04-10-2023, 04:49 AM | #287 |
Rep 13
I Have the same error.You mean"delete other ECUs".How can i delete other ECUs or Where other ECUs Delete from?Thanks.
[/img][/url] Last edited by sboz; 04-10-2023 at 04:56 AM.. Reason: Photo. |
04-11-2023, 08:36 AM | #288 |
Rep 3,070
EDIT TAL
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
04-22-2023, 10:58 AM | #290 |
Rep 170
Quick question…any value in updating the other non-DME ECUs? I don’t think my car (2nd owner) istep was ever updated.
I’m 26% into flashing nbt, fwiw. EDIT: Success! |
05-03-2023, 02:38 PM | #291 |
Rep 418
Can anyone advise if this fault in HU module will cause any issues if I flash HU to update NBTevo?
It’s the only fault that returns if I delete fault memory.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
05-08-2023, 02:02 AM | #293 |
Rep 418
SaNGRia Great guide!
Used Esys 3.40.2 & PSdZData 4.41.10 with ENET cable. Now on NBTevo_Y shawnsheridan Big thanks for the download.
SaNGRia996.50 |
06-17-2023, 04:10 PM | #295 |
Rep 562
Can I do this if the nbt is retrofitted in ESeries and only thing I have is ENET working with hand built VA/FO file. I can code NBT, but no other modules are visible in eSYS. ISTA doesn't seem to work. But maybe I need something to set it up?
06-17-2023, 05:01 PM | #296 |
Rep 41,221
If you are talking NBT2 EVO (not NBT as you wrote) Coding NBT is done via CAN Bus, so possible with ENET Cable, but Flash requires Ethernet, so flash can only work if Ethernet was repinned from Quadlock to OABR, and that assumes a late model E-Series as early E-Series did not have Ethernet on Quadlock.
06-18-2023, 09:04 AM | #297 | |
Rep 562
06-18-2023, 10:23 AM | #298 | |
Rep 41,221
06-18-2023, 09:11 PM | #299 |
Rep 562
Thanks Shawn, I got this far but it says I have missing files. I don't know the shipment istep from this 2019, so I picked 2018 as a random shipment istep. Could that be the issue?
06-18-2023, 10:25 PM | #300 | |
Rep 41,221
So after you calculate SVT Target (SVT_soll), check the box that says "HW-IDs from SVTactual" and then Save it. If HWEL is Black only, no Red / Blue HWEL, then you can proceed to flash it. As for Missing SWEs, you need PSdZData Full, not Lite.
06-20-2023, 06:30 PM | #301 | |
Rep 562
Should I turn off HTTP transfers? If so, how long will a NBT2 flash take? Do I need a crazy strong battery tender? I only have 1.5A trickle charger and I'm on a lithium battery so it will last a while this way, but maybe not overnight. |
06-20-2023, 07:13 PM | #302 | |
Rep 41,221
The-Traveler139.00 |
06-24-2023, 10:47 AM | #303 |
Rep 562
I did it all again and instead of red and blue, it's all blue now. What does that mean? Also, this time around check software version doesn't complain about missing files even though I haven't added the full pzdData.
06-24-2023, 10:50 AM | #304 |
Rep 41,221
Blue is actual state. You need to calculate svt_soll to see Target state and any firmware file updates.
06-24-2023, 12:39 PM | #305 | |
Rep 562
Then I click calculate and I get red and blue, then I click HW-IDs from SVTactual but nothing changes in the colours. |
06-24-2023, 12:40 PM | #306 | |
Rep 41,221
06-24-2023, 02:00 PM | #307 | |
Rep 562
06-24-2023, 02:38 PM | #308 |
Rep 41,221
Yes. Flash it if you want.
