01-09-2019, 12:54 PM | #1 |
Rep 234
F15 X5 Differential Fluid
Update 2/27/22:
As other's have pointed out the standard rear diff calls for the Hypoid G3. Just wanted to update this for future reference. Front: 0.91L of Hypoid Axle Oil G2 (83-22-2-413-511) a service would require ordering 2 of this part number (500mL) Standard Differential: Rear: 0.91L BMW Hypoid Axle Oil G3 (83-22-2-413-512) a service would require ordering 2 of this part number (500mL) Last edited by happydude; 02-28-2022 at 04:34 PM.. Reason: Update |
01-09-2019, 03:36 PM | #4 |
Rep 7,373
Is this for the basic diff or the the limited slip of the DHP? Or is there not a difference for lube? Haha
01-09-2019, 04:05 PM | #6 |
1658
Rep 2,995
If you look up bmw part number for differential fluid, it comes back as 75w-85 gear fluid.
I ended up just buying lucas 75w-90 synthetic gear fluid available at all parts stores. The one fluid that I did buy from bmw was the transfer case fluid. Since I couldn't find the specs on it. Charged me $50 a quart. |
01-09-2019, 04:31 PM | #7 |
Rep 234
Mine has the M-sport package, so I believe it has a different differential than the basic diff (please correct me if I am wrong, I am still learning about this model). I think I may change the differential fluids here at around 60k miles with original BMW and check the condition of the old and adjust my frequency as needed.
01-09-2019, 04:39 PM | #8 | |
1658
Rep 2,995
01-09-2019, 05:20 PM | #9 |
Rep 234
01-09-2019, 05:34 PM | #10 |
Rep 7,373
Why do you think that?
01-09-2019, 10:33 PM | #11 |
Retired Curmudgeon
3122
Rep 4,226
Redline is fine. Just remember, NS spec Redline is only for open diffs. Do not use in a limited slip diff unless you add the appropriate amount of friction modifier.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
01-10-2019, 08:44 AM | #12 |
///M
199
Rep 278
Drives: 2021 BMW X5 M50i
What about Adaptive M Suspension?
2021 G05 X5 M50i - Black Sapphire Metallic - 22" M Double Spoke Black 742M Wheels - Continental Premium Contact 6 - Dynamic Handling Package - Driving Assistance Professional - Parking Assistance - Executive Package - Extended Shadowline - Coffee, Extended Merino Leather Upholstery - Bowers & Wilkins - Leather Dashboard - Anthracite Alcantara Headliner - Heated Front Seats W/ Armrests and Heated Rear Seats - BMW Laser Headlights - Glass Controls - Trailer Hitch - XPEL Paint Protection Film - Ceramic Coating[/I]
01-10-2019, 08:46 AM | #13 |
Rep 234
My differential appears to be a limited slip differential and I based it on your comment of the limited slip differential being on the DHP. Let me know if that is accurate.
On a separate note, can anyone help me determine the fill volume? Will I need to order 1L of each or 1.5L of each of the following fluids? Front: Hypoid Axle Oil G2 - 500 mL (83-22-2-413-511) Rear: BMW Final-Drive Gear Oil Carbon Mod SAE 75W-85 (83-12-0-445-832) |
Sedoy691.50 |
01-10-2019, 08:59 AM | #15 |
///M
199
Rep 278
LOL dumb question. Adaptive M is not the same as DHP so nevermind!
01-10-2019, 03:49 PM | #16 |
Rep 234
So I do not believe these are limited slip differentials... I had mistaken the carbon mod for the friction reducer in the differential oil that I use for my e92 M3 and assumed this one was a LSD too. And I was able to find the original window sticker to the car and I do not have the DHP package.
01-17-2019, 02:43 PM | #17 |
Rep 234
Just to wanted to give an update of what I was able to find out for future reference: I have a 2014 F15 X5 xDrive35d with the standard differential and looking to perform front and rear differential oil changes. The following fluids are the recommended fluids and capacities:
Front: 0.91L of Hypoid Axle Oil G2 (83-22-2-413-511) a service would require ordering 2 of this part number (500mL) Rear: 0.91L BMW Hypoid Axle Oil G3 (83-22-2-413-512) a service would require ordering 2 of this part number (500mL) I chose for now to stick with the BMW recommended fluids as I am still under CPO Warranty through 2020 that was purchased prior to me acquiring the vehicle and in the event of any issues with the differentials I do not want to risk voiding the warranty. I also intend to keep the vehicle far behind that and will examine the condition of the fluids here at 60k miles and determine my change intervals going forward based on the results. Last edited by happydude; 01-23-2023 at 11:35 PM.. Reason: Corrected the fluid |
01-17-2019, 03:20 PM | #18 | |
Rep 1,066
Drives: 2015 X5 50i M Sport
Are you performing the fluids flush yourself or at dealership?
2019 Cayenne Turbo
01-17-2019, 09:05 PM | #19 |
Rep 234
I was going to perform them myself while I do the transmission fluid and transfer case. I bought a bunch of the transfer pumps from harbor freight for $4.99. I just ordered the parts and will probably get around to it within the next month or 2.
04-09-2019, 10:21 PM | #20 |
Rep 138
Drives: 2015 X5 xdrive50i M-Sport
Is there a step by step video or instructions on here for this job? How complicated is this?
04-10-2019, 02:16 PM | #21 | |
Rep 234
Front Differential: https://www.newtis.info/tisv2/a/en/f...ial/1VnXbUhqQ9 Rear Differential: https://www.newtis.info/tisv2/a/en/f...ive/1VnXfHavLC |
Silververtu231.00 alphaod1152.00 |
04-10-2019, 02:25 PM | #22 | ||
Rep 1,066
Thanks for the links!
2019 Cayenne Turbo
