02-20-2019, 10:38 PM | #551 |
Rep 7,165
I have SE lined from ECS I'll be installing as well. Again not needed but why not. It's only about $120 for the set of 6
DuSh2113.50 |
02-22-2019, 11:53 AM | #554 |
Long Time Bimmer Fan
215
Rep 156
Sweet shot! Delete the car in the backdrop and it's even sweeter.
2014 X5 XDrive 35i - Current
2010 X5 XDrive 4.8iS - Traded 1990 325iS - Sold 1985 318i - RIP |
02-23-2019, 03:19 PM | #555 |
Rep 7,165
Looks good let's see a close up of that color!
DuSh2113.50 |
02-24-2019, 12:04 PM | #558 |
Rep 1,859
Drives: 23' X7 40i M Sport
Can someone recommend a seller who can package the MPBK with F85 rotors? My goal is to not have to sell the rotors that come with the MPBK at a deep discount and pay up for new F85 rotors separately.
I've read from a few here that the dealer was open to a credit to hold onto the MPBK rotors and let you pay-up to the difference in F85 rotors. A local dealer actually looked up the difference in cost and it's only $65!!!!! How could BMW possibly make the decision to roll out this kit with a standard ventilated rotor when they could have just used the nicer F85 cross-drilled rotor? Crazy...
02-25-2019, 10:51 PM | #559 | |
Rep 7,165
Heard of some dealers doing that but you're gonna have to ask your local dealer. Problem is cheapest price is getbmwparts. Maybe you can sweet talk them. Although they'll probably want to sell it as a one piece thing as the MPBK is a part number of its own as a whole. And it's what makes it cheaper than a la Carte. But hey in other news. Looks like BMW isn't completely opposed to a fixed 4 pot rear caliper. Thanks M2 CS...
classic_erik2811.50 |
02-26-2019, 04:56 AM | #560 |
483
Rep 317
I had a hard time trying to figure out how the hell to code this damn brakes, however after a few hours of youtube videos and sifting thru post after post, I finally figured it out and wanted to write a comprehensive coding in ESYS 3.27.1 since there isn't any pertaining to our F15 X5 M sport brake coding.
Disclaimer: I'm not responsible for any damages, injuries or death following this steps...I'm hardly an novice and more of an imbecile when it comes to coding BMW...so if your unsure on following these steps seek an expert coder for assistance. Pre-step, Make sure your car is hooked up to an battery charger with at least 14V to prevent vehicle from going into sleep mode. Leave keys in the vehicle, and hit start button without starting engine (no foot on brakes) and connect OBD to your computer/laptop with ESYS 1. Start connection click on the Icon that is highlighted in red 2.Select F025 and click connect this is F15 X5 F16 X6 specific, this may take a moment (WHATEVER YOU DO NOT SELECT DIRECT) 3. Click read then save 4. Save it securely, you may choose any name for our example we'll use "feb 26 fa 3" 5. After saving click EDIT and it should automatically take you to FA-Editor 6. Expand all the folders and find HO-WORT, Right Click, select NEW and click on HO-WORT 8. You'll be prompted with a small text box within the drop down folders, type in SBRE and hit enter. (SBRE is for F15 M sport brake code) 9. Right click on the FA folder, then click on calculate FP 10. It should populate the vehicle profile with no error message...now if your ESYS is working properly it should show "Aftermarket Addon", in our case its folder 8, expand folder 8 and it should be another folder with 2376, which is 18in sportbrake for F15, this confirms that file is coded and ready to be written on vehicle. Besure to click the save disk (highlighted in red) to save it. 11. Look over to the left tab and click on "Expert Mode" then click on VCM and you should see a screen like this. 12. Next look down and find for vehicle order section, select file tab and click the |...| box (highlighted in red) to load the file that we saved on the FA editor. In our case the feb 26 fa 3.xml 13 Expand the FA files and find the HO-WORT to verify the SBRE is added 14. Right click on FA and click on calculate FP this should populate the Vehicle profile section with folders 15. In the Vehicle profile expand folder 8 and verify that 2376 is present (highlighted in green box), then click on the Master tab (highlighted orange box) and click on Write FA FP (highlighted red box) if all goes right there shouldn't be any errors popping up. 16.On the left tab click on expert mode thencoding (highlighted in orange), after if opens, click on Read and save, name the file diffrentely for our example i added coded in the end of file name, feel free to name it whatever you want. 17. After Read and Save, expand all the files and find Ho-wort and look for SBRE and in vehicle profile look for folder 8 and subfolder 2376 this means is has been written into the car but we still have to code into the module for it to be completed. 18. Now we need to code the new HO-WORT into the appropriate Module, click on the Read ECU (highlighted in red) and SAVE a copy. 19. In the SVT section, find DSC2 right click and select Code...this will take 1-5 mins and you'll see an ABS Warning message that will pop up for a second and disappear as it should resolve on its on (ESYS will erase the fault code automatically) it should not reappear. 20. If you did it all correctly you should have no errors and you'll get a abgeschlossen bearbeitung (process completed) dialog and a close button. (didn't get the image of it). Click close and another popup will appear and will ask you to save a text on what it did, it's up to you if you want to save it or not doesn't hurt either ways. 21. Click disconnect and your done. You now have successfully coded M Sport brake on your X5 I haven't driven it yet so I'll find out this afternoon on how it goes, it is super late lol its 0500 as of now time for some ZzZzZzZz Last edited by Mr.47; 02-26-2019 at 05:33 AM.. |
02-26-2019, 07:10 AM | #561 | |
Rep 1,975
Great add to this thread!
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
02-26-2019, 08:10 AM | #562 | |
Rep 1,859
02-26-2019, 01:02 PM | #563 | ||
Rep 7,165
02-26-2019, 01:04 PM | #564 | |
Rep 7,165
also I assume you have ESYS pro given the token has expired for premium.
02-26-2019, 02:33 PM | #565 |
Rep 1,859
02-26-2019, 02:55 PM | #566 | |
483
Rep 317
Perhaps Dush can tag that thread on the front, I could copy and paste in a new thread but I feel this is an appropriate place to contribute since is a well known and knowledge dense thread. |
02-26-2019, 03:24 PM | #567 | ||
Rep 7,165
So how did you code without FDL? Or is it all VO coding? I didn't read through it all as it's very long lol
02-26-2019, 03:56 PM | #568 | |
483
Rep 317
TLDR: add SBRE to vehicle option, write to vehicle and code DSC2 to apply new braking parameters for ABS for m sport brake |
Maverik2594150.50 |
02-26-2019, 08:37 PM | #569 | ||
Rep 7,165
02-26-2019, 08:49 PM | #570 |
Rep 1,975
Exactly. Like what the hell does TLDR mean? Lol.... reminds me of the Rickie Fowler Quicken Loans commercial.
02-26-2019, 08:59 PM | #571 |
499
Rep 328
Does it matter that the coding above references the F chassis? This brake code would be for an F85: 6-Piston versus the 4 on the E70.
02-26-2019, 09:01 PM | #572 | ||
483
Rep 317
To Long Didn't Read |
Maverik2594150.50 |
