06-01-2021, 09:14 PM | #45 |
Rep 1,428
Here is the extra FRR-01 just arrived, Ready to ship. Price $300. This module is very hard to find in the US and prices are between $400 - $900. Plus this unit came from 2016 X6 while i am using from 2012 7 series on my DIY. I am giving this price due to the plug being cracked but nothing wrong! And i also use one of my plug to see how it looks like after plugged in, it covers the crack area completely! Check out the pics :
Plugged :
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 06-01-2021 at 09:23 PM.. |
06-02-2021, 05:13 PM | #46 |
Rep 6
Hello guys, really interesting write up. I just purchased 2014 (2013.12) f15 with S5DF, it also has S8TH (SLI), also adaptive LED headlights so KAFAS in place, and also 360 cameras with one camera on the front grille. How easy or hard would be do this SA5AT ACC w/ SA5AR TJA ?
06-02-2021, 10:39 PM | #47 | |
Rep 1,428
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
06-03-2021, 01:39 AM | #48 |
Rep 6
06-03-2021, 11:53 AM | #49 |
Rep 1,428
You need to take the front bumper off and see if you have SRR-01 short tange radar on the side. I assume you have blind spot detection. If you dont then you also need 2 more sensor on the rear. I assume you already have FRR-01 sensor since you have 5DF. It should be fairly easy retrofit for you.
06-03-2021, 05:11 PM | #50 |
Rep 6
don't have blind spot. but again with sensors, mirrors and coding i will have blind spot as well ? In that case lane departure warning as well with vibro steering upgrade
06-04-2021, 12:20 AM | #51 |
Rep 1,560
Caught up to you today, Sensor is installed in the bumper and the harness run to the compartment just below the ABS pump.
Left harness that has to be unplugged to remove bumper Right harness. You also need to unplug the foglights Sensor installed Harness on bumper Bumper fully off
06-04-2021, 02:18 AM | #52 | |
Rep 1,428
Nicee. Seems like you also dont have the front SRR short range sensors like me. Do you have SA5AS also lane assist via KAFAS2?
06-04-2021, 08:58 AM | #53 | |
Rep 1,560
06-04-2021, 09:40 AM | #54 | |
Rep 1,428
It is used on SA5AT and SA5AU on current G series regardless of the FRR or KAFAS2 So i have 5AS, which only includes rear SRR and thats for blind spot. KAFAS2 helps for lane departure warning but does not do automatic lane change. I think the side radar on the front end helps for that.
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 06-04-2021 at 09:47 AM.. |
06-04-2021, 09:58 AM | #55 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
What is jack point you;are using to lift front end?
06-04-2021, 10:09 AM | #56 |
Rep 1,560
I have not seen any F15 that has lane assist that will actively mitigate straying out of your lane. It only vibrates the wheel. G series has it
My options are 5AG Lane Change Warning 5AS Driving Assistant 5DL Surround View 5DP Park Assistant https://f15.bimmerpost.com/forums/sh....php?t=1314464
06-04-2021, 10:32 AM | #57 |
Rep 592
Thanks , I did not read first response well enough
06-04-2021, 04:15 PM | #58 | |
Rep 1,428
This is the first time i have been in F chassis X5 in my entire life so i really do not know what others optioned, but i was in the market to get the most loaded version which i got at the end. My understanding is 5AD built in to 5AS. And where i see the front SRR on the f85 was when i saw the Mike's ACC+TJA topic. He is equipped with it. But i dont know is that just for LDW or LDP. Regardless of that front 2 SRR, i have seen 5AT retrofit installed without this 2 sensor. I think KAFAS2 will handle with it.
My VO also includes 5AL which is Active Protection and can auto brake during emergency situations. So Kafas2 definitely can maintain the 5AT features with the FRR-01 for sure. But what i see is the newer G series asking for FSC code to activate features like Driving Assistant Pro option in KAFAS module. Quote:
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 06-04-2021 at 04:26 PM.. |
06-04-2021, 11:40 PM | #59 |
Rep 1,428
I am at the stage trying to run the wires from hood to cabin. What do you guys think? It is pretty tight there. And i couldnt see any light shining in the cabin after removed coupe of trims. Gotta be an easy way somewhere
UPDATE: Driver side much better to work with. Since i had a long cable i can grap from passenger firewall area and run thru to driver side without removing the bumper and re routing the wiring harness. I will first stop at Kafas then split from there to ICM. I should have looked the the firewall situation before installing the wiring harness.
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 06-05-2021 at 12:36 AM.. |
06-05-2021, 07:23 AM | #60 |
Rep 1,560
I plan on using one of the spare grommets below the ABS module to enter the cabin. I was a little perplexed why they used the grounding block on the passenger side since there is a much closer grounding block on the drivers side as well. Kafas is right there where the cable would enter.
06-05-2021, 01:54 PM | #61 | |
Rep 1,428
06-05-2021, 09:15 PM | #62 |
Rep 1,428
Thread Updated. Wiring from hood to Cabin is done and documented!
06-06-2021, 06:17 PM | #63 |
Rep 1,428
Almost there : ICU ICM
I ve reached to this step within 15 min. With my guidance EVERYONE going to have some easy steps to remove the middle console as usual The End : 2,5 hours total amount to remove and put everything back in place. I only have F45 fuse cable left in the project. Rest is gonna be programming and activating. Last edited by SaNGRia; 06-06-2021 at 10:43 PM.. |
blue dragon1205.50 |
06-06-2021, 08:02 PM | #64 |
Rep 1,560
You went all out this weekend
06-06-2021, 11:05 PM | #65 |
Rep 1,428
Yes sir. 80% is done Thread Updated!
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 06-06-2021 at 11:32 PM.. |
06-07-2021, 12:19 PM | #66 |
Rep 1,560
I noticed that you have to move the seats front and back to get to the bolts on the center console. Did you remove the NBT controller and trim with the buttons (all the pieces at the top) before disconnecting the battery? Did you unplug the ICM with the battery still connected?
