      08-05-2019, 04:16 PM   #23
-c-
-c-'s Avatar
Drives: bmw
Originally Posted by Florida-X5 View Post
B&O has always been about over the top modern styling. From an audio quality perspective, I would take B&W over B&O any day, I'm fine with the HK .... it's a vehicle, hardly audiophile listen conditions.
So true ! I have B&W in my house as well as my headphones.
Love em!
      08-05-2019, 07:03 PM   #24
Florida-X3
Drives: '24 X3 x30i / '12 Infiniti M37
Love em!
Yes, the house we recently bought, the original owner was downsizing so he offered me a pair 903's, center and sub at a steal as well left in three B&W ceiling mounts in the rear for a 6.1 set-up and a pair of B&W ceiling mounts in the Lanai! Was a Wharfedal fan before my introduction to B&W! (sorry to get side tracked folks, back to your regularly scheduled program)
mrfochon211.00
      08-06-2019, 05:01 PM   #25
fbuzila
Drives: 2023 BMW XM
Following this, I'm curios about how hard is to mount it and if it really works
      08-07-2019, 05:32 PM   #26
eldogo
eldogo's Avatar
Tanzania
275
Drives: BMW 328xi BMW X5 F15 BMW M2
2017 BMW M2  [0.00]
+1
      08-12-2019, 05:55 PM   #27
-c-
-c-'s Avatar
Drives: bmw
Updated with pics !
Came in today. Now just need to install it.
First impressions are wow, their getting good.
Overall quality looks like it should.
Not sure if you could really spot the fake. The wiring is all their for the installation and even down to the foam on the inside of the speaker cover they got it all their.
Not bad for a couple hundred bucks. Now just need to install it.
fbuzila367.00
      08-12-2019, 06:50 PM   #28
Muzza
Drives: X5 F15 x50
If you get the original b&o upgrade, is it just that speaker or do all the speakers in the car get the b&o treatment and logos?
5HOUT28.50
      08-12-2019, 07:11 PM   #29
-c-
-c-'s Avatar
Drives: bmw
All the speakers and amp and programming.
You can buy this speaker without the logo, also if you plan on upgrading the speakers you can possibly upgrade the speakers in this unit.
I'm thinking the design of the unit is part of the magic as it fires sound differently than the fixed stock one.
Either way if you want your HK system buy the center channel without the text and it will look like a trick HK system setup if you upgrade your speakers to bavsound and recode the system to B&O then it will be a little better possibly.
Some people want the nice aluminum covers vs the black ones but the center channel was always the tuff sell as you needed the amp to make it work. And they didn't want to tear apart the whole truck to run the amp wires.
This is just another option to play with.
Muzza55.50
      08-13-2019, 02:57 PM   #30
CatalinP
Drives: BMW X5 F15 2014 3.0xd
Can you please share the wiring diagram for installation?
I'm just curious where does the lifting mechanism connect to.
Thanks.
      08-13-2019, 03:37 PM   #31
menelaos
menelaos's Avatar
1226
Drives: 2015 BMW X5 F15
Thanks.
Had this on my radar for quite some time now, but not sure how to power it. Thus I hesitated pulling the trigger. Did not want to power it via the cigarette lighter.
Both Red and Black (ground) wires are provided, but you have to run it to the front fuse box and find an empty slot.
      08-13-2019, 03:52 PM   #32
-c-
-c-'s Avatar
Drives: bmw
They give you multiple options, you can hook it into the fuses and you can also piggy back off the head-unit itself,
Theirs only 7 wires
One is power and ground and ACC
The other 4 are speaker wires to connect to the stock system.
Also if you have the B&O amp you can power it that way as well and the led. It's literally a one to one copy.
The led is powered either through the block connector they supply or if you use the B&O amp to power it.
I'll have a write up as soon as I connect it up.
      08-13-2019, 04:39 PM   #33
CatalinP
Connecting it to the fuse box will not give the desired effect I guess - raise upon turning on the audio and go in when you stop it...
Can you please post the diagrams whenever possible...
      08-13-2019, 05:07 PM   #34
-c-
-c-'s Avatar
Drives: bmw
Right the fuse box connection is if you add in a relay so it goes up and down when you turn off and on the stereo. Or use the OEM amp.
The other route just connects to the back of the idrive system quad lock connector. Everything you need is their so that's what they connect to.
The easy way will have it turn up when the car turns on and lowers when you shut it off.
      08-13-2019, 05:54 PM   #35
CatalinP
It should be powered by the same wire on the back of the HU, the one that powers the amplifier in the trunk.
Your car has HK, right? Do you still need to cut through the dashboard for the new speaker enclosure to fit?
      08-13-2019, 07:45 PM   #36
-c-
-c-'s Avatar
Drives: bmw
Hey! Yea I have HK, and yea you still need to cut the dash for fitment.
And correct gonna wire it all from the quad lock connector.
Excited to get this little guy in!
Nothing looks to be a biggie. But we know how that goes
      08-24-2019, 08:51 PM   #37
-c-
-c-'s Avatar
Drives: bmw
Updated with installed pics and installation time.
CatalinP591.00
      08-24-2019, 08:54 PM   #38
turboawd
1644
Drives: 2015 X5 35i
So how did you wire it to go up?
      08-24-2019, 09:11 PM   #39
-c-
-c-'s Avatar
Drives: bmw
When you turn the car on the unit powers up and it goes on with the ignition. When I power the car off it powers down and the unit falls.
If I'm sitting in the parking lot and keep the car off and just hit the volume knob and turn the stereo on it stays lowered but the speakers work. So more like standard HK setup.
CatalinP591.00
      08-24-2019, 09:27 PM   #40
volc
Drives: X5 F15 '14 M50D
How sound quality has changed after installing this speaker? Is it better? Have you also noticed any improvement on sound stage perception?
eldogo275.00
      08-24-2019, 11:53 PM   #41
Silververtu
Silververtu's Avatar
231
Drives: 2015 X5 50i M Sport
Thanks for the write up! Can you further explain what do you need to cut on the dash? And do you have leather dash?
2019 Cayenne Turbo
Gone but not forgotten:
2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport
      08-25-2019, 12:46 AM   #42
-c-
-c-'s Avatar
Drives: bmw
I know it's not worse, It takes some hrs for speakers to break in and I'm no audiophile but I'd bet that a lot of R&D went into the design on B&O side of things and I'm sure it has an effect overall, bouncing off the windshield angle and the tweeter design firing at you vs up, once I code the idrive to B&O theirs some options that will possibly take advantage of the design even more have no idea.
Just wanted to let you all know theirs a cheap quality looking alternative to having the active center speaker without having to spend thousands and have to retrofit anything.
I wasn't expecting anything and not sure how to quantify such a change but it still sounds great and if anything the voices seem a little clearer than before if that makes sense.
All I know is I love having it and it looks great!
Russmov1328.00
      08-25-2019, 12:52 AM   #43
-c-
-c-'s Avatar
Drives: bmw
Sure when you remove the tweeter and mid driver their are two holes where they used to be and you must open them up, you must open it up to accept the full unit so instead of two circles you need to make a square / rectangle and theirs 4 holes in the top where this unit plugs into and rests.
Mines not a leather dash but you only need to trim the plastic bit of the ip. It's a fairly simple trim.
      08-25-2019, 06:47 AM   #44
Silververtu
231
Thanks! Now I know what you mean, to trim the speaker mounts from "previous" speaker to drop the B&O unit in.
2019 Cayenne Turbo
mrfochon211.00
