      03-10-2018, 09:27 AM   #45
Painted Reflectors installed
I finally had the painted reflectors installed. I waited until I imported it from Germany to the US to avoid any clearance issues that may arise. Another great product from Ben/ r33_RGSport.
Appreciate 4
menelaos1237.00
P111852.00
      03-10-2018, 10:11 AM   #46
Originally Posted by Dogzyboy View Post
Great work, loving that interior.
Thanks, I really like it as well. It looks awesome at night with the ambient lighting reflecting off of the CF.
      03-10-2018, 10:11 AM   #47
CeeTeeX5
Looks great man! On that first pic with the painted reflectors, did they not put the wheel well liner back in correctly? Looks like it's not tucked behind the inside part of the flare.
Are you planning to get wheels?
2018 X5 35i M-Sport
Dinan Stage 1 Tuner
M-Perf Exhaust and lip
2018 X1 28i M-Sport
      03-10-2018, 10:18 AM   #48
You scared me, I went out to check it and it’s just camera angle. It’s assembled correctly.
As to the inevitable wheel question, I’m content with the OEM 469Ms. I may replace them someday, but no plans at the moment. I have two sets of OEM 469s, and two sets of summer performance tires to go with them, along with the Contis. I am looking to sell a set of the 469s though.
      03-10-2018, 10:38 AM   #49
Sedoy
Drives: F10
I'm confused part numbers for supporting ring - 51168060321 and 51168060322 shows up on RealOEM for both F15 and F85 but this part should be different between regular X5 and X5m?
Exactly, simple swap.
I believe these are the parts I used;
51168060321
51168060322
51162361520
51162361521
      03-10-2018, 10:58 AM   #50
It is compatible with both, but the outer ring is specifically for the F85/86. Its a clean swap with no modifications required.
      03-10-2018, 12:21 PM   #51
lapa
Sweden
151
Drives: BMW X5 M sport 40d 2017
Your car looks awsome!
I miss my white 2014 X5..
2014 X5 30d - retired
2016 X5 40e - retired
2017 X5 40d - present
      03-10-2018, 12:27 PM   #52
Thank you very much, I appreciate it.
I know the feeling, I still miss my black sapphire F16 but my X5 helps me easily get over those feelings.
      03-10-2018, 03:42 PM   #53
Sedoy
Drives: F10
So that's the part number for that outer ring? I trying to order it and confused that part do I need for outer ring. I already have F85 covers. Thanks.
      03-10-2018, 03:44 PM   #54
Window tint
Finally, I can have my windows tinted! SunTek CIR applied all around, including sunroof and windshield with a 70%.
Before /After
      03-10-2018, 03:47 PM   #55
Yes, those are the part numbers for the supporting rings.
      03-10-2018, 03:54 PM   #56
Don't trust 3rd party BMW online parts catalog 100%, I have got a wrong parts following it.
There are some tricks to confirming part numbers, usually require some VIN and different parts catalog that connect to BMW database directly.
It does require subscription, which I do have.
      03-10-2018, 03:59 PM   #57
Check this thread, I posted more detailed info.
http://f15.bimmerpost.com/forums/sho....php?t=1465994
      03-13-2018, 09:56 PM   #58
yewlock
yewlock's Avatar
Drives: X5
Your car looks beautiful and almost completely mod. Have you thinking about changing the following
http://www.rgsportshop.com/index.php...earch=downpipe
      03-13-2018, 10:18 PM   #59
Thank you, I appreciate the compliment.
Yes, I’ve considered replacing the downpipe, but not sure about doing that mod yet. I need to save some mods for when I get bored with her.
      03-13-2018, 11:28 PM   #60
yewlock
yewlock's Avatar
Drives: X5
How are your tire condition? Are they worn out more on the inner side? Do you install any camber kit? Are the front and rear worn out the same ?
      03-14-2018, 07:47 AM   #61
I switched to Contis right before I lowered it and installed the spacers. But I haven’t noticed any odd wear on the tires and no camber kit installed.
I took her to BMW for an alignment a few weeks after the Eibach springs were installed and they said that it was within spec and wouldn’t adjust the alignment.
Drives/rides like a dream.
      03-16-2018, 01:58 PM   #62
AlpineOnCoral
Drives: 2018 X6 SDrive35i
Following! Great build thread. Hurry up with the RC install and review!
      03-16-2018, 11:32 PM   #63
That cannot be a 70% tint. You mean a 30% tint?
      03-16-2018, 11:36 PM   #64
Windshield and sunroof are 70%, the front is whatever Texas max allowed.
      03-16-2018, 11:38 PM   #65
I have 5% all around, and 25% on the driver and passenger side. In the photos, yours looks just as dark as mine!
      03-16-2018, 11:39 PM   #66
Are you going to take off the empty license plate bracket?
