02-16-2019, 10:19 AM | #529 | |||||
Rep 7,165
Ya he should have definitely sent the bracket.
02-16-2019, 10:24 AM | #530 | ||||||
499
Rep 328
Rears are from Tronik..I got the fronts off of a seller on eBay. Response I got from the seller is that M5 caliper bolts directly to the spindle on studs. No bracket. I guess I can call BMW to validate but it looks like I'll need an adapter regardless. Hopefully I can have Tronik throw them in for cheaper than advertised. |
02-16-2019, 10:40 AM | #531 | |||||||
Rep 7,165
02-16-2019, 10:47 AM | #532 | ||||||||
499
Rep 328
02-16-2019, 10:50 AM | #533 |
Rep 7,165
Ya you better jump on this. Last one left.
02-16-2019, 02:42 PM | #534 |
Rep 207
Anyone know the correct numbers for splash shields for M brakes?
34-11-6-857-979 looks like front left 34-11-6-857-980 looks like front right 34-21-6-857-982 looks like it might be left and right for the rear? Also anyone have the part number for the m rotor screw? Thanks! |
02-16-2019, 03:11 PM | #535 | |
Rep 7,165
Put them into getbmwparts and they show you.
KillFox9185.00 |
02-16-2019, 08:23 PM | #537 | |
Rep 7,165
Take it by the dealer ASAP and get those parts.
02-16-2019, 08:29 PM | #538 | |
Rep 674
02-16-2019, 11:13 PM | #539 |
Rep 1,975
sbinshihon684.50 |
02-17-2019, 10:56 AM | #540 | ||
Rep 7,165
sbinshihon684.50 |
02-17-2019, 03:18 PM | #541 |
Rep 1,975
Shot in the dark but is the face of your wheel hub and the back of your wheel's mounting plate super clean? Might help to hit all four with a wire brush?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
Maverik2594150.50 |
02-17-2019, 05:02 PM | #542 | |
Rep 674
I getting fed up with MPBK I will remove them and install the original brakes. Hopefully the problem will go away.. then I will rebuild the MPBK. |
02-17-2019, 05:04 PM | #543 |
Rep 1,975
Would rebuilding them have anything to do with vibration? If anything I would think it would only help the actual stopping power.
02-17-2019, 05:21 PM | #544 | |
Rep 674
02-17-2019, 07:31 PM | #545 | ||
Rep 7,165
02-17-2019, 08:25 PM | #546 | |||
Rep 674
02-17-2019, 08:36 PM | #547 |
Rep 2,388
If you have the car on hoist already, maybe you could simulate same conditions with wheels in air and see if there will be vibrations visible on front or rear? i mean start the car, put it in D, accelerate till needed speed and then apply brakes (assuming it's safe to do and car is secured on hoist). There's no way you wont' see what vibrates - unless it's indeed suspension (due to car been oh hoist) - then we at least will know it's not brakes.
sbinshihon684.50 |
02-17-2019, 09:44 PM | #548 | |
Rep 674
The vibration comes in speeds above 75 miles. Literally when I first lean on the brakes (you know that gap before the actual brake force), so If I just close that gap with my foot the car shakes violently, the harder I press the less shaking theres... : |
DuSh2113.50 |
02-18-2019, 07:06 AM | #549 |
499
Rep 328
When swapping out your calipers did you guys change your brake lines as well? Any recommendations?
02-20-2019, 01:41 AM | #550 |
Rep 674
I have good news turn out there was something missing that caused the vibration! The primary suspect is this brake line holder. After installing this and turning the rotors... The brakes feels solid now!
Maverik2594150.50 DuSh2113.50 |
