      04-24-2014, 07:56 PM   #45
Originally Posted by jpsjr70 View Post
Vented seat temp? Can someone explain?
It is to freeze your ass off.
It is to lower the temp for the seat ventilation. I don't have this option in my car, but Ziphoria and Nikonman has it and I code it for them. They told me that they can feel it cooler now, but not to the point where it will freeze your ass.
If you live in Cali or Texas, you probably will need it. But you have to have the ventilation seat option.
You can set the seat heating into higher temp also, but I haven't tested it. Maybe someone in the east coast can confirm what is the best temp setting.
PM for Everyday DEALS!!
      04-24-2014, 09:13 PM   #46
jpsjr70
jpsjr70's Avatar
Drives: 2015 BMW X5M
Wow! I need that! How can you help me code? I would be more than happy to pay.
J
      04-24-2014, 11:52 PM   #47
J
Since you are in NJ, look up this post.
I personally don't like remote coding, unless you are 100% that you won't loose wifi signal or don't have battery issue on the laptop.
http://www.bimmerfest.com/forums/sho...d.php?t=693949
st152.00
      04-25-2014, 12:06 AM   #48
v12
Drives: F10
Hey guys - the ventilated seats do not work in conjunction with the A/C. They just use fans. Coding a lower operating temp. point is highly recommended since they don't much by default.
I cover the CT/NJ/NY tri-state area in person and code remotely when meeting is not an option.
      04-25-2014, 10:18 AM   #49
mikikuki7
mikikuki7's Avatar
Drives: Searching for X6M or M8
yes, this is what I do and works great too.... I have the air from the rear controls come out on from the bottom (through feet) if you see the air duct, it has a twisted end so the air can flow up and cool the seat.. it cools my seats pretty fast
      04-25-2014, 10:22 AM   #50
Hey, so you got your car to start up?
The car only need to sleep through the night I guess, right?
      04-25-2014, 10:27 AM   #51
mikikuki7
mikikuki7's Avatar
LOL, I left it for a few hours, but the codes were at default values. Someone remotely connected and re-coded the vehicle
My SA told me that he would reset the vehicle so I could start fresh lol... he wants me to code his new X5 too... so I'm excited! You have been of great help r33! Thanks a bunch!
I re-coded my vehicle just for practive and I found a way to increase the LED Corona brightness to 99%, just like my '13 X6. BRIGHT BRIGHT BRIGHT!
There is some coding about Blu-Ray, but I suppose you have to have BR drive or something like that...
The rear glow lights also stay on during the day which is cool! The glow looks awesome!
      04-25-2014, 10:30 AM   #52
Haha. Great. Next time, save the default before start messing around with it.
      04-25-2014, 02:46 PM   #53
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
I might increase this as well. Can you take pictures of both the front and rear lights. Thanks
      04-25-2014, 04:04 PM   #54
bradbragg
Drives: 2014 X5 sDrive 35i
1. Would someone be so kind as to add the coding for defaulting ACC distance to the shortest one? I use ACC all the time and it would be nice if it defaulted to the shortest distance, as I use that 95% of the time.
2. Does anyone have a picture of what the rear DRLs look like? Curious about coding it but not sure I want brake lights on all the time.
      04-25-2014, 04:13 PM   #55
Brad,
The rear DRL is the same as when you turn on your light at night. Except this time it will be on all the time.
It is separate then the brake light itself.
Just switch on your light manually and look on the back light. That's how it will looks light when it is set to be on all the time.
      04-26-2014, 08:30 AM   #56
atomic80
Drives: 997TT
YES! I'd be interested in the coding info for this too!
      04-26-2014, 08:43 AM   #57
Unfortunately I can't help you guys with that. I don't have that option in my car.
      04-26-2014, 12:10 PM   #58
oshevtsov
oshevtsov's Avatar
38
Drives: E90/E60/F10/F15/F16/F32/G11
Auto PDC not working after coding F15
Coded F15 with usual stuff: ASS memory, video in motion, DVD playback for all areas, seat belt reminder off, enabled video codecs and DRL switch. Auto PDC stopped working (activation by switching into R and by button work as usual).
100% sure that PDC-related modules were not touched.
Has anyone come across this before? Thanks for any ideas
      04-26-2014, 12:14 PM   #59
wdimagineer
wdimagineer's Avatar
Drives: 2015 X5 M
Look for ICM->3000 Daten, F8->LDM_Abstandsstufe_init or a similar function.
Set Werte=01 (the default is Werte=04) for ACC position 1 or whatever your preferred distance is.
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP
      04-27-2014, 11:40 PM   #60
bradbragg
ACC distance coding
I tried to changed the spreadsheet for the coding but Google wouldn't let me.
I was able to find the ACC distance setting with Wdimagineer's help.
It is in ICM, 3000 Daten F8, C_Abstandsstufe_init
Set Werte=01
Works like a charm.
      04-29-2014, 04:30 AM   #61
ljxrayman
Drives: 2014 X5 M Sport Mineral White
Coding Issue Help!! LED gone
After coding using the cheat sheet r33 provided, I was able to get all the features listed in the sheet working. However, my interior LED lights are gone!!!! And both driver side and passenger side' interior FOOT LIGHTING are also gone! See pictures. I didn't touch any other module other than the modules listed in the sheet.
Now I'm desperate....could someone help me please....
      04-29-2014, 06:43 AM   #62
Jenya B
Russia
144
Drives: Z4 , X5 F15d Msport
DONT WORRY BUD !!! I had same problem after coding , just let your car fall asleep , and after that everything will start working again . just turn it off , wait 20 minutes and ON again .
      04-29-2014, 08:21 AM   #63
griffith_500
Switzerland
8
Drives: X5 50i F15, F430 Spider
Thanks for all your input and the cheat sheet, I was able to code a few things.
A few things left to do, maybe someone with experience can tell my in which modules to find those as they don't seem to be in BDC Body, Kombi or HU_NBT. I can't start the engine when coding and am afraid of draining the battery if I continue to look through each CAFD.
MACRO_CAM_LEGALDISCLAIMER
V_SCHWELLE_1
V_SCHWELLE_2
SV_Activate_Speed_Limit initwert / Werte=0F
SV_Deactivate_Speed
SBR_FA_GWF_SBR_FA
NAVI_FUELSTOP_PROPOSAL
Anybody found these yet?
Many thanks!
andy
      04-29-2014, 02:09 PM   #64
griffith_500
Switzerland
8
Never mind, found everything with TokenMaster's very useful CAFD tool; either I didn't search correctly in E-Sys or the search is not reliable.
      05-03-2014, 07:55 AM   #65
bradbragg
Anyone out there know how to code to unlock doors when engine is shut off? I see it on the F10 cheatsheet as ER_KEYOUT_AUTOVR in the CAS module but couldn't find it anywhere. I have my X5 set to auto lock doors when put into drive and it would be nice to also have it auto unlock either when engine is shut off.
Also, I know there is a code for to keep fog lights on with high beams, but I was wondering if there was a way to code to remember fog light on/off status. I like the fog lights on with low beams but I am forced to manually turn them on every time.
Thanks.
      05-03-2014, 12:42 PM   #66
troylees
Drives: Mini
Hi all, anyone can show me another address to download the X5 cheat sheet? I cannot open the address above. Mail is ok, thanks in advanced!
2014, coding f15, f15, f15 coding
