      04-30-2014, 04:23 AM   #1
atranphoto
atranphoto's Avatar
Drives: 2014 BMW x5
Headlights
I really regret not getting the LED light option. Couple questions:
Does anyone have pics of the standard xenon headlights? It's the same exterior right? Only the bulbs and light intensity is different right?
Do you think there will be an upgrade in the future?
My car arrives 5/10 . So excited.
www.atranstudio.com
2014 X5 35i M Sport // Black Sapphire
      04-30-2014, 04:48 AM   #2
Zipforia
Zipforia's Avatar
62
Drives: 2016 BMW i8
Xenon light picture below.
Yes on both. Also, inner "lights" are dummies in xenon. The outer lights do low and high beams, while both (inner and outer) LED light are functional.
I would ask the dealer if you can change out the light housing to LED lights. I don't know if there are voltage difference and/or other mechanisms that are different, but if it's just the light housing only, then you can simply buy the LED light housing and change it out...although that might be expensive.
Congrats on the X5! Can't wait to see it! Post pics!
Z.
      04-30-2014, 04:53 AM   #3
Xtremery
Drives: 2016 X5M F85
I got the standard xenon. You can't tell the physical difference of the car other than the bar through the lens on the led version I found.
You will be just as happy.
      04-30-2014, 04:58 AM   #4
atranphoto
atranphoto's Avatar
Drives: 2014 BMW x5
Okay phew, I'll stick to the standard xenons for now and upgrade in the future. I wish I checked it off in the first place. Oh well, I'm still super happy and excited.
And yes! Will definitely post pics. I have so many parts already waiting hehe
      04-30-2014, 08:29 AM   #5
Armen383
Armen383's Avatar
Cyprus
51
Drives: Mercedes-Benz E63S
There's been a post somewhere on the 5 series forum re: face-lifting - some guy installed LED headlights instead of xenons and also changed the back ones. So I reckon it's also doable on the F15, but will cost...
      04-30-2014, 09:39 AM   #6
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
To me theres a big difference ibhad a 2012 x5 50i with standard lights, but on my m5 i have led. Wow i must admit there is a big change on the road. U could always do retrofit
      04-30-2014, 09:55 AM   #7
buckeyewalt
Drives: 2014 X5 50i
To me also, there is a big difference in my older (2011 X5) xenon and the LED I have now (2014 X5) especially on the road. I don't know what they are rated at (if anyone knows it would be a good time to speak up) but it is definitely brighter and more of a blue color.
      04-30-2014, 10:24 AM   #8
BMWMN1971
22
Drives: 2014 BMW X5 xDrive35i MSport
After being screwed by BMW and my dealer on the 2011 X5 (I knew full LED angel lights were coming to replace the ugly yellow ones so I kept delaying my order until the dealer told me they talked to BMW and the LED angel would take several months to come out so I ordered. Guess what? Two weeks after I got my 2011 with yellow lights the LED angel lights were released) on my F15 the first option I picked was the full LED package. I couldn't be happier.
      04-30-2014, 11:16 AM   #9
Socal2025
Drives: 2014 X5 35d
I also ordered the xenon instead of the LED. Trust me, I debated about it for a long time but decided to use my $1,900 to get something way more useful to me: ACC. From what I read there is not that much difference in the brightness level. The LED looks nicer and theoretically lasts longer than xenon. I think you should just use the xenon until a few years later and then consider replacing them, if costs are not excessive.
      04-30-2014, 02:56 PM   #10
opasha
opasha's Avatar
853
Drives: 2014 BMW X5 50i
True. Also for those wondering about the brightness. Just turn on your fogs. They're LED. It does make a huge difference. So if just mere LED fogs can do that, then LED is for sure more powerful/bluer. I've done 5000K-6000K modifications and seen light output from each. LED is completely different/stronger. 4300K lumen output gives the best visibility on headlights, which is why factory oem comes as 4300K xenon from what I know. The higher you go 5000K, 6000K, etc. - the color changes to bluer, but the light output decreases, esp because most headlights are 35 watt stock rather than the brighter 50 watt. This is why, if anyone ever goes for a bluer/whiter look, they'll usually go for 5000K to stick to pure white/still have decent output. Now, LEDs get you that nice white slight blue hint look with much more powerful output of light from what I have seen. There's definitely a difference, and I think it's a good idea to upgrade down the road if the price is right and if they can be retrofitted easily.
Search this Thread:
Advanced Search
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
