      08-20-2015, 01:15 PM   #1
Alan l.
Alan l.'s Avatar
6591
Drives: 2026 M5 Touring
Dash cam install... Which fuse?
I know not another dash cam thread...
My Blackvue 650 should be arriving next week and going to do the install myself. Searched all the threads here and I haven't seen any solid confirmation which fuse we should be tapping into. I plan on using the fuse box in the back of the X5.
For those who have the power magic pro installed with the parking video enabled have you had any battery discharge warning issues pop up yet?
Thanks
Alan
      08-20-2015, 02:21 PM   #2
Alan, this is the post on which fuse.
I have yet to play with mine, maybe today or tomorrow.
http://f15.bimmerpost.com/forums/sho...6&postcount=13
      08-20-2015, 02:46 PM   #3
Alan l.
Alan l.'s Avatar
6591
Thanks Ben.
I've been reading all i can about BMW's with dashcams and it seems like its inevitable that you'll eventually get the battery drain warning on your idrive. Not sure the benefits of recording while i'm parked out weighs the potential issues.
      08-20-2015, 04:10 PM   #4
Originally Posted by Alan l. View Post
Thanks Ben.
Well, the lowest setting that PowerMagic has is 6 hours of recording.
And the low voltage setting is either 11.8V or 12V.
But then, there is an on/off switch where you can switch is off when you park for long time. I plan to switch it off whenever I park in the garage overnight.
      08-21-2015, 02:28 PM   #5
monkray
Drives: X5 30d M Sport
Hi Alan,
I have the two channel Blackvue 650 installed on my X5 30d with the Powermagic for six months. Very happy so far and no issues with the battery whatsoever (I have it stay on 12 hours after parking). After trying a few of the suggestions for fusion connections on the forum which did not work out, I found that connecting the red wire of the Powermagic to fuse 162 and the yellow to 107 (see photo - which should be rotated) worked perfectly. I don't know if the fuses are different between the 35i and 35d but I am using the tailgate for the permanent 12v supply.
Good luck!
Ray
G0FNDM3814.50
      08-21-2015, 03:35 PM   #6
monkray , I will use your image to update my DIY if you don't mind.
      08-21-2015, 08:20 PM   #7
dr.waxman
Drives: X5M
I have the BMW Advanced Eye and have had no warning whatsoever re battery drain
      08-22-2015, 03:49 AM   #8
monkray
Of course, please go ahead. Note that I corrected my post - one should connect the red wire of the Powermagic to fuse 162 and the yellow to 107.
      09-26-2019, 06:06 AM   #9
G0FNDM3
G0FNDM3's Avatar
Drives: E90 M3 AW
2007 335i  [9.00]
Originally Posted by monkray View Post
Hi Alan,
Good luck!
Ray
Great reference. Will use this for my 2017 X5
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
      02-24-2023, 09:38 PM   #10
donniemcm
Drives: BMW X5 F15
Hi Alan,
Good luck!
Ray
Hi, sorry to revive an old post but I tried ACC on 162/142 and VCC/BATT on 107 but it doesn't seem to work
I don't have the fuse extension you have on the picture. I just try to roll the cables mettalic part around one of the fuse leg.
      02-25-2023, 10:58 AM   #11
suitedcboy
Cattlecar
223
Drives: 16 X5 50i MSport, 21 M50i DHP
I am and have been an automotive tech for decades. Do yourself a HUGE favor and look at "automotive accessory fuse taps" on Amazon. Make sure the fuse in photo matches the ones in the fusebox. They work great and will not stretch the fuse terminals open and cause intermittent problems.
      02-26-2023, 09:38 AM   #12
donniemcm
Drives: BMW X5 F15
Thanks.
I'm going to order fuse taps, it should be safer and work better than just twisting it on the fuse end!
      03-22-2023, 12:50 PM   #13
jfandl
Drives: '14 BMW X5 5.0 (F15) - '17 M3
I ultimately tied mine into the interior overhead light. It has power for a few minutes (I think 8) after the car has been turned off. It was easy and super clean install. I just bought a 12v to USB adapter, mounted it on the ceiling above the light, ran the 12" USB cable through the rear view mirror cover. It looks super clean and factory, works great and no battery drain issues.
My Dashcam has a built in battery so it continues to record for sometime after the power source is off. Gives me recording long enough to go in and out of stores while still recording.
      03-22-2023, 03:27 PM   #14
Vivek.
Drives: 335is coupe, e30 vert
Do you have any pics of this install process? What did you have to remove and any difficulties with clips, etc? I want to do the same tap to hardwire my radar detector
Originally Posted by relative4 View Post
My wife would give me so much head if I did that.
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6
