10-18-2023, 09:12 AM | #5788 |
Rep 41,227
I hate the question of "warranty" of Coding, which is a legal matter. I am convinced it is legal, but I didn't go to Law School, and I am not going to make any assurance that some dealer somewhere is not going to take issue with it and try and create problems. I only know coding is rampant, and I never hear of warranty problems, except in very rare cases where an individual has actually bricked an ECU when Programming (not coding).
50iXman34.00 |
10-19-2023, 10:45 PM | #5789 |
Rep 1
shawnsheridan do you provide local coding services in HTX? I'm looking to code anti-glare no-dazzle high beams. I was trying to PM you, but I cannot since I just registered here
10-19-2023, 11:19 PM | #5790 |
Rep 41,227
I replied to your same PM.
11-02-2023, 08:28 PM | #5791 |
Rep 1
Hi Shawn, possible to get the current esys and ESYS psdzData?
The last version I had was 2.4.3.85 and can't seem to get it working even with changing dates anymore. Thanks in advance! |
11-02-2023, 08:33 PM | #5792 |
Rep 41,227
PM sent.
11-09-2023, 05:08 PM | #5793 |
Rep 3
hey guys, I have an f15 diesel with a 6wa that has a bad turn signal LED. (I've seen the write up on replacing the led, but want to be prepared in case I botch the surgery) I presume that even if I do a direct replacement with a virginized cluster, I still have to code the new cluster, correct?
If so, who is the go to for this type of coding these days? Any help is appreciated!! Thanks! (disclaimer, I've searched a ton but most seam to be about retrofits and not direct replacements, also have seen the phrases cafd, kombi and hu_nbt but still don't know what it all means, might as well be Chinese to me) |
11-10-2023, 12:53 AM | #5794 | |
Rep 3
FIREEEE
11-13-2023, 04:35 PM | #5795 |
Rep 138
Hey Shawn,
Great thread. Could I get the links please for general coding but I’m also specifically looking to do the old skool EGR fresh air adjustment. Is this even possible on the F15? I know it was removed in newer ISTA versions but I’d really like it back to do some testing. TIA ✌️ |
11-13-2023, 07:40 PM | #5796 | |
Rep 41,227
11-14-2023, 01:00 PM | #5797 |
Rep 138
11-14-2023, 01:46 PM | #5798 |
Rep 41,227
OK, nothing I've ever done.
11-18-2023, 08:03 PM | #5799 |
Rep 1
Just finished installing a hitch and need to program the AAG Trailer Control Module. Ran into this amazing thread in my research to programming the modules.
Would it be possible to get the link to the latest E-SYS and E-SYS psdzData? |
11-18-2023, 09:31 PM | #5800 |
Rep 41,227
PM sent.
11-27-2023, 09:46 PM | #5801 |
Rep 8
New member learning the ropes and flailing blindly in the dark. Could I request access to the above mentioned E-SYS and psdzData files? Does the ESYS include the launcher?
Thanks! |
11-27-2023, 10:53 PM | #5802 |
Rep 41,227
PM sent.
12-14-2023, 04:35 PM | #5803 |
Rep 3
Seems things have changed since 2021 when I last tweaked my 2018 X5D for trailer hitch functions. Launcher Pro 2.8.2.162 error: EST token invalid...no certificate found...
Please provide links for the updated files needed. THANKS! -js |
12-14-2023, 04:38 PM | #5804 |
Rep 41,227
PM sent.
12-15-2023, 07:28 PM | #5805 |
Rep 4
Shawn:
I recently completed the installation of OEM hitch, wiring, and control module on my F15 X35D. I only have ISTA+ installed on my laptop, and it appears I may need to use E-Sys to properly complete the coding of the AAG module. Can you share the link? Thank you, Al |
12-15-2023, 10:05 PM | #5806 | |
Rep 41,227
12-17-2023, 01:29 PM | #5808 | |
Rep 53
Cheat Sheet link is not available
