everyone though. I appreciate it.
2015 X5 35d M sport
09-26-2018, 01:26 AM | #8 |
Rep 103
I do not think they are supposed to auto-adjust when you go uphill or downhill. This is what the user manual says:
Self-leveling headlights The self-leveling headlights compensate for acceleration and braking operations in order not to blind the oncoming traffic and to achieve optimum illumination of the roadway. I have LEDs and never noticed any issues when going up or down on a steep hill but i cannot say anything regarding the Xenons. |
09-26-2018, 01:44 AM | #9 | |||
<3 Flat Four
217
Rep 754
read here for more info, take this with a grain of salt tho as this section seems to copied from the e86 chassis section, but is also found under f15 when searched
https://www.newtis.info/tisv2/a/en/f...odule/Aj05ieCq OP, do u have the headlight switch at the "A(auto)" position or do u have it at the "on" position. these fancy functions only work when the switch is turned to the "A" position. Quote:
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White Last edited by TOPEC; 09-26-2018 at 01:50 AM.. |
09-26-2018, 05:48 AM | #10 |
Rep 196
Thanks for the link, it sheds some light.(hah) on the issue.
I have a bad habit from owning older BMWs to manually turn the lights on and off myself. So at night I would just turn them to the ON position. Not Auto. I always figured I don't need the headlights turning on and off un necessarily. I'll try leaving it in A and see if it changes anything. the pictures of the adaptive headlights explain it much better. But like I had mentioned, even my passenger had commented on why my lights were so low. So maybe there is an issue with the functioning of them. I will keep an eye on it. Still under warranty until April 2019 and with winter approaching I'll be seeing some more night time driving Also, How would I know if my car has the VLD option coded? When I ran the vin it says Variable Light Distribution is De-coded. I'm guessing that means they were coded out when delivered? I have the bimmercode app I just never got around to playing with the VLD option yet.
2015 X5 35d M sport
09-27-2018, 12:49 PM | #11 |
Rep 535
OP I think its by design. Compared to my 7 series and 5 series both of which had adaptive head lights, the X5 is very to react on bendy turns. The previous cars would move the light far left (aiming for middle of road) as soon as I was on a slight turn left and I think thats what its supposed to do. I am not sure if it does it when going up or down. The X5 is often very slow at this predictive turning business.
I do have variable lighting distribution coded, but that does not fix what you are seeing. It is a euro-spec setting and is not default in North America. It requires esys and VO coding. Try this: park close to a walk. Turn car off lights off, and turn them on. You will see it auto adjust. Thats the sign that auto adjustment is working atleast. Now can't test this really on the road, but that would be the first thing I would check.
09-27-2018, 09:44 PM | #12 |
<3 Flat Four
217
Rep 754
to my knowledge the car only goes through the auto adjustment range upon initial start up, with or without the headlights on. if the engine is already running, turning the lights off and back to auto will not instate the adjustment sequence again.
