03-05-2014, 03:11 PM | #1 |
Rep 118
radio stays on when I get out of the car.
When I turn off my 2014 X5, the radio stays on. This is good, most of the time.
When I park in my garage at home, I don't lock the car. I'm afraid the radio could stay on indefinitely. Is there a way to turn this "radio stays on after engine is off" function off? Or some other work-around?
thanks,
someguy |
03-05-2014, 03:41 PM | #3 |
Rep 3,307
It will also shut off after a while to keep from draining the battery, 5 minutes I think but could be wrong. But locking it is always your best option to make sure you don't forget that second push of the start button. Also preserves the battery. My wife used to leave her X3 unlocked occasionally and sometimes with her purse (and key) in the car. That drains the battery and I got the low battery warning, had to drive around aimlessly for an hour to recharge it.
I also read on here you can hold the start button in longer on the first push and it will shut off the engine and accessories, but I've not tried that. I'm just used to hitting it twice at this point, or once and locking the car. |
03-05-2014, 03:56 PM | #4 |
Rep 118
hmmm. it seemed to me that pressing it again might start the car (again). but maybe only with my foot off of the brake? I'll try it.
thanks,
someguy |
bluesman826646.00 |
03-05-2014, 04:23 PM | #5 |
Rep 161
Push start again WITHOUT pushing brake pedal, and then the car goes completely off.
Another option : lock the car and then unlock it. Like you I do not lock my car in the garage, could sound weird, but the explanation is simple : in the morning my wife is used to prepare me a breakfast and put it in the car before I go to work, and she doesn't want to have to search for the key ^^ I love my wife |
03-05-2014, 05:22 PM | #7 |
Rep 132
This car is full of a bunch of "That is a good idea" kinda stuff that don't really work.
I mean at least give us an option of having the press the Start Stop twice with your foot off the break vs making it the default setting and unchangeable. The second most annoying thing is of course the Phone Cradle Dock. |
03-05-2014, 06:07 PM | #8 | |
Rep 3,307
On the door, most people lock their cars… so I don't think the second push is all that poor of a choice as default. If it went right off, so would the radio. Perhaps a better default would be to switch off accessory on first push, but leave just the radio on until the doors open, then all off, like most other cars do. |
03-05-2014, 08:15 PM | #10 | |
Rep 196
03-05-2014, 11:21 PM | #11 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
Instead of pressing the start/stop button to shut the engine off and then again for electronics, Simply hold the start/stop button for a 1/2 second longer and it will power everything off. If you lock the car with CA it will also shut your radio off if you forget to double push or loooong push.
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
03-06-2014, 03:38 AM | #12 | |
48
Rep 313
03-06-2014, 04:40 AM | #13 |
Rep 1,887
To shut the vehicle off, hold the button in for a half a heartbeat longer and everything should shut down. I could be wrong, as I don't have an X5 yet, but this is true of every previous, and current BMW that I have with the pushbutton start.
03-06-2014, 04:00 PM | #14 | |
Rep 46
03-06-2014, 06:59 PM | #15 |
Rep 3,307
FWIW, I tried this on my F30 and it didn't work. Haven't tried the F15 yet.
03-07-2014, 03:10 AM | #16 | |
Rep 774
Almost all other manufacturers have the radio turn off, if you open the door = smart. Pressing a button 2 times to turn the radio off=plain stupid. BMW has their own logic in many things, I just don't get why. |
03-07-2014, 10:06 AM | #17 |
Rep 161
03-07-2014, 10:41 AM | #18 | |
54
Rep 373
That's how it works on my E93 as well, so at keast BMW is consistent with their illogic. Also annoying is that if you want to keep the radio playing with the engine off (for example if you're waiting to pick up your better half at the airport and don't want to idle the engine) it automatically turns off after about 5 minutes and you are forced to restart the car. That's annoying too.
F83 M4 convertible, F15 X5 xDrive35i
Previous: E93 335i, E36 328iC, E28 528e, E21 320i |
03-10-2014, 05:01 PM | #19 |
115
Rep 653
BMW leaves the electronics on because it is the equivalent of turning off the engine and leaving the ignition on when we still used a key.
Others would complain if it went off immediately. I agree there should be a menu item in Settings > doors/ lock But meanwhile, this is what happens when the engine is shut off with one press: > so long no door is opened the electronics will stay on and time-out automatically after about 8 minutes. > if a door is opened and the car locked, the electronics go off, the car is locked and the alarm is activated (if equipped). For those of you who 1) do not want to wait, want the electronics off *right* this second: simply press a second time or as mentioned above, long press when turning off the engine. Obviously having the foot of the break and pressing the Start/ Stop button is how you start the car so here, the outcome will be the same, having just turned-off the engine notwithstanding. 2) do not want to have to press a second time (just 'cause...), the car can be coded to have the electronics go off after the engine is shut down and when the driver's door is opened. Many people leave their cars unlocked in the garage and the car will drain its battery even if the electronics have timed-out. The ///M cars do this very well. - |
03-10-2014, 05:39 PM | #20 |
Rep 102
If the dreaded, idiotic, useless push the button twice feature is the same on the new X5 as it is on the five series, a long push on the start/stop button will NOT turn everything off. Get a sense of how I feel about this feature? If you forget to push the button twice and walk into your house and your phone rings….it will be connected to your blue tooth in your car for the first eight minutes. Wonderful. Arghhhhhhh.
04-07-2014, 11:18 PM | #21 | |
Rep 713
Drives: '06 E90 - '04 E85 - '16 F15d
There is one other option to consider when using the technique of locking and then unlocking the car to get the radio to shut off. There is an option in iDrive you can enable that will re-lock the doors if a door is not opened after you unlock the car.....so if that is enabled you may find the car locked when you return if you never open a door. We have had the car for three weeks and couldn't be happier with the way it drives and comfort of the interior, and the awesome range of the diesel (600 miles on the first tank in mixed driving). The annoyances are the disclaimer startup screens, the parking system warning, and the floppy door seals that keep getting folded back when I get out.
