02-08-2018, 10:24 AM | #595 |
Rep 748
Adapter has on/off button. Adapter also turns off by itself after car stopped and locked ( i think not right away, but rather after some time). Anyhow, i live it plugged in.
sbinshihon684.50 |
02-08-2018, 03:09 PM | #597 |
Rep 674
02-08-2018, 03:27 PM | #598 |
Rep 1,180
02-08-2018, 03:30 PM | #599 |
Rep 674
Yes, but that was a quick answer for a nob question. People try to open it for sound as far as I know.
02-08-2018, 05:07 PM | #600 |
Rep 49
02-13-2018, 08:40 PM | #603 |
Rep 46
Got my adapter in for the bimmercode app and everything is done easily and most of the stuff in somewhat self explanatory, but could I get some help on the circled items in terms of what changes these make? Most of them our related to trunk closing and opening but don't exactly understand how they relate, esp when it says "footwell" please help!
02-15-2018, 01:58 PM | #604 |
Rep 1
Im a new member here! 2015 X5 xdrive50i. I did the coding with bimmercode but cant figure out how to add turn signals to the HUD. Can anyone guide me how to do it?
Thank you in advance! |
02-15-2018, 03:21 PM | #605 |
Rep 63
02-16-2018, 08:53 PM | #606 |
2020 Mineral White 30d MSport
527
Rep 2,147
Drives: 2020 Mineral White 30d MSport
Anyone knows how to unable opening the rear tailgate from keyfob via BimmerCode?
02-17-2018, 03:36 PM | #607 |
Rep 165
Ok, what am I doing wrong...I can connect to the v-link via wifi, it reads the ecu and shows the menus, I find the option I want to code, change the value and hit code at the top of the screen and it gives an error that I am not connected to the internet....which makes sense becuase I am connected to the vlinks wifi....
02-17-2018, 05:14 PM | #608 |
527
Rep 2,147
Do you have it set to “slow communication”?
Check it out on settings page on BimmerCode |
02-18-2018, 12:51 PM | #609 | |
Rep 131
- the tailgate button that's locate on the driver door's window switches panel (whether you want it to be able to open/close/open & close) Tailgate remote operation mode - with the bmw remote, do you it to be able to open/close/open&close Tailgate button in footwell close with long press - when it's closing, do you want it to be close with one touch or you have to keep on holding onto the button Tailgate with remote close with long press - same with the previous one, but now it's with the remote, do you want it to be close with one touch or you have to keep on holding onto the button Start Stop function off by default - the engine start/stop function, whether you want to keep this function off or not |
Killacam1378.00 |
02-18-2018, 02:44 PM | #610 |
Rep 63
Got my iCar Pro Wifi on Saturday and had a chance to play around with the basic settings, planning to dive into expert mode stuff today or tomorrow. Super easy to get started with iOS apps and reading most of this thread in advance was key so i knew about some of the basic stuff like throwing codes and starting w Slow Connection.
Done the following so far: One Touch Trunk Open/Close w. Fob & Door Button Mirror Open/Close w. Comfort Access /M Splash Screen at Start-up Radio/Nav off on door open Digital Speed in Board Computer Disabled Disclaimers at Start-Up Disabled 2 Horns when Locking while Running 6 Click Indicator - WORKING! Door Handle LEDs on Reverse FWIW, i've found i have to clear errors 2-3 times from both the INFO and ERROR Memory sections of BimmerLink to get it to stick. Also think you need to explicitly DISCONNECT in the BimmerCode app to get it to connect in the Bimmerlink app Last edited by Mgm 05; 02-18-2018 at 07:37 PM.. |
Killacam1378.00 |
02-20-2018, 12:20 PM | #611 |
Rep 528
Does anyone know if the flashing red LED on the rear view mirror can be disabled using BimmerCode? It’s activating my dashcam motion sensor, so the thing is recording all night!
02-20-2018, 12:57 PM | #612 | |
Rep 1,180
You may be the first to get this to work or bimmercode finally found a way to get this to work.
2018 X5 35i M-Sport
02-20-2018, 01:22 PM | #613 |
Rep 31
02-20-2018, 04:36 PM | #615 |
Rep 1,180
thanks man!
2018 X5 35i M-Sport
02-20-2018, 06:39 PM | #616 |
Rep 63
https://photos.app.goo.gl/PmcMSyKhdcLPP7OQ2
CeeTeeX5 Here you go, don't know how to embed the video, let me know if the link doesn't work. I'll do screenshots of Bimmercode (i'm only touching easy mode) if switch to 4 is a success. |
CeeTeeX5936.00 |
