      08-29-2020, 07:39 PM   #507
CT335xi
CT335xi's Avatar
684
Drives: 2022 x5 m50i, 2005 evo 8
Originally Posted by itzjoker View Post
No spin or any noticeable bogging using launch control. I attached my best times that night (right side). Not sure how my other times are though.
Your 60’ times should be lower if you could cut it down to 1.7-1.8 that would be worth quite a bit, they say for every .1 on your 60’ worth almost .2 on the back end.
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno
Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr,
04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp
2014 x5 50i msport
itzjoker149.50
      08-31-2020, 11:24 PM   #508
itzjoker
itzjoker's Avatar
150
Drives: 2013 BMW 650i Gran Coupe
There is definitely room for improvement there but that's gonna be tough with street tires! I have some other theories for my slow ET's as well:
1. Car is heat soaked off the line, hence slow 1/8 times. Once it gets moving IAT's decrease, ECU adjusts and car performs as it should.
2. Keeping DTC on (Sport+ mode). I will try DSC off and DTC off next time (comfort mode). I believe DTC is intervening and slowing the car. Tested this out on the street and the car pulls 1-2 so much harder with everything off. If I do this then I won't be able to use LC.
      09-01-2020, 05:24 PM   #509
CT335xi
CT335xi's Avatar
684
I have heard lots of people doing this with switching everything off as it helps , you should still be able to probably break boost to 2500-3000 and leave the line. Good luck!
2014 x5 50i msport
itzjoker149.50
      09-01-2020, 09:42 PM   #510
C-Poppy
Drives: 650i xDrive Gran Coupe
Yeah... heat soaked doesn't help. However... I'm here in Tampa, FL and still able to get good 60ft, 0-60 and working on 10 sec 1/4 mile times. You definitely need to turn all of the nannies off to get the optimal launch. Hint... brake launching is much better than using launch control in these cars. If I can figure out how to attach my dragy slips here I'll post them up. Anyone?
itzjoker149.50
CT335xi684.00
      09-18-2020, 08:12 PM   #511
classic_erik
classic_erik's Avatar
Drives: 23' X7 40i M Sport
Do we know anyone who installed the Active Autowerke catted downpipes for the N63TU? Would love some feedback!
      09-24-2020, 10:03 AM   #512
itzjoker
itzjoker's Avatar
150
Sorry guys I don't have a F15/F16 50i (do have X6 35i however) but I figured I'd chime in here since I do have N63TU1 BM3 Stage 2 (650i GC) and the 6 series forums are kinda quiet.
Bootmod3 Stage 2 93oct
ARM Catless DP
Muffler Delete
Tried a ~20% E85 blend
Went to 1/4 track and best time was 12.822 @115MPH, very disappointed.
Somethings gotta be up right? Used launch control every run and I consistently ran 12.8/9. IAT's were constantly 40-50F above ambient (80F) and it was very humid outside. I dont have any proper logs but according to Bimmerlink I was hitting 19psi max during the run. I'm gonna build a custom intake and hope that helps for next time :\
Went back last night with the following changes:
Added some Boostane (98oct)
Custom front mount intake
DSC/DTC fully off
Best timeslip attached below.
Wow what a difference cool weather and launching without TC makes! Not sure if the intake made any difference though since my IAT's were still pretty high. Still need improvements with my 60' times, better tires next year will change that (I'm currently running all-season Continental ExtremeContact DWS) and help me break into the 11's.
CT335xi684.00
      09-24-2020, 10:09 AM   #513
Rotzy
Rotzy's Avatar
Drives: 2016 F15, 2015 F83
DSC/DTC fully off
Nice improvement.
itzjoker149.50
      09-24-2020, 06:03 PM   #514
CT335xi
CT335xi's Avatar
684
DSC/DTC fully off
Much better !! Your car should break into the 11’s no problem . Good luck.
2014 x5 50i msport
      10-07-2020, 10:05 AM   #515
C-Poppy
Well...I hit 10.97 and 10.98 1/4 mile times. 2.99 and 3.00 0-60 (this is without 1ft rollout). 2.81 with rollout on both 0-60. Times were using dragy. Times should go down once I go to the track. I'm trying to figure out how to attach my Draggy slips here. Any help would be great...
itzjoker149.50
      10-07-2020, 04:18 PM   #516
CT335xi
CT335xi's Avatar
684
Your car is a beast nice results!!
2014 x5 50i msport
      10-12-2020, 03:06 PM   #517
Yo_Holle
Drives: F15 xDrive50i E46 M3 Cabrio
New guy here! I got my X5 50i a few weeks ago and took it to the track yesterday. 96k miles Completely stock
ran a 12.8 a few times, not sure of the mph and didnt get a slip. will be going back friday
Anywho, for those running BM3 would having catless Dp on a stage 1 tune have any benefits? or would i have to buy stage 1 and 2 and switch back and forth? Its my daily but dont want catless everyday just race days
      10-12-2020, 05:55 PM   #518
CT335xi
CT335xi's Avatar
684
You will knock off a sec in the 1/4 should be high 11’s , plenty of results if you search good luck
2014 x5 50i msport
      10-12-2020, 11:50 PM   #519
pits200
Drives: 09 335i X-Drive Black Sapphire
You still running bm3?
      10-13-2020, 05:52 PM   #520
CT335xi
CT335xi's Avatar
684
Actually no , I was contemplating but here good and negative reviews so was on the fence but I have seen a few guys on the board with bm3 or some sort of similar stage 1 tune running high 11’s . Did you give up on the bm3 ?
2014 x5 50i msport
      10-13-2020, 06:37 PM   #521
txgrown
txgrown's Avatar
Drives: 2015 F80
Anyone running DME TUNING? Trying to look at all options before pulling the trigger this winter.
TXgrown
2018 x5 50i
      10-13-2020, 07:39 PM   #522
Yo_Holle
Is that with stage 1 and Dp? i seen the guys on here in high 11s with stage 1 and no dp. trying to see if its worth making the jump to stage 2 and getting more since they're the same price
      10-13-2020, 07:57 PM   #523
CT335xi
CT335xi's Avatar
684
I have heard they run that with nothing more then stage 1 and 93 octane no dp as you need stage 2 for that.
2014 x5 50i msport
      10-15-2020, 08:55 PM   #524
pits200
So I'm a glutton for punishment and wanted to see if the issue was this tune or because my prior engine had 97k miles on it.
For the past week the new engine has run amazing, completely new short engine, new coils and new plugs too. I flash to stage 1 93 tune and let the car get to operating temp. Literally the first log I get a knock event and the acceleration feels like im driving a trans am.
I took a 5 second log and I'm a moron for not doing this before, BM3 on their stage one tune is way too aggressive. I've included a log and this ots tune is an engine breaker. The amount of ignition they are running at such low rpms is a recipe for disaster. Unfortunately, I can't see what the IA targets are for the tune but they obviously want people to feel it in the butt dyno and the way you gain that is through torque. I can't see any reason for running this kind of advance on a stage 1 tune. If this was an E85 tune, I'd give them a pass but one a 93 tune with engines that don't typically love high advance, this is moronic, stupid, idiotic, etc......
I'm all of the names I listed above for not logging and checking this earlier.
https://www.bootmod3.net/log?id=5f88...729b488dc3d9c4
CT335xi684.00
1norseman399.50
      10-16-2020, 04:40 AM   #525
CT335xi
CT335xi's Avatar
684
Thanks for posting !!
2014 x5 50i msport
      10-16-2020, 06:01 AM   #526
pits200
As a reminder to people, IA is used can be beneficial at low rpms to help remove the appearance of boost lag while the turbos spool.
      10-16-2020, 01:46 PM   #527
skoold2003
skoold2003's Avatar
2014 X5 50i  [7.50]
I've wondered if the RC XLR pedal tune can cause the same issue. Could it be that the motor needs that throttle delay to avoid opening the throttle before the turbo kicks in?
      11-14-2020, 08:46 PM   #528
campaign308
Drives: 08 X3
Completely stock other than JB4 Map 1.
