08-25-2024, 03:43 PM | #68 | |
Rep 14
I'm here rooting for GOrdon. |
08-25-2024, 05:32 PM | #69 | |
Rep 187
I’ll also check the mid i-shaft to see if there is any play. Thanks for the response appreciate it |
08-26-2024, 06:25 AM | #70 |
Rep 72
OK, steering shaft replaced...unfortunately, no changes in the mysterious dull clunk, or as we called it "scuttleshake...
Hmm, thinking of replacing the part above the steering shaft because it also have a play - the steering spindle (part No.2 on the scheme in post #56). Guess I have to sit down and think what part else could be involved here... |
08-26-2024, 11:34 PM | #71 |
Rep 187
Okay so today, did not hear the noise. I’m thinking it might be the front sway bar bushings, not the links. I know someone here mentioned they replaced the sway bar and noise went away. I’m thinking because of the heat they might have swollen and caused the noise to go away.
I’m thinking of ordering the power flex front sway bar bushings(for the regular sway bar not active) and possibly remove the fan assembly and see if I can get access to the bushings. |
08-27-2024, 03:54 PM | #72 | |
Rep 92
So today has been warmish here in the South of the UK and has been a day when I haven't experienced the clunk, knock, damn annoying thing we are all chasing, as "normal". And this despite driving the same roads I do each and every day. I'm not familiar with the layout of the underside of the F15 but what is there underneath around the bulk head, gearbox housing area and towards under the front seats - a cross membre of some sort perhaps? I'm starting the believe this area is the origin of the issue and not suspension. Last edited by seanegee; 08-27-2024 at 04:02 PM.. |
08-27-2024, 04:06 PM | #73 |
Rep 92
08-28-2024, 02:35 AM | #75 | |
Rep 72
The results are that the sound is definitely audible on the driver side - on passenger side you can barely hear it (until yesterday I was pretty sure it can be heard it in whole interior). I've asked him - "so, suspension or what?"... and he said...definitely suspension, as he is 99% confident it's a rubber clunk...I told him I've replaced almost everything in front suspension. And once again we're coming to the sway bar... Basically beside visual control, to check sway bar you have to swing the car from side to side and observe the bushings...two indy shops said to me my sway bar is fully okay, but I'm starting to doubt... too bad in our F15's we can't change just the bushings, but the whole sway bar... |
08-28-2024, 10:10 AM | #76 |
Rep 425
Bummer on the steering shaft experiment. Noise definitely more apparent on driver side. I was a passenger in my car recently and not nearly as noticeable. I think there is something to the sound being sent through the chassis. My mechanic suggested the same.
I’ll try to record my sound this weekend to see if we are all agonizing over the same thing. Now that it’s in my head, it’s 10 times worse! |
08-28-2024, 11:39 AM | #77 | |
Rep 187
08-28-2024, 03:08 PM | #78 | |
Rep 92
08-28-2024, 03:09 PM | #79 | |
Rep 92
08-29-2024, 02:09 AM | #80 |
Rep 72
Correct, the sway bar was inspected by two indy shops, and they said it's fully okay... but somehow I'm kinda afraid the bushings are simply worn out after 276k km...tomorrow I'm going to the dealer - SIB for a driver airbag - I'll ask if they had many problems with the sway bars.
On 5th of September I'm having also a visit in the indy shop (basically the best in my region), we'll be driving with the owner and mechanic to check that noise. At this moment basically the two parts I did not replace are top wishbones (the A-ones) and the sway bar itself... Anybody ever replaced the "A" top wishbones? |
09-03-2024, 07:34 AM | #83 | |
Rep 72
Well, decided to carry on with the topic - this Friday going to the best indy shop in the region to drive with the owner and the mechanic to track that sound. No matter what the result will be, I will also replace the upper control arms (top, A-wishbones), then I will have a complete front control arms refreshment... I'll keep you guys posted on the effects... |
09-03-2024, 09:34 AM | #84 | |
Rep 92
Have you read the other thread i pointed out above? |
09-03-2024, 10:42 AM | #85 | |
Rep 72
You mean the thrust arms topic? In my case it went for the first shot, but didn't changed nothing - they were in quite good condition in the final... The reason why I've decided to pursue with the "A wishbones" is that those control arms are in my car since the factory (and I'm having now 277k km on the desk), where the lower and upper wishbones were replaced 3 times already... Was yesterday also on a Vehicle Control Station (btw, here it's obligatory once per year), and I've asked the guy to check the sway bar and steering rack with "machinery" - he said they are solid as f**k... yhhh. Well, let's see what the magicians from the indy shop will find... |
09-03-2024, 02:36 PM | #86 |
Rep 92
[QUOTE=G0rdon;31438530]No no, still fighting .... :[
You mean the thrust arms topic? In my case it went for the first shot, but didn't changed nothing - they were in quite good condition in the final... The reason why I've decided to pursue with the "A wishbones" is that those control arms are in my car since the factory (and I'm having now 277k km on the desk), where the lower and upper wishbones were replaced 3 times already... Was yesterday also on a Vehicle Control Station (btw, here it's obligatory once per year), and I've asked the guy to check the sway bar and steering rack with "machinery" - he said they are solid as f**k... yhhh. Well, let's see what the magicians from the indy shop will find... Awesome So which parts in the diagram have you replaced so far and are 19 what you're about to do? |
09-06-2024, 03:36 PM | #88 |
Rep 92
