      03-17-2021, 11:15 AM   #1101
bosstones
Drives: o_0
Originally Posted by nyalpine90 View Post
how difficult is replacing sprinkler head?
landscapers are next door, will be getting estimate from them.
my lawn needs help,
In-ground, pop-up sprinkler head? Haven't done it myself (yet) but doesn't look too bad. Lots of YouTube videos on it. Dig, remove, extract, insert, adjust, replace dirt/grass.
      03-17-2021, 11:19 AM   #1102
TXSTYLE
"Salud"
TXSTYLE's Avatar
Drives: F01 & F15 / Mineral White
Lightbulb
My latest project... Avocado! ��
So this is something I've been interested in trying for years! I recently opened a rather large fruit and the seed was already cracked and sprouting! Which if you've read up on these, that's one of the most difficult tasks. So I decided to clean it off and Transplant it into a starter pot. I already know it may never yield Fruit. But it still makes for a really nice Houseplant. ���� Stay tuned...
      03-17-2021, 11:27 AM   #1103
TXSTYLE
"Salud"
TXSTYLE's Avatar
Thumbs up
My very first Redbud that I planted last Summer (which was already bad timing) also survived that Antarctic Blast and is now budding and doing lovely. 🤗
Appreciate 5
nyalpine907444.00
RickFLM411002.50
wrickem2124.50
      03-17-2021, 01:35 PM   #1104
nyalpine90
nyalpine90's Avatar
7444
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
not sure what i have
i do know is that i have to replace few, when the inspector turned on sprinkler system. Few heads didnt pop up, more like low pressure fountain lol
      03-17-2021, 02:04 PM   #1105
UncleWede
UncleWede's Avatar
Drives: G01 X3 M40i Dark Graphite
Sprouting is the easy part. When you try to transplant, and hope the roots don't die off, now THAT is tough. I think it took me literally a dozen trees, of varying degrees of maturity, before I got one to reach the point of actually producing fruit. I'd go out, notice suddenly all the leaves were gone on a tree, and with a slight pull on the trunk the whole tree came out of the ground.
The trick, I learned from a local with a bunch of fruit-producing trees, was a rusty nail driven into the trunk.
      03-17-2021, 04:32 PM   #1106
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
You might just be missing nozzles or a head is stuck under the grass. Look for pooling where heads may be stuck. If one is up try steping on it rapidly, this spikes pressure along the line.
If a head is broken but not at the base it will just unscrew, very easy takes me 3 mins to do an entire swap out. If the head is over 6 inches tall it may be side entry which isn't as easy. In that case dig the head up and around it to allow the head to be able to come completely out of the ground. Be very careful not to pull too hard or you'll break the swing fitting. Then spin off and the new one back on. Hardest part for homeowners is adjusting the head afterwards.
Or the easiest step is just call an irrigation contractor. I charge between $46-58 per head replaced, labor and parts plus service call of between $45 and $90. If a lot of heads need replaced I waive the service call. Just so you know what it may cost.
nyalpine907444.00
      03-17-2021, 05:20 PM   #1107
TXSTYLE
"Salud"
TXSTYLE's Avatar
That last sentence...
But I've read up plenty and we'll see. The thing is, the chances of it actually producing fruit is slim to none.
I'm doing it more for a nice attractive Houseplant.
      03-18-2021, 08:53 AM   #1108
nyalpine90
nyalpine90's Avatar
7444
2016 BMW X4  [9.33]
good to know. looking to upgrade the heads and sprinkler box with valves.
one estimate came back $3500 new heads, lines and valves. (verbal)
no idea how much piping is involve, how much valves and heads are.
i walked away
      03-18-2021, 11:05 AM   #1109
Our03z4
i walked away
Lines shouldn't need to be replaced. We do system renovations as well and I've never seen one needing that as long as it's pvc or poly. I charge $250 per valve replaced. $3500 sounds like it could be reasonable depending on system size, types and number of heads plus quantity of valves. Takes about one day to do. I had to replace all valves at a house last year. Took 7 hours, cost $2,300, replaced 7 heads and 7 valves. I don't recommend replacing valves yourself. You could do the heads which would save you some money and just pay them do the head adjustments and valves.
nyalpine907444.00
      03-21-2021, 12:35 AM   #1110
bosstones
Drives: o_0
I trimmed back around 60 tallgrasses and 12-ish carex today. I bought a pair of grass scissors for that. The deed is done but, damn, factory sharp isn't on par w/ how sharp I like to keep edged tools. I might look into a sickle or a scythe for next year. lol
      03-23-2021, 04:30 PM   #1111
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
it's been known bro that if you put rusty nails in the dirt the acidity goes up. so if i want my hydrangeas to turn blue instead of buying acidity amendments i can throw some rusty nails in the soil
on that note i can't even put my pre emergent down because were suppose to get several days of rain and if i put the pre emergent down it could wash away
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      03-23-2021, 05:45 PM   #1112
TXSTYLE
"Salud"
TXSTYLE's Avatar
Ordered this for my Garden...
UncleWede18175.50
      03-24-2021, 03:42 PM   #1113
lsturbointeg
just spent the afternoon taking the lawn down to 2" to get rid of the dead grass. used my lawn sweeper to pick everything up. if it doesn't rain tomorrow i'm gonna dethatch the lawn. suppose to rain the next day so i'll wait before i aerate than throw down my pre emergent. Springs is so close but knock on wood i'm expecting at least one more snow dump on us
      03-24-2021, 08:17 PM   #1114
roastbeef
roastbeef's Avatar
Drives: E92 M3
Patchy grass vibes.
Instagram; @roastbeefmike
bosstones1191.50
      03-25-2021, 04:13 PM   #1115
lsturbointeg
worked on dethatching the lawn. kids weren't too excited about this because it's yard work lol!
all done!
Nikko Blue Hydrangeas are starting to bud out! looks like they survived the winter
my tulips are also starting to take off!
nyalpine907444.00
bosstones1191.50
AmuroRay2379.00
      03-26-2021, 09:26 AM   #1116
UncleWede
UncleWede's Avatar
OH CPS contacted. Please confirm your address.
bosstones1191.50
      03-26-2021, 01:30 PM   #1117
TXSTYLE
"Salud"
TXSTYLE's Avatar
Smile
Compare the pic I posted above just 9 days ago to today. My Redbud is exploding with Blooms!
Appreciate 4
nyalpine907444.00
RickFLM411002.50
AmuroRay2379.00
      03-26-2021, 04:40 PM   #1118
lsturbointeg
got the aeration done yea!!!! waiting for better weather to do some Spring pruning
      03-27-2021, 01:13 PM   #1119
UncleWede
UncleWede's Avatar
There may be guacamole in my future again
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
TXSTYLE14036.50
      03-27-2021, 06:08 PM   #1120
TXSTYLE
"Salud"
TXSTYLE's Avatar
Nice! We had a Giant Avacado tree in our back yard growing up in So Cal. We are Guacamole on a regular!
      03-28-2021, 10:10 AM   #1121
jsf721
Drives: 2019 540i X M Sport
Our03Z4 quick question.
I have a landscaper who handles the whole years but I still do so small projects and check some stuff. For example if I see a brown spot I’ll add some tine to that zone. I’m thinking about installing a Ratchio sprinkler clock so I can change setting on my phone. It should make it easy to check heads and coverage without running back to the clock.
Any suggestions ?
      03-29-2021, 06:07 PM   #1122
Our03z4
Any suggestions ?
Personally I prefer the Hunter Hydrawise, it's actually the only controller we install currently. I'm actually a certified Rachio installer but only install them if forced. For a contractor the Hydrawise is the best choice for numerous reasons, easy install and also has a color touch screen for if you don't have a phone handy. Plus their tech support is US based and the best in the industry. RainBird has tried to get with the times but their controller is a joke compared to others.
All in all if it will just be you using the controller the Rachio will be fine, but if you have a contractor that ever needs access then you're better off with the Hydrawise. I honestly don't understand the draw for everyone wanting the Rachio.
