      04-18-2014, 11:15 PM   #1
mikikuki7
mikikuki7's Avatar
Drives: Searching for X6M or M8
Unhappy has anyone created an F15 coding cheat sheet...
Has anyone created a cheat sheet for coding the F15?
      04-18-2014, 11:21 PM   #2
Jenya B
Russia
144
Drives: Z4 , X5 F15d Msport
      04-19-2014, 12:42 AM   #3
ljxrayman
Drives: 2014 X5 M Sport Mineral White
      04-19-2014, 12:59 AM   #4
Sorry, been busy with work.
I'll compile it next week.
PM for Everyday DEALS!!
      04-19-2014, 06:07 AM   #5
Jenya B
Russia
144
thanks bud
      04-19-2014, 04:54 PM   #6
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
Likewise. Though there's not much of a difference between the F15 and some contemporary cars, like the F30 and F10.
The primary difference is the introduction of the BDC ECU, which now contains most of the functions previously found in CAS, FEM_BODY, and REM.
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP
      04-19-2014, 05:01 PM   #7
mikikuki7
mikikuki7's Avatar
Lol, I don't want to go changing everything to see what works and what doesn't hahaha....
      04-19-2014, 05:38 PM   #8
wdimagineer
Drives: 2015 X5 M
I haven't found anything that doesn't work yet based on the cheat sheets we've previously created for cars like the F10.
We figured most of this out by trial and error.
      04-20-2014, 11:33 AM   #9
golovan
Drives: 2015 X5 35D
Did you find halo brightness code? I didn't find it under BDC. I think it is still there but with different name.
      04-20-2014, 03:01 PM   #10
wdimagineer
Drives: 2015 X5 M
I have not. Personally I find them bright enough. But I can dig.
      04-20-2014, 03:02 PM   #11
mikikuki7
mikikuki7's Avatar
I tried looking for it, but was not able to find it either... Have to translate each one of them... Ha
      04-21-2014, 03:16 AM   #12
CatFlap
United Kingdom
21
Drives: ...
Lightbulb
Good old 'Google Translate' eh? - we'd be lost without it!
X5 F15 - gone after 5 months!
      04-21-2014, 02:07 PM   #13
wdimagineer
Drives: 2015 X5 M
There are several options for the halo/angel eye brightness. They vary depending on whether the headlights are off (DRL), on, or in parking light mode.
All in BDC_BODY:
DRL:
MAPPING_TAGFAHRL_V_L_PWM_LEVEL_1
MAPPING_TAGFAHRL_V_R_PWM_LEVEL_1
Headlights On:
MAPPING_STANDL_V_L_PWM_LEVEL_1
MAPPING_STANDL_V_R_PWM_LEVEL_1
Parking Lights On:
MAPPING_PARKL_V_L_PWM_LEVEL_1
MAPPING_PARKL_V_R_PWM_LEVEL_1
Each takes a hexadecimal value for the brightness.
Defaults for DRL should be 64, which is 100%. Defaults for the other 2 should be 8.
So, 0% = 0, 25% = 19, 50% = 32, 75% = 4B, 100% = 64.
For those who don't speak German:
tagfahrlicht = daytime running light
standlicht = sidelight
parklicht = parking lights
      04-21-2014, 02:11 PM   #14
Jenya B
Russia
144
seats ventilation code please
      04-21-2014, 02:19 PM   #15
mikikuki7
mikikuki7's Avatar
All in BDC_BODY:
DRL:
Headlights On:
Parking Lights On:
You know what I noticed? When I walk to my car during the day and I press the unlock from key fob, the angels won't turn on! It only does it at night or when it's dark... Anyone has the same problem? May be a coding thing... I'll look into it as well!
      04-21-2014, 02:20 PM   #16
bradbragg
Drives: 2014 X5 sDrive 35i
+1 for a list of codes mentioned in other posts
      04-21-2014, 02:21 PM   #17
wdimagineer
Drives: 2015 X5 M
Make sure your welcome light settings are correct in iDrive.
iDrive -> Settings -> Lighting.
You'll see the options at the bottom.
      04-21-2014, 05:43 PM   #18
mikikuki7
mikikuki7's Avatar
Well, it has never done it.. I changed all the things in the iDrive Menu and nothing...
      04-21-2014, 07:58 PM   #19
wdimagineer
Drives: 2015 X5 M
Do you turn your headlights off or keep them in Automatic?
I'm pretty sure mine turn on but maybe they don't.
      04-21-2014, 08:31 PM   #20
mikikuki7
mikikuki7's Avatar
They are on Automatic... Always been... Mmm I'll switch to off and see if that works.. I would hate to switch them all the time....
      04-21-2014, 08:34 PM   #21
wdimagineer
Drives: 2015 X5 M
Mine too.
      04-21-2014, 09:46 PM   #22
https://docs.google.com/spreadsheets...it?usp=sharing
Here is the cheat sheet for now as promised.
Gotta run for now, there are a lot more basics coding that can be looked under F10 or F30 cheat sheet, but yet to confirmed.
The cheat sheet is full access to anyone, feel free to edit, add, and correct.
2014, coding f15, f15, f15 coding
