11-27-2024, 09:56 PM | #67 | |
Rep 281
11-28-2024, 09:14 AM | #68 |
Rep 1,503
Drives: X5M, M3 ZCP 6MT, MB E63 AMG
If you install new pads, they will just conform to the rotors surface, if not perfectly straight. After the pads are bedded in, it will be the same as before once the pads and rotors are hot. Keep in mind that yes, these are performance vehicles, but definitely not a true track car. If you truly want to get the best out of your vehicle, I recommend installing dedicated rotors, calipers and track pads. If you truly like to explore that track, an M4 would be more suited for this type of work.
11-29-2024, 07:42 PM | #69 | |
Rep 281
But, still want to track and street race the x5m as the weather's kind of bad now. Also, was thinking of ebc bluestuff vs yellowstuff. See the post here: https://f15.bimmerpost.com/forums/sh....php?t=2150330 |
12-07-2024, 07:52 PM | #70 | |
Rep 281
Did you ever try machining your rotors? Will it crack if you do that?> |
12-08-2024, 09:44 AM | #71 | |
Rep 1,503
Also, a lot of machine shops will not machine rotors that are crossed drilled, as it breaks the teeth off the resurfacing bits they use. Also, the holes need to be chamfered afterwards, as it will create hot spots around the holes, which will cause the rotors to crack along the holes. If the holes aren't chamfered, they will also gouge into the pad surface decreasing pad life. In this case, with BMW M cars it's better to just replace rotors.
12-17-2024, 03:33 PM | #72 | |
Rep 281
12-18-2024, 03:28 AM | #73 |
Rep 21
I can attest to the great braking performance of the Powerstops, with fresh flush of Motul 600 and proper bedding the beast stops on the dime.
Noises are gone not sure about the brake dust since I replaced few days ago. |
12-18-2024, 06:06 PM | #74 |
Rep 1,503
When the rotors gets nice and hot, due to a track days. What happens is that you apply a nice coating of brake pad material to the surface of the rotor, which increases the braking efficiency. But everyday driving quickly removes that brake material.
