03-08-2019, 03:31 PM | #45 |
Wannabe Track Rat
70
Rep 930
Well thank god for this thread. I was about to off myself. Did the “short version”. Took 30 min. Would have been 15 but had to keep moving the car to get the damn penny to settle in the back so I could grab with the tweezers. Thanks a ton!!
03-08-2019, 03:46 PM | #46 |
200
Rep 351
Damn a penny would be harder to catch luckily mine was a quarter. If it wasnt for this thread a couple of months ago I wouldve spent 400 at the dealer
03-27-2019, 06:15 PM | #47 |
Rep 1
Tried this today and failed. I removed the shifter and there was nothing underneath. I realized that the quarter is directly under the cup holder and is completely blocked from the view. I now need to lift up the cup holder, which requires removal of the side pieces that are blocked by the armrest piece, which I have no idea how to remove(will try again tomorrow).
06-14-2019, 07:20 PM | #48 |
Rep 14
For those of you that have done this, I have a quick question. I followed the instructions (and photos) at the beginning of this thread. But, is this the piece you're supposed to pull forcefully from the sides? It popped off, but now it won't pop back in, so I didn't want to pull the other side. I'm hoping I didn't break something... Thanks.
https://ibb.co/gSKD7pC |
06-23-2019, 05:57 AM | #49 | |
Rep 14
06-23-2019, 08:41 AM | #50 |
Rep 14
But, as a bonus, I did get $0.24 and an ATM receipt from the previous owner.
The Libertine1237.00 |
06-23-2019, 09:08 AM | #51 |
Rep 1,222
jeffrey10110.50 |
06-26-2019, 03:15 AM | #52 |
Rep 2
I’m having the same problem. Please let me know how to get rid of this?
06-26-2019, 10:04 AM | #54 |
Rep 2,529
07-28-2019, 10:37 PM | #55 |
Rep 207
Just did this. Thanks to this great video I was able to complete it in about 30 minutes!
02-02-2020, 09:38 PM | #56 | |
Rep 76
Anybody ever get the whole cup holder assembly out? |
02-04-2020, 10:57 AM | #57 |
Rep 536
12-23-2020, 05:08 PM | #58 | |
Rep 38
2006 530xi - Sapphire Black (sold)
2013 X5 xDrive50i M Sport - Carbon Black Metallic (totaled) 2019 R nineT Scrambler - Brushed Aluminum 2016 X5M - Long Beach Blue Metallic |
02-26-2021, 04:45 PM | #60 |
Rep 473
Hey guys
I lifted the centre console out to try and get the coin that’s been rolling around in there. I don’t know which tTorx screws to take out to get access to that groove by removing the gear console. Does anyone have a picture showing which screws to take out? Also, is it possible to break the tabs at the front when pulling up on the silver part? I think I may have because when I tried to put the console cover back, it’s still loose at the front even when it’s all the way down. 😳😖😢 |
03-04-2021, 05:36 AM | #61 | |
Rep 6
I'm waiting for new ones to arrive so I can remove everything once again and try to find old ones deep in those holes... |
03-09-2021, 01:44 PM | #62 | |
Rep 473
Do you know part numbers?
DR CHUCK
2009 E92 M3 Le Mans Blau on Schwartz. DCT. RAC RG63, KW V3, Eisenmann Race, AP Racing, Vorsteiner GTS5 Front Bumper, Vorsteiner GTS-V Rear Diffuser. |
02-25-2023, 02:00 PM | #63 |
CELLO11
Rep 11
Replacement of cigarette lighter by USB charger
I just removed my noisy coin in the center console by following the instructions in this thread. Thanks a lot to RufussCkingston , everything worked perfect.
As instructed I had to remove the handrest compartment, but as the cables were too short I was not able to deconnect the sockets, so I just lifted up the handrest compartment in order to remove the two side trims covering the cupholder compartment. However, as I did this extensive work, I decided in this occasion also to replace the cigarette lighter with a USB C charger including Voltmeter. In order to remove completely the cupholder compartment I had to disconnect the power connector on the side of the channel. Attached picture shows the USB A/C charger with voltmeter indication on. I can turn the voltage indication off if needed pressing the small button on the surface. The main advantage for me is that I can still close the cover of the cupholder compartment completely and I can monitor low battery level. |
