      08-04-2019, 09:54 PM   #749
lshiroda1
Drives: 2021 X5 M50i, 2023 M850 Conver
Anyone know the cost of replacing the battery in a 2017 F15 X5 xDrive35i at a dealer? I know dealer costs can vary, but does anyone have a roundabout figure?
      08-04-2019, 11:58 PM   #750
mrfochon
Drives: X5 F15 M package
The price of a battery
      08-08-2019, 04:53 PM   #751
ManImCool
Drives: F15 X5
Originally Posted by ManImCool View Post
Anyone have any ideas why my coasting feature stopped working? Nothing has changed; haven't coded anything in a long time. It's still checked in the menu options, attempting to use without cruise control, in eco pro, shifter to the right, etc. I used to use coasting all the time but now it won't work at all.
Per another thread, I tried resetting my tire sensors numerous times to no avail!
Originally Posted by InsipidMonkey View Post
Low battery charge? Try charging your battery fully and see if it works.
Hmm - you actually might be on to something - I installed a 12" subwoofer a few weeks ago which obviously draws more power than the car is used to, and I *think* the car stopped coasting in the same week or possibly the following week after the sub install.
Don't get any low voltage warnings or anything but definitely worth a shot!
Update: Bought a CTEK trickle charger, and the battery indeed was on the low end (I think only 2 lights out of 7/8 total lit up). Overnight and in the morning, I was fully charged and ready to go, so I took it for a ride, but sadly, coasting still doesn't work!!!
      08-08-2019, 05:51 PM   #752
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Those 2 lights are not indicating the charge level... They show the charging sequence... You better read the manual of the charger...
      08-09-2019, 04:06 AM   #753
ger0nim0
Drives: bmw 740xD 2013 F01
SOS Call System Failure
I've got this issue for a few weeks already.
I checked on the forums and it suggested that i might try to change the backup battery, but it was impossible for me to find it...
Can anyone help me to locate it?
Or maybe the MOST fiber optic ring connector which seems to be the reason of the fault in other cases...?
In my case everything it's working fine except the SOS call system...
Thank you!
      08-14-2019, 10:48 AM   #754
ManImCool
Drives: F15 X5
So I read the manual, retried charging with the CTEK in auto+recond mode; it got to the 3rd light within seconds, and took overnight to fill 7 lights, with the 7th green and the rest yellow.
Took it for a drive, still no coasting. Sigh.
      08-14-2019, 08:59 PM   #755
lshiroda1
Looks like I'm going to need to replace the pads and rotors on my '17 F15 xdrive35i. Any idea at what it'll cost me at a dealer? Non Msport btw
      08-16-2019, 01:07 PM   #756
A-4WD
Long Time Bimmer Fan
Drives: 2014 X5 35i
$1500+ CAD (I know you're in the US) and don't settle for cheaper pads. All you'll get is tonnes of brake dust. OEM ones are virtually dust-free...I had a BMW specialist try it for me but I ended up with OEMs in the end.
2014 X5 XDrive 35i - Current
2010 X5 XDrive 4.8iS - Traded
1990 325iS - Sold
1985 318i - RIP
      08-26-2019, 09:54 AM   #757
Bmwit
Drives: BMW X5 F15
Lines on Navigation screen
Has anyone ever seen this problem with the navigation screen? Any ideas on how to fix it? Thanks in advance.
      08-26-2019, 02:16 PM   #758
mudbug
Drives: Black
Hi, My car is out of guaranti in May next year. I heard some dunking noise in background when car is in ide. Is it normale engine nosie? Thanks
      08-30-2019, 03:27 PM   #759
Roman_H
Drives: BMW X5 50i (F15)M-Package
CEL+Engine Drivetrain Malfunction
51K Miles
CEL+Engine Drivetrain Malfunction resulting in rough idling and a significant loss of power. Codes: P00BC/$07E8+P0172. Also throwing codes: P0300+P0304+P0303+P0302 (Cylinder 1-4 Misfire. Any ideas/suggestions?
Note: I cleared the codes and the vehicles drives perfectly well for 3-4 miles then the engine light and drive train malfunction warning comes back and along with it the rough idle and loss of power
      09-02-2019, 06:28 PM   #760
RED_Y_
Drives: 2014 X5 3.5d
Originally Posted by Roman_H View Post
51K Miles
P00BC/$07E8 Circuit Range/Performance Flow Too Low and P0172 is System Too Rich point out to the MAF problem.I would guess this the the root cause which is causing the misfires. Replace MAF.
      09-04-2019, 07:54 AM   #761
mpowered5
mpowered5's Avatar
433
Drives: E34 M5
Anyone have their pinion seal go?
Front of the rear diff where the driveshaft meets?
2015 X5 35d M sport
2017 340i M sport
1991 M5
1988 M5
      09-08-2019, 12:20 PM   #762
captain-slap-a-ho
Drives: X5 30D
Smile F15 Sat Nav update not working or asking for FSC code? Please help!
Hi All, yes another Sat Nav question . I currently have an F15 X5 and want to update to the latest Sat Nav version for Europe. I've downloaded Road Map Europe Next 2019-1 and have unpacked it using winrar. Currently I'm running 2014 NEXT.
When I plug my USB (from the centre console - no usb point in glove box - 64GB USB) it asks if I want to update which I click yes then nothing seems to happen. It doesn't ask for an FSC code (which I have) and I can't see an update status bar or anything? I've left it for over an hour whilst driving and still not updated.
Any ideas would be much appreciated and I've attached some pics
Many thanks
      09-09-2019, 08:12 AM   #763
Bottled
Czech_Republic
Having the same issue after 120K km.
Just gave it to indy shop to replace all 3 shaft seals.
First problem so far.
What is your mileage as its kinda rusty per the picture
      09-09-2019, 08:49 AM   #764
ComasF15
Drives: Silver
~$500
FWIW Batteries Plus does it for~$300 and they can register the new battery. I had this done on my 2015.
      09-10-2019, 11:14 PM   #765
GasGiant
Drives: F15 X35i 2014
Yes, on a 2014 with exactly 80,000 miles. Fix it ASAP before you need to replace the rear differential! My indy guy charged me USD $500.
      09-11-2019, 04:04 AM   #766
mpowered5
mpowered5's Avatar
433
Drives: E34 M5
Attachment 2138189
Has only 65,000km on it. Canadian winters take their toll
2015 X5 35d M sport
2017 340i M sport
1991 M5
1988 M5
      09-15-2019, 07:47 PM   #767
Kanuc
Drives: 2013 X6M Melbourne Red
Brake shuddering
Hi. 2016 X5 35d, 70000km, new tires.
When I go down a long steep hill, car pretty full of ppl and cargo, gradually I start to get shuddering in the car. Not through brake pedal, instead whole car just shakes. This occurred on a hot day. This did not recur on a similar incline on a cool day during rain.
Dealer checked out brake condition visually. pads look close to new, rotors look good. However, service computer shows front and rear brake job due in <5000km.
Dealer checked wheel alignment, looks good.
Dealer came up empty.
If this is not uncommon, there must be a service bulletin, but dealer said none exists.
      09-17-2019, 05:47 AM   #768
travellingkiwi
Drives: f15 e87 fireblade
Shuddering while using the brakes? Or shuddering when engine braking?
      09-26-2019, 10:08 AM   #769
Billy416
Drives: 2014 BMW X5 5.0i
Hello everyone,
First time posting here but I have an issue that I can't figure out.
Car 2014 X5 5.0i with 140KM/ 86K miles
When I drive the car I hear a very high pitch sound coming from the engine, and sometimes when I park it a dn run in the store I hear it as well.
      09-28-2019, 11:15 AM   #770
luftika7
Drives: bmw X5
will these wheels fit my 2015 X5
I am not sure if they are OEM X5 wheels or from something else and will they fit on 2015 X5
Search this Thread:
Advanced Search
