05-11-2024, 02:41 PM | #199 | |
Rep 2,558
To be fair, my factory bolt was bent some as an image in my OP shows, but agreed that I was pleasantly surprised it wasn't worse given the reports from others and my number of trips to the Strip. As I've also taken my wife's X3MC to the Strip a few times with about 10 or so launches, I'm thinking about ordering an OEM bolt and nut from the Dealer and having them just replace those on hers (leaving the bushing alone) - 33326775040 Hex bolt with washer, 33326760380 Combination nut. Knowing my front bushings and bolts were fine I'm not concerned about those on hers. Will be interesting to see what they quote for the labor since both of ours don't have the vertical bracing as we don't have a pano, so it should be a quick and easy process. |
Jnat439.50 Kevin_The_Clean13436.50 |
05-14-2024, 02:37 PM | #200 | |
Rep 55
Drives: 2023 BMW X3M Comp
Kevin_The_Clean13436.50 Jnat439.50 |
05-15-2024, 07:33 AM | #201 | |
Rep 1,144
WTF, thats obv the "dont want the job" rate. I just hope none of the few ones I have around here dont pull the same crap. Ugh Last edited by TacosRule!; 05-17-2024 at 09:19 AM.. |
05-15-2024, 08:01 AM | #202 | |
339
Rep 321
Drives: 2014 STI - 2020 X3MC
Wow. |
05-16-2024, 09:58 PM | #203 |
Rep 55
I mean, if you go religiously by the instructions, it's a ton of work. Drop the brace under the exhaust, drop the exhaust, drop the diff, and reverse all that. They thought their press tool might not have enough room so they said they might have to drop the rear subframe too, that's what they thought might cause it to reach $2k. Ehh. In the end, I have to agree that this is the most extreme solution and it's probably only applicable to the most extreme drivers -- dedicated racers who don't blink at these type of costs to prep an M and/or do their own work.
05-17-2024, 05:34 PM | #204 |
Rep 2,558
For spatial reference here is how my 2020 X3MC (top) and my wife's 2022 X3MC (bottom) rear diff bolts appear on images taken directly behind and midway underneath the bumper, both sans pano. I just leaned down and reached underneath with the iPhone.
5
05-19-2024, 12:37 AM | #205 | |
Rep 4,057
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
Max Well4814.50 |
05-22-2024, 02:45 PM | #206 |
Rep 2,558
Received the new OEM bolt and combination nut yesterday which we'll eventually use for my wife's X3MC. Comparing to the Sep 2019 versions which I had replaced in Feb, it appears the bolts are identical. The only difference I can see is the combination nut which has a different size and shape, which is maybe the 're-design' discussed earlier?
Not in a rush to change hers out, but it'll be interesting to see if its bent if/when we do, given it's only had 10 launches over two Strip outings... |
4
05-22-2024, 02:53 PM | #207 | |
Rep 1,144
Interesting finds. Thanks for sharing. |
Max Well4814.50 |
05-24-2024, 12:53 AM | #208 |
Rep 4,057
That looks like a slightly strong nut. That bolt (like you said) appears identical in all dimensions. Wonder if the new revised nut will improve things. With 40 or so launches on your X3 M & many of those at the strip, still surprised your was bent more
05-24-2024, 12:54 AM | #209 | |
Rep 4,057
Max Well4814.50 |
