04-13-2020, 12:08 PM | #1 |
Rep 243
Ambient Lighting Replacement - Dashboard
So the ambient lighting strip on the dash is dim and was told by the dealer they will need to replace it...at a cost of $1245!!!
Does anyone have experience with this? I might ****in do it myself or somethin if possible |
04-13-2020, 12:36 PM | #2 |
1644
Rep 2,995
Well if it's like the door panel lights, the strip is like a fiber optic (plastic rod) with an led bulb at the end to light it up.
Just need to find the bulb. Perhaps it moved away from the plastic strip a bit, since you say it's dim. |
Carpe_BM185.50 |
04-13-2020, 01:13 PM | #3 |
Rep 243
Going to have a local Euro shop look at it as well but will inquire if this is the case with needing a quick re-alignment to purpose the led bulb
06-05-2020, 06:41 AM | #4 |
658
Rep 345
Just wondering what happened , my ambient lighting is also dimming, hoping its a bulb and an easy fix i can do myself.
11-13-2020, 04:29 PM | #6 |
BMWfreak
Rep 12
Hi,
do you have "new" informations baout the issue? My stripes are also "dimmed"....i think they should be brighter than they currently are. Setting in Headunit is on max. From beginning to the the end they are loosing brightness and Iīve recognized kind of stains...before and after this point it is brighter... Last edited by NeRkO20; 11-13-2020 at 04:49 PM.. |
11-13-2020, 05:39 PM | #7 | |
1644
Rep 2,995
11-14-2020, 07:32 AM | #9 |
1644
Rep 2,995
11-18-2020, 01:08 PM | #15 |
BMWfreak
Rep 12
Iīve ordered in a onlineshop, it is an offical BMW dealer. But i am from europe, I donīt know if there is something similar in US.
Change: you have to disassamble a couple of things...depending on which bulb you want to replace Update regarding my issue: changed bulb in dashboard and nothing changed...so I expect my issue in the door panels is not a damaged bulb... |
pennsiveguy3552.00 |
11-25-2020, 10:44 AM | #16 | |
Rep 3
11-25-2020, 11:17 AM | #17 |
BMWfreak
Rep 12
An idea how to fix it? A new fibre optic is not an option as you can not buy it separately. It comes with the complete door panel. I mean only the one on top...the other two are available separately
