07-29-2020, 05:37 PM | #750 |
Rep 439
Drives: 07 E92 335 / 17 F16 X6 35i
Does anyone have the rough specs for the brackets for the F10 M5 brake caliper? It should be an easy part to make.
@mikecentola
07 335i SG / CR - LOTS OF MODS - BUILD THREAD 17 X6 SG / LCSW - ZMM/ZCW/ZDA/ZDB/ZLP/ZPP/MPPK - H&R VTR / Vossen 22x10.5/22x12 18 Ford Raptor |
08-03-2020, 03:50 PM | #751 |
Rep 10,319
This is THE picture of the year. Time magazine ought to consider it for the cover page in lieu of other worthy options.
08-03-2020, 03:51 PM | #752 |
Rep 10,319
[QUOTE=azm3;26481338]Powder coated and almost ready to mount! Waiting on a rebuild kit for the rears, will install them next week...
Wow. Exhibition quality outcome. Sharp! |
08-08-2020, 07:21 PM | #753 |
Rep 43
Drives: 2017 X5 35i
Received my E70 x5m calipers from eBay and I must say, I didn't expect them to be this big.. wow.
I cleaned them up using soap and brake cleaner. Sanded them down and masked it. That process took me about 1hr. Next I used VHT primer, paint and clear coat. One done.. I'll be doing the other caliper tomorrow. |
4
08-10-2020, 04:03 PM | #754 |
Rep 43
Drives: 2017 X5 35i
Hey guys,
So I want to install larger rotors on the back but keep my existing calipers. Do I need new brackets to support the larger sized 385mm rotors? I have the x35i with stock brakes. Thanks in advance. |
08-12-2020, 06:45 PM | #755 |
Rep 7,165
This would be pointless friend. Unless you're adding a larger caliper to support a larger pad you will get nothing but fractional heat dissipation. Plus you'll get major uneven wear on the rotor due to the pad not fitting the rotor. Just get the 50i calipers. They're not expensive.
08-13-2020, 09:46 PM | #757 |
Rep 7,165
Up for sale in the classifieds
08-19-2020, 02:48 PM | #758 |
Rep 1,547
Anyone attempt to retrofit the carbon ceramic calipers and rotors? I may have a line on some front calipers and rotors from an M6
08-20-2020, 01:56 PM | #759 | |
Rep 43
Drives: 2017 X5 35i
anyone know what is the max size rotors i can use with the stock rear 50i calipers? 345mm or can i use the 385mm Thanks |
08-20-2020, 01:58 PM | #760 | ||
Rep 7,165
08-20-2020, 02:01 PM | #761 | |
Rep 43
Drives: 2017 X5 35i
X5M rear caliper is hard to come by and very expensive. Im going with the 50i rear calipers. (upgrade over my 35i calipers) |
08-20-2020, 02:03 PM | #762 | ||
Rep 7,165
Edit: one for sale for $243
08-20-2020, 07:12 PM | #763 |
Rep 7,165
They are same size as M5 and should fit the exact same way. Will need adapter for front and rear caliper won't work since it has parking brake integrated
08-23-2020, 07:33 PM | #764 |
Rep 1,547
To the guys running the porsche rear caliper, can you PM me milling instrutions? I plan on buying the brackets from Tronik
08-24-2020, 08:04 AM | #765 |
Rep 1,666
08-28-2020, 06:09 PM | #766 |
232
Rep 337
If anyone did the upgrade themselves: is removing just the parking brake shoes in rear is enough to replace the brake shield? The manual guide says removing the hub. Planning to do my brakes soon, so doing my research
09-02-2020, 01:02 PM | #769 |
Rep 42
BBK getting installed...
20 ///X5MC Tanzanite Blue II Metallic - RachChip, MSS Springs, Cat-back Titanium Exhaust
17 X5 50i Space Grey Metallic - ESS Tune, Catless Downpipes, X5M Air Filters, H&R Springs & Spacers , BBK 96 SC ///M3 Racecar - CP Pistons & Rods, ARP Studs, VAC SC Cams, VF V3 Blower, 12lb Pulley, RK Tune & lots, lots more... |
NYBulldog1312.00 |
09-03-2020, 03:13 PM | #770 |
Rep 42
4
