03-04-2014, 12:56 AM | #1 |
Rep 241
Equalizer settings for HK
Could someone please advise on ideal eq settings. I know I should play around with them but maybe someone has found the "sweet" spot. I am looking for best clarity with a nice "tight" base. I am trying to get that thump that u feel inside. Can this be achieved with the Harmon kardon
03-04-2014, 01:19 AM | #2 | |
Rep 1,368
Does it not have pre-set options e.g. Rock, Blues, Soul, Vocal etc etc |
03-04-2014, 01:50 AM | #4 | |
Rep 1,377
03-04-2014, 05:25 AM | #5 |
Rep 161
Just wondering something : why do people always says "Harmon Kardon" ?? This is "Harman Kardon", a brand founded by Sidney Harman and Bernard Kardon ! :P
04-03-2014, 10:26 AM | #6 |
Rep 69
I don't buy the "settings will depend on the type of music you like to play". It is always about the "room" and your equipment.
So saying that, there MUST be an optimal setting for the HK in the F15 cabin. Sure, some may find certain settings more pleasing then others, but as far as clarity and reproduction concerned, there has to be a "sweet spot". From there we can slightly adjust to our liking. I have been playing around to avail at the moment. The best I got is a pattern like so: 0 -1 -2 -3 -2 -1 0 Starting with 0. I find that it is more beneficial to reduce the frequencies rather then boost them. Boosting introduces unnecessary noise, you can simply increase the volume if you want more impact. These are with Logic 7. Anyone has any settings they can share? |
04-05-2014, 07:47 AM | #7 |
Rep 159
When HK worked with BMW to design the new sound system for the F15, would they not have created the default setting to be the optimal sound setting for this car?
04-05-2014, 11:23 AM | #8 |
Rep 528
I would like to see the settings from a professional calibration using a sound meter. From what I remember from HK threads of other BMW models there was a consensus that reducing the 200 setting was good for truer sound reproduction.
04-05-2014, 12:40 PM | #9 |
Rep 423
I picked this off of the 335i board. Don't know if this helps or not.
I just spent a good part of an hour taking some quick measurements with a tone generator and SPL meter. Here a few bits for HK owners to chew on while I continue to get to know the system. The two major issues in the bass region are the following... 1. There is a deep hole in the response centered at 130Hz. I suspect this hole is from the midrange drivers in the doors not being able play this low of a frequency with any authority. 2. Arguably just as significant of a problem is a big rise in the response just above 200Hz. I can't help but think this is a byproduct from an attempt by the designers to deal with the first issue mentioned. As an overarching theme, I'd suggest experimenting with seeing how much "boost" you can apply to your 100Hz slider, and how much "cut" you can apply to 200Hz slider before it's too much for your taste and listening material. Notes on the EQ and tone controls: EQ has approximately 10dB of boost/cut per band. As expected, the EQ bands are fairly "low Q." This means they are broad; less-than pinpoint adjustments. For example, the 500Hz slider still boosts/cuts a 1kHz tone about 7dB. I believe the Bass level adjustment is a very broad "shelf" type, effecting all bass frequencies. This is how you adjust frequencies below the 100Hz band in the EQ. My measurements and listening were done at a standstill, but this is how I have my car set to start tomorrow's day in the office (my car). I'm not completely married to these settings but this is how my HK is set for now. Treble flat Bass +1 L7 on 100Hz +5 200Hz -7 500Hz +1 1kHz +1 2kHz flat 5kHz -1 10kHz -1 |
04-05-2014, 07:09 PM | #10 |
Rep 454
Used the above settings except I thought it sounded better...
100 hz +4 200 hz -4 Cleaned and tightened the bass.... But middle range still sounds "muddy" to me. Of course it depends on the material and input. |
05-06-2015, 08:56 AM | #14 |
Rep 93
Cabin size and speaker layout will absolutely make a difference on your settings. You really have to get someone who can do a professional calibration just for the X5.
I personally listen to all rock and hip hop.. those are the settings I am looking for. Love this thread! I too believe the system right now is muddy when I listened to it at the dealership. Waiting for mine to arrive new next week. |
05-06-2015, 09:06 AM | #15 |
Rep 5,066
I've the question as you can see above and it appears that not many people want to share their preferences and it is probably due to that everyone is different with sound.
I've been playing with my settings and to me for each type of music the optimum settings is different per genre. So it is difficult to find one setting for all music types. |
05-08-2015, 07:11 PM | #17 |
Rep 159
When HK worked with BMW to design the new sound system for the F15, would they not have created the default setting to be the optimal sound setting for this car? Why would you have to buy a tone generator and SPL meter to make the sound better? Why would you think the "CNET boys" would do a better job than the "Harmon Kardon and BMW boys" in designing the default installation and sound specs for the this car?
If it is not to your taste, just monkey the equalizer settings to what your personal hearing likes. However, I very much doubt anyone else but BMW and HK know how to set up the defaults for this car as a default for a broard spectrum of sound. |
05-09-2015, 06:01 AM | #18 |
Rep 103
This is a good thread and yes although people's tastes are different it's good to know what others use. The one thing I find really good is putting some of the sound to the rear as you gain a more "amphitheatre" type sound feeling if you do this and you IMO can hold more bass without it getting overbearing.
For me: Logic 7 on Bass +2 Treble Flat Rear +2 Will revert with EQ settings |
05-09-2015, 07:39 AM | #19 | |
Rep 682
05-09-2015, 04:04 PM | #20 |
Rep 423
I Googled HK equalizer settings and there were quite a few responses listed.
I tried most of them and finally settled for what I think was best for my ears. That said, I do think that HK should have made presets for certain music and then give us the option to modify it and save it, rename it as our default. Our knock around car is a Chevy Cruze and it has the optional Pioneer 9 speaker system and it has preset equalizer settings or you can set your own. BMW just behind the times in electronics IMHO. |
05-10-2015, 09:33 AM | #21 | |
Rep 103
06-28-2015, 09:51 AM | #22 | |
Rep 113
Best setting i tried so far, thanks!!! |
