12-14-2022, 08:51 AM | #1 |
Rep 206
Drives: 2015 BMW X5 50i
Blackstone Oil Analysis - High Aluminum
Would anyone have some insight or thoughts on this oil analysis I just got back from Blackstone? I have a 2015 50i with the N63TU engine. Blackstone noted double the average aluminum values in my oil. I had just under 5k miles on the oil and right around 69,500 miles on the car. Any thoughts would be appreciated!
2015 X5 50i - Current
2011 E92 M3 - Sold 2016 F30 340i - Sold |
12-14-2022, 10:38 AM | #2 |
Rep 5,015
Hmmmm. Some of the fluid bearings in the head are aluminum. Lots of thins in the valvetrain touch aluminum. Kind of A tough one.
Side note - 10 quarts of added oil in 4,300 miles. Holy crap. |
12-14-2022, 07:21 PM | #3 |
Rep 105
Surely that 10 qts of added oil is a typo, maybe it should be 1?. If not, I think some higher than normal aluminum is a secondary concern at this point.
2017 f85 X5M | Donington Grey | Aragon Brown
2009 e90 335i | Black Sapphire Metallic | Saddle Brown 2004 e46 330ci ZHP | Silver Gray | Black (RIP) |
12-15-2022, 09:33 AM | #5 |
Rep 666
The intake camshaft bearing caps could be a suspect. And in our case with the N55's, there aren't any real bearings with the camshaft. The shaft journal just sits inside the half round housing from the head and the other half round housing are the caps themselves. And boy I'll say this, I've worked on 4 heads so far which are minimum of 70k miles each, and a common find I always observe is the caps are always VERY scratched up. There's oiling holes from the head half, but the caps are just non-oil caps, so if the oil has any bit of dirt or debris, it can go in there and end up on the cap side and create some scratches.
Look at this blog and refer to the pictures for the cap wear: https://bmwtechnician.com/2017/10/25...haft-bearings/ When I took mine out, I find much worse wear on mine (@190k miles, henceforth a full rebuild). On assembling everything back, I sanded the caps grooves and smoothen it out, then took it to the blast cabinet to oxide blast the surface for MicroSlick Cerakote. Then after 6k miles, took the caps out again to check for wear, caps 0 and 1 have had the Cerokote worn out a little bit, but 2 through 6 are all intact. And goes to explain why when I do see this wear, they are mostly on cap #1, and some on #0. Anyway, if you're having this same problem, chances are that you won't even notice it from the way it drives, until it's too late where the camshaft starts to really grind down on the cap. But as far as having that much aluminum debris in the oil can point to many things; and this could be one of them.
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump Last edited by yupetc; 12-15-2022 at 09:40 AM.. |
12-16-2022, 10:11 AM | #6 | |
Rep 5,015
12-27-2022, 10:21 AM | #7 | |
Rep 206
The 10 quarts was definitely a typo, I would be extremely concerned if I had to add anywhere close to that much. It should have been 1 quart. It was really 2 quarts by the time all was said and done, but I am wondering if the dealership did not fill it all the way when I first got the car. I got a Low Oil Warning light like a week after I bought it.
12-27-2022, 10:22 AM | #8 |
Rep 206
Thanks everyone for your insights, I'll be keeping an eye on it through the next oil change to see if anything changes. I have not heard any strange noises, so it's just a waiting game at the moment
