06-14-2022, 08:28 AM | #89 |
Rep 59
hello i have f30 with apple carplay (activated aftermarket) without fullscreen only half because i have NBTEvo_H
So what version of esys and pzdata need to flash my unit for fullscreen carplay and follow this beautifull tutorial please ? |
06-14-2022, 08:31 AM | #90 |
Rep 41,186
If you have USB .bin file as your Aftermarket CarPlay solution, then use 18-03, otherwise you can flash with latest.
06-14-2022, 08:34 AM | #91 |
Rep 59
06-14-2022, 08:36 AM | #92 |
Rep 41,186
I-Step 18-03, which is 4.10.20 psdzdata.
06-14-2022, 08:41 AM | #94 |
Rep 41,186
No, sorry, I do not keep old versions.
06-14-2022, 08:55 AM | #96 |
Rep 41,186
You can, although you will not be able to reinstall your USB .bin CarPlay solution.
06-16-2022, 05:37 PM | #97 | |
Rep 1,353
CARPLAY_SWT = aktiv WLAN_DIAGNOSE = aktiv WLAN_STATUS = aktiv WLAN_WIFI_DIRECT = aktiv ENT_MIRACAST = aktiv ENT_MIRACAST_DISPLAY_SETTINGS = aktiv ENT_MC_WLAN_STREAM_DMP_COVERART = aktiv ENT_MC_WLAN_STREAM_DMP_VIDEO = aktiv If your vehicle has Carplay option on VO, you shouldnt code this parameters. Just the carplay full screen and apps. Check your VO if carplay optioned you should have 6CP. If not add the 6CP, VO code then FDL code CARPLAY_SWT = aktiv As a note If your HU had FSC Pack with after market option, that needs to be repatched as far as i know.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
Alexey Brui5.00 |
06-18-2022, 03:38 PM | #98 | |
Rep 6
Maybe you are right and I had after market option. How could I update it? Should I reapply a new FSC code? Last edited by Alexey Brui; 06-18-2022 at 03:39 PM.. Reason: typo |
06-21-2022, 05:39 AM | #99 |
Rep 9
06-21-2022, 05:45 AM | #100 |
Rep 41,186
Your Receive PM function is disabled. PM me when working.
4door440.00 |
06-21-2022, 05:49 AM | #101 |
Rep 9
Thank you for the extremely quick reply, unfortunately I think I have to wait 7 days for pm since I just made this account:/
06-21-2022, 03:27 PM | #102 | |
Rep 25
06-24-2022, 07:03 PM | #103 |
Rep 59
i would like to say thank you to this thread, i just flash my nbtevo_Hxxxx to nbtevo_Yxxx with full psdzdata (thank shawn to help me in pm) now i got fullscreen carplay
flashing time was 40min with no issue So i-step update F020-16-07-503 to F020-22-03-552 with : -esys 3.30.1 -v.4.35.42_PSdZData_Full -E-Sys_Launcher_PRO_v2.8.1_Build_155 -.EST token with 50 years. |
06-24-2022, 08:15 PM | #104 | |
Rep 41,186
06-29-2022, 12:39 PM | #105 |
Rep 25
Hello Shawn
I'm trying to update my NBT Evo I'm getting the below error. My NBT was replaced the HDD for another HDD with the same specification, could you help me? My BMW had an NBT_Hu, I retrofitted it to an NBT_Evo and activated it in my car, it works radio, bluetooth, etc., only doesn't work functions it needs the HDD like Navigation, Multimedia, etc. Log Read SVT before TAL execution started. TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] ExecutionID=2022/06/29-13:29:53.546 [] prepareTALExecution started [PROGRESS] [] prepareTALExecution finished [PROGRESS] [] prepareVehicleForFlash started [PROGRESS] [] prepareVehicleForFlash finished [PROGRESS] [] SVK-Ist does not match expected SGBMIDs for ecu ECUId:HU_NBT_0x63. Excpected (relevant process classes only): [hwel_00000df5-001_021_021], Actual (relevant process classes only): [hwel_000022e3-001_002_003], Missing SGBMID(s): [hwel_00000df5-001_021_021], Surplus SGBMID(s): [hwel_000022e3-001_002_003] [THROWABLE] [HU_NBT - 63] There was an error during TAL execution, please check the log files. [WARN] [HU_NBT - 63] - [Exception - HU_NBT - 63] SVK-Ist does not match expected SGBMIDs for ecu ECUId:HU_NBT_0x63. Excpected (relevant process classes only): [hwel_00000df5-001_021_021], Actual (relevant process classes only): [hwel_000022e3-001_002_003], Missing SGBMID(s): [hwel_00000df5-001_021_021], Surplus SGBMID(s): [hwel_000022e3-001_002_003] [HU_NBT - 63] installECUBL started [PROGRESS] [HU_NBT - 63] installECUBL finished [PROGRESS] [HU_NBT - 63] finalizeECUBLUpdate started [PROGRESS] [HU_NBT - 63] finalizeECUBLUpdate finished [PROGRESS] [] finalizeVehicleFlash started [PROGRESS] [] finalizeVehicleFlash finished [PROGRESS] [] prepareVehicleForCoding started [PROGRESS] [] prepareVehicleForCoding finished [PROGRESS] [] finalizeVehicleCoding started [PROGRESS] [] finalizeVehicleCoding finished [PROGRESS] [] finalizeTALExecution started [PROGRESS] [] finalizeTALExecution finished [PROGRESS] TAL execution finished [TAL_EXECUTION_FINISHED] TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "2min 44s". [C206] Read SVT after TAL execution started. Read SVT after TAL execution finished. |
06-29-2022, 01:47 PM | #106 | |
Rep 41,186
1) Use E-Sys Direct, no Launcher. 2) Use correct I-Step Shipment for svt_soll calculation. NBT HWEL in svt_soll should be Black, not Red / Blue.
06-30-2022, 12:31 PM | #107 |
Rep 25
Hello Shawn, I am not able to find an i-step Shipment so that the NBT HWEL in svt_soll should be Black. Is there any way to find out which is the correct i-step? I tried several different i-steps but they are all showing blue or red.
06-30-2022, 01:14 PM | #108 |
Rep 41,186
After you calculate KIS/SVT Target, check the box that says "HW-IDs from SVTactual" and then Save as SVT_soll, and see if ECU HWEL is Black, not Red/BLue.
06-30-2022, 01:54 PM | #109 |
Rep 25
It's still the same Red/Blue ... isn't it because I retrofitted to NBT_Evo? and my car is a 2013 and it didn't come with EVO from the factory?
06-30-2022, 02:15 PM | #110 |
Rep 41,186
It's Red/Blue becuas eit is retofitted and is not same I-Step Shipment as rest of car. But "HW-IDs from SVTactual" usually will turn HWEL black anyway.
