      10-17-2024, 09:22 AM   #463
sukhk527
Drives: BMW X5 XDrive35i
Originally Posted by vaios55sp View Post
็How hard to change the rear sway bar?
Drop frame needed?
Nah, just jack the rear up , undo bolts, pull OEM bar out. Easy peasy.
2017 X5 XDrive35i X-Line | Sophisto Grey | MHD Full Flexfuel Tuned | Mosselman Turbo | Sutphin Tuning TCU | Nostrum Stage 2 HPFP | Walbro 450 | S63 EU5 Injectors | ER Charge Pipe | FTP F10 Inlet | Midnight Motorsports Intake | ApexBuilt Catted DP | VRSF FMIC | Zeitronix Flexfuel Kit | KateCool Oil Cooler | Variant Wheels | Conti DWS06+ | Custom 3.5" Catback | M18 Racing Oil Breather Cap | Turner Catch Can |
      10-21-2024, 10:41 AM   #464
hound
Drives: BMW
How has the upgraded sway bar changed the driving dynamics?
Worth the investment in your opinion?
sukhk5272435.00
      10-21-2024, 05:23 PM   #465
sukhk527
Definitely worth the investment. Car seems much more planted at speed , I recommend this for every car no matter the level of build.
hound6.00
      10-21-2024, 05:26 PM   #466
sukhk527
Going to try and head back to the track one last time this coming friday and have been doing some data analysis to prep.
Since I haven’t shared this before, here’s a log to show some data on kill mode. Steady boost control, holding almost 24psi til redline , with fuel trims where you want them to be. 14.5 degrees of timing on this pull with E80 fuel in the tank.
Fingers crossed for this Friday. 🤞🏽
Appreciate 4
      10-23-2024, 02:09 PM   #467
parthpatel1
Drives: 2015 X5 M Sport
10/2/24
Car is officially back in my possession with a squeaky clean and leak free underside, plus some upgrades .
With that said, the rear right BC shock is leaking so a full suspension overhaul including all front arms and such coming in the spring. Now the question is:
KW V3s or AirLift? 🤔
Do you have any symptoms with the leak or just happened to notice it? I have a weird clunk noise coming from my rear right, so wondering if mine is also.
sukhk5272435.00
      10-23-2024, 03:21 PM   #468
sukhk527
No symptoms, found the shock leaking when I was under there. Knock is likely a thrust arm bushing or sway bar endlink. Rear endlinks are a cheap and easy fix.
      10-26-2024, 01:47 PM   #469
sukhk527
Ended the season on a high note yesterday. New personal best yet again, 11.4x index broken. Just some better DA from last time to this one. Can still adjust launch strategy a bit, do some additional lightweighting and size down a whole inch in tire.
Slowly but surely getting there.
      10-26-2024, 02:58 PM   #470
Kilabyte
I'm Batman!
Poland
3970
Drives: Mineral White M3 6MT
Congrats! That is moving
S55, 2JZ, M48.00, N55
sukhk5272435.00
      10-26-2024, 07:06 PM   #471
sukhk527
Thanks man, I’m happy with how’s it’s performing right now!
      10-28-2024, 10:02 AM   #472
titanjc
Drives: F15 X5 xDrive35i, Pure Stage 2
Buys SUV for dog car, turns it into drag strip machine. LOVE IT!
Congratulations, that is a MEGA time. Can't wait to see you running 10's next year!
      10-28-2024, 11:29 AM   #473
sukhk527
Many thanks my dude, it’s been a long time coming to get here. Now I just need to get it looking as good as yours.
titanjc58.50
      10-30-2024, 10:50 AM   #474
clarkitect
Drives: E30, E38, E46, E85, F15, F150
Sitting at work halfway through this build thread. Awesomeness. I gotta get back to work.
sukhk5272435.00
      10-30-2024, 01:33 PM   #475
sukhk527
I’m glad it’s entertaining enough for you to want to finish reading it later!
      10-31-2024, 09:57 AM   #476
clarkitect
Oh it is! Even though my wife said stop it, I am NOT to mess with our X5, don't get any ideas haha.
      11-03-2024, 05:07 PM   #477
sukhk527
I am not to be held responsible for arguments with your wife about the X5 later lol.
      11-08-2024, 04:28 PM   #478
titanjc
So sukh, I need some tips on launching. After putting it off for a long time I finally finished up my custom tune through Jordan Tuned, and the car is running great. Holding 18-18.5 psi all the way to redline on 93 pump gas. However, I’ve tried a few 0-60 runs on my Dragy and the best I’m managing is consistent 4.9s. I’ve been using launch control and leaving it in sport automatic. It feels like boost builds before launch, then bogs massively right after launching before it starts pulling hard. I’m also using the OTS XHP stage 3 trans flash.
I know there are a couple things holding me back. First is my 22’s. Although they are about the same weight as the OEM wheels, the tires I chose are almost 1” larger in diameter. Nothing I can do about that, I love the look! The other thing is my exhaust situation. Currently I’m on the stock downpipe. I may have to try the catted downpipe I was running before to see if it makes a big difference, just didn’t care for the gas smell.
Long story short, let me know how you’re launching the car. Launch control or just brake boosting, first or second gear, custom settings, etc. Also, if you feel like the Sutphin trans tune was worth any time. Might try throwing the downpipe on this weekend to see how much it improves the 0-60, you know, for science haha.
      11-09-2024, 12:16 PM   #479
sukhk527
Alright, let's get your launches dialed. Good call out on the taller tire, I'm glad you're already in the know about that affecting the time so there's that.
My launch strategy has always been 2nd gear, manual mode, brake boost with foot to the floor, mash the accelerator and let off the brake when the rpm's hit about 2800rpm.
The reason for this is because you'll hit a torque limiter sent by the tcase if you stand on the LC too long so to bypass that, you do the 2nd gear brake boost and let off in the right moment, in our case around 27-2800rpm so the car actually lets go at 3k because of the slight delay in the brake pedal.
I've also always manually shifted. On the stock turbo, I was shifting no later than 5500rpm because of the way the torque dropped off but on the Mosselman, I'm shifting at 63-6500rpm because it can hold the boost properly.
Try that, let me know. Feel free to DM me, always open.
EDIT: if you're not already, grab a data log of a pull so we can review it and see what we can work on based on the data.
      11-09-2024, 07:55 PM   #480
titanjc
Thanks man, I appreciate the detailed info. I’ll give the second gear start a go next time I have an opportunity. Hopefully that’ll help solve me bogging out of the hole. I’ll try to grab a log as well.
sukhk5272435.00
      11-09-2024, 09:55 PM   #481
sukhk527
Anytime dude. Watch the video of my latest run at the link below to give you an idea.
https://www.instagram.com/reel/DBl_M...l0NXIzdDRnaWVt
titanjc58.50
      11-10-2024, 07:57 PM   #482
Haihan
Haihan
Haihan's Avatar
Drives: BMW X6
Pretty sure I saw you driving pass me from the opposite direction on rte 59 today. Nice looking X5!
sukhk5272435.00
      11-10-2024, 09:17 PM   #483
sukhk527
Hah small world, and thank you!
