M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding
      11-17-2016, 06:51 PM   #23
makscheban
Drives: 2014 BMW 535i
Originally Posted by Almaretto View Post
Linked in Post #12
Tried today and no luck. Is programming and flushing the same thing?
I was told since I used a brand new TMS module, it needs to be programmed and initialized and I won't be able to do it through ESYS. Is that true?
Does anyone know anybody who can do it remotely?
      11-17-2016, 07:29 PM   #24
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Programming = Flashing = Updating ECU firmware/ software
Coding/Encoding = configuring ECU settings or parameters.
ISTA-P or ISTA+ will usually only allow the use of new ECU's. ISTA+ is used for diagnostics and for procedures (eg, initializing light modules). Both can program all series (except E-series & ISTA+) as well as code factory values.
E-sys can program, code factory values, and individually FDL ECU's.
Programming requires a PSU (not just battery tender) and there are risks involved. As such, not many offer it as a remote service.
      02-05-2017, 05:08 PM   #25
evilb
evilb's Avatar
Drives: McLaren MSO 570S, 18 Raptor
I recently had my all of the electronic modules updated to the latest versions at my dealership. It of course erased all of my previous coding. I went back in tonight to re-do some things, and found that I was getting error messages when attempting to 'Read' certain modules: HU_NBT, CAS, HKFM. Primarily the 2 that I was unable to code that I used to really like were 1) Enable keyfob mirrors/windows/sunroof open & close, 2) Trunk close with keyfob.
Another weird thing I noticed is that the HU_NBT is now displaying as HU_NBT_LS.
Any ideas?
2016 McLaren MSO 570S | 2018 Ford Raptor | @alpha7even
      02-05-2017, 06:25 PM   #26
Almaretto
Almaretto's Avatar
2376
Any ideas?
If you get "not found [C012]" error, when "Reading Coding Data," it is time to update Psdzdata. PM Sent.
I have heard of HKFM_LS, but not HU_NBT_LS.
      06-02-2017, 11:14 PM   #27
Mr. Uy
Drives: F10 M5
PM sent
Help with the same problem?
      06-03-2017, 01:21 AM   #28
Almaretto
Almaretto's Avatar
2376
Check OP:
Fxx, Ixx, & Gxx Series Coding: Latest Software, Guides, and Tips
      09-21-2021, 07:11 PM   #29
mbworldz
Drives: 2011 535i
Originally Posted by MWPos View Post
I've also created this very clunky spreadsheet so that I can chose functions to code, then re-sort the spreadsheet by ECU. Coding by ECU, instead of By Function, is much more efficient. This is targeted at the non-M F10, so some functions are not relevant to the M5. The "Technology" column is just a way to discriminate between older and newer F10s. The newer have the HU-NBT. The older, like mine, have the HU_CIC.
In order to view the attachment correctly, delete ".pdf" from the end.
I have a 2011 F10 535i, CIC unit. I wonder if I can code this to playback videos using the USB in the glove box or center console.
Enable video playback via USB Port and with various video formats
HU_CIC HU_NBT 3000 ENT_CODEC_VCD => aktiv
      09-22-2021, 03:18 AM   #30
Almaretto
Almaretto's Avatar
2376
Video playback requires NBT or newer.
m5post
