      11-01-2021, 09:29 AM   #23
Clifton
Clifton's Avatar
Drives: Cars with tires
Originally Posted by Andy_Kay View Post
how about wrapping it with some wire to hold it in shape - so it can stay in that candy cane shape. I think I'll give that a go and report back
You may be on to something. One thought I had was feeding a wire coat hanger into the plastic flexible tubing. Then form a candy cane shape before inserting into the fill hole. That would help to add and maintain the hook shape and would not impede the flow of oil during the extraction.
Regards,
Clifton
      11-01-2021, 09:29 AM   #24
Chilled
Chilled's Avatar
Australia
532
Drives: F85 X5M
Andy_Kay
I've got some pic inside the TC, hope this helps.
https://f15.bimmerpost.com/forums/sh...&postcount=161
You would have to find a way to snake the pipe back away from the fill plug towards the other side.
Clifton303.00
      11-01-2021, 09:34 AM   #25
scotty339
Drives: 2015 BMW X5 x35i M-Sport
I used this pump with a 8 in piece of brake line, bent into a candy can shape. Insert the brake line into the end of the tube and it works perfectly.
Performance Tool W54173 200cc Extraction & Fill Pump
      11-19-2021, 02:25 PM   #26
M302_imola
M302_imola's Avatar
851
Drives: '15 X5 35i Xdrive Mineral Whit
Ordered new cabin air filters, front and rear diff fluid w/ new drain/fill bolts, and Transfer case fluid from FCP Auto. It just arrived and I realized I'm an idiot and didn't order a new replacement drain/fill plug for the transfer case. Is it a huge deal to reuse the stock plug? I hate to postpone my service another week while I wait for the new plug, but will if necessary. What you guys think?
      11-20-2021, 03:44 PM   #27
Clifton
Clifton's Avatar
I don’t think it will hurt. You *might* get some weep, but if you order the fill plug and then swap out later, I’m not sure I’d worry. The plug can be swapped pretty quickly if you have correct tool.
      11-20-2021, 09:31 PM   #28
Chilled
Chilled's Avatar
Australia
532
Drives: F85 X5M
The diff and TC plugs are all identical. Put the new plug into the TC and re-use the fill plug on the rear diff. It easier to get to the rear diff fill plugs then the TC, imho.
BTW, don't forget. If you are dropping the reinforcement plate for the front diff. That plate needs new bolts.
      11-21-2021, 06:55 PM   #29
M302_imola
M302_imola's Avatar
851
Good deal, I wasn't sure if they were the same. I've found a few drops of fluid towards the rear of the vehicle on the garage floor lately. Not sure if it's from the TC or rear diff. With that being said I'll prob use the 2 new plugs on the TC and rear diff and reused plug on the front diff. I won't be dropping the reinforcement plate. Appreciate the insight.
      11-22-2021, 08:01 PM   #30
Chilled
Chilled's Avatar
Australia
532
Drives: F85 X5M
The Front diff seems to be the hardest to get to and diagnose leaks. I would say put new plugs in that. If the TC is leaking that would be inline with the center of the front doors.
Please let me know how you manage to do the Front Diff without dropping the reinforcement place. All guides and people doing it, seem to have done it.
I am yet to attempt it as I haven't bothered to buy the bolts for it.
      11-22-2021, 11:52 PM   #31
M302_imola
M302_imola's Avatar
851
I thought the TC was a bit more toward the rear of the car. So going off what you're saying it must be my rear diff that has the slight leak. I'll investigate more. I'm having a local shop do the front & rear diff and TC fluid change. I'll recalibrate the TC using ISTA software. You referenced the reinforcement plate and I misunderstood. My mind went to the subframe that's a tight squeeze between the TC. So you have to replace the bolts on the reinforcement plate? I def didn't purchase new ones
      11-23-2021, 02:44 AM   #32
Chilled
Chilled's Avatar
Australia
532
Drives: F85 X5M
The TC is directly behind the gearbox somewhere near the middle of the front doors. It can be done without loosening/removing the crossmember if you have short sockets/allen keys, or Tite-Reach extension(or the Strap-On version), or do some custom tooling and cut some sockets (me).
Tite-reach
https://tite-reach.com/products/3-8-...tension-wrench
My TC Post (just FYI, this thread has talks on oil types. Most do not correlate to a F15/F16)
https://f15.bimmerpost.com/forums/sh...2#post28214462
The front reinforcement plat is the silver plat that is under the engine sump. The thing you poke your hand through the get oil filter.
Has a nice view of it missing and the guy pointing at the front diff, in 5th pic
https://f15.bimmerpost.com/forums/sh....php?t=1874581
33306772888
https://www.realoem.com/bmw/enUS/sho...diagId=31_1173
      11-23-2021, 02:26 PM   #33
M302_imola
M302_imola's Avatar
851
Tite-reach
33306772888
So pertaining to the bold up above. Does the front diff have both a drain and fill plug in the f15? Not sure if it's any different in F85?
      11-23-2021, 06:19 PM   #34
Chilled
Chilled's Avatar
Australia
532
Drives: F85 X5M
Yep, your front diff will have a drain and a fill plug.
      12-06-2021, 12:26 PM   #35
JamesInSJ
Drives: E46 M3
Originally Posted by JamesInSJ View Post
As long as I can get this 14mm socket up in there, looks like this will work great.
Start with open end 14mm, hex is fully inserted with 1-2mm to spare. Break it loose. Then insert the 14mm hex through the 14mm ratcheting end (still 80-90% of the way in), and back the bolt out until you can just use your fingers to remove it.
Would like to report that this approach worked perfectly, using these tools that many of us already have. It was easy to navigate the socket + wrench into the space, and I used a small screwdriver pressed against the back of the socket to help get it in place. Once I put a little pressure on it, it held in place for me to give it a few whacks with the mallet to break it loose. Used fingers to remove it the rest of the way.
      12-06-2021, 04:58 PM   #36
M302_imola
M302_imola's Avatar
851
FYI, FCP Euro just did a DIY on the front diff. Dropped the reinforcement plate and didn't appear to replaced the bolts.
      12-07-2021, 08:53 PM   #37
Chilled
Chilled's Avatar
Australia
532
Drives: F85 X5M
No idea. He did do them up as stretch bolts tho. Maybe just an oversight?
      12-08-2021, 05:12 PM   #38
M302_imola
M302_imola's Avatar
851
Could be, just bringing it to your attention since your post above.
      12-08-2021, 05:32 PM   #39
Tomcat_F15_STL
Tomcat_F15_STL's Avatar
181
Drives: BMW F15 & E70
I only do 45deg as a final rotation - works for me. Manual says replace them. There's no way I am gonna pop for new bolts every time that stiffener comes off the vehicle! Most of us do not print money.
Cbozz746.50
      12-08-2021, 08:22 PM   #40
M302_imola
M302_imola's Avatar
851
I thought a full 90 def after was a little much. Appreciate the reply.
      12-09-2021, 03:03 PM   #41
crystalworks
crystalworks's Avatar
540
Drives: Many BMW's
I do the same thing with the reinforcement plate bolts on my E53. Had it on and off at least 10 times now. Will take the same approach to the F15 when I do the front/rear diff fluids.
      12-30-2021, 08:21 PM   #42
jluzbet
jluzbet's Avatar
Drives: F10 535, F15 X5, E93 335
at 110K, never changed it would it be a bad idea?
      01-02-2022, 01:40 AM   #43
Chilled
Chilled's Avatar
Australia
532
Drives: F85 X5M
I would say that changing oil that late in something that has clutch packs could cause issues. There is probably a bit of clutch material in the oil now that allows it to actuate, and engage.
If you remove this material, you may find that it starts to struggle with engagement of the front wheels to the amount it needs.
Not saying you shouldn't do it, but just full disclosure and be aware. Yes not doing the change, would probably be a worse choice.
      01-02-2022, 02:42 AM   #44
crystalworks
540
Drives: Many BMW's
I'd change it. And have on other xdrive bimmers with higher mileage. Just my .02 though.
