05-01-2014, 02:34 PM | #68 |
Rep 18,682
Just received a few more of the grill trim.
Also the plastic rivet for the fender flare that need to be partially removed in installation process. I personally only able to take off 3 of them instead of the whole thing.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... Last edited by r33_RGSport; 05-01-2014 at 02:48 PM.. |
05-01-2014, 06:34 PM | #69 | |
Rep 157
05-01-2014, 07:54 PM | #71 |
Rep 32
I'm interested as well. Please send a PM
www.atranstudio.com
2014 X5 35i M Sport // Black Sapphire |
05-02-2014, 12:36 AM | #72 |
Rep 18,682
First of all.
Here are the pictures of my updated mods. I just lowered it and decided to get the M Performance kidney grill. Secondly, I am PM'ing 3 of you.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
05-02-2014, 12:50 AM | #73 |
Rep 3,990
Wow, Ben! Looks awesome!! The plastic splitter def makes the car look more aggressive/better. How is the ride? Does it affect your tires at all - rubbing, etc.? I'm kind of curious in case I wanted to lower mine with the 22's already installed - if that's even possible. Thanks!
05-02-2014, 01:22 AM | #74 | |
Rep 18,682
Ride is ok. I did a quick write up on the other lowering spring thread started by TrinityTwo. I would love it to go stiffer and less rebound. It didn't rub in any way. With your car, the reason your is rubbing, because your overall diameter is bigger than the original setup. Which is good in a way, this way you have more meat on the tires, so softer ride and you get more distance in 1 rotation. The supposedly size for the F15 with 22" is 295/30-22 front and 335/25-22 rear. So, to answer your question, yes you can lower yours, but be prepare with more rubbing on a full turn. The slogan was, it is not low enough if it didn't rub. But of course, it meant by rubbing on the fender.
05-02-2014, 01:32 AM | #75 | |
Rep 3,990
05-02-2014, 02:21 AM | #76 | |
Rep 18,682
05-02-2014, 02:24 AM | #77 |
Rep 3,990
05-02-2014, 10:57 AM | #78 | |
Rep 54
So it's required to remove the fender flare in order to access the rear of the lower grills to install the trims? And those plastic rivets are required because the fender flare uses 1-time rivets? Or are those plastic riviets used for something else? I thought you could just pull the wheel well cover off to access the rear of the lower grills?? |
05-02-2014, 11:03 AM | #79 | |
Rep 18,682
I, myself, managed to only remove 3 rivets, since the fender liner is consist of 2 pieces. Front half and Rear half. Man, I should've done the DIY or taking picture. The plastic rivets is 1-time use. Also, should've took a picture for comparison. Anyway, I will try to take a picture and post it later.
05-02-2014, 11:43 AM | #80 | |
Rep 41
I searched the web all over the place to buy them but couldn't get it. Ben got it I don't know how. |
05-02-2014, 12:52 PM | #81 | |
Rep 18,682
I know some people that know some people. j/k. Great that USPS didn't screw up my shipment, haha. My apology for not letting you know about the rivet situation earlier.
05-02-2014, 05:52 PM | #82 |
Rep 18,682
Here is the picture of the used rivet.
Also the picture where the front 3 of the rivet that I removed. Only up to the middle part of the front fender liner. I hope you guys can see the line that separate the front portion to the rear portion of the fender liner.
05-05-2014, 05:01 AM | #83 |
Rep 18,682
FYI, the rivet is not re-usable. You can use it to cover the holes, but it won't be functional.
I currently re-using mine because I am debating whether to paint the side marker or not. Maybe you guys can give me an input on painting the side marker or not.
05-05-2014, 11:19 AM | #84 |
Rep 1,377
No harm in painting it. My bumper has a slight color mismatch on one side which makes the painted reflector appear like a different color.
05-06-2014, 08:55 PM | #86 | |
Rep 18,682
It is worth to do it, I wish BMW made it much easier to put on.
05-07-2014, 09:19 AM | #88 | |
Rep 18,682
In that case, you can use the H&R springs front with adjustable link in the rear. That set is available in the market already for a few months. Let me know if you need it. Also, as far as warranty, if you really worry about that, keep your car as stock as possible. Otherwise, dealer will always find a way to void your warranty just because they are being an ass about it. But, in my experience with my F10 running JB4 Stage 2, with catless downpipe, and lowered on KW suspension, also with my customer E92 with JB3, full cat back exhaust, Bilstein PSS10 coilover, with Brembo brakes, they still takes care the car without any trouble. But then, they are dealers in LA, the capital of fixed up cars.
