01-04-2015, 03:51 PM | #881 |
Rep 3,990
I don't think anyone has attempted this on the F15 yet, so report back if you get it done successfully. Again, all the new codes I've found, I cannot test yet .
01-04-2015, 03:53 PM | #882 |
Rep 265
01-04-2015, 03:57 PM | #883 |
Rep 3,990
I mentioned this in another thread on fest because someone inquired about it. It may not work at all because I believe you have to have the necessary hardware (we are missing the AMP for this setting). However, try it out and report back .
01-04-2015, 03:58 PM | #884 |
Rep 265
We shall C! I know in the older cars this was possible regardless of hardware.
01-04-2015, 08:13 PM | #885 |
Rep 1,771
Hi opasha and everyone else,
Just came back from Coding Session 2 and did a lot more. It turned into a circus of warning messages and error codes, some as serious as telling me stop driving and to call service center, I guess it was part of coding process as the only thing it left me with was reset EQ, time and reset trip computer. I remember reading somewhere about setting the time manually instead of auto, was that before or after coding or was it for something specific? When I tried code the VLD, I noticed the value in BDC_BODY/3073/LUT_FLC_FORWARDLIGHTING_Y/F015_ohne_AFS Change to: F015_mit_AFS ...is actually a whole lot more than just this, I have all these: Do I change all _ohne_'s to _mit_'s? Is this because I have LEDs? Also, like you said, Open/Close Window via Keyfob and Close Window via Comfort Access were already aktiv as default in my X5. Also HUD Turn Signal works beautifully. Editing all others in Window/Mirror enabled mirrors to fold instantly with keyfob! Nice! And Disclaimers are gone! Bye Bye nag-screen.
2024 X3 m40i
01-04-2015, 08:22 PM | #886 | |
Rep 3,990
Regarding Date/Time. This will ALWAYS happen with Kombi coding. You just go into your iDrive Settings>Date/Time and uncheck the Automatic Time box and Recheck it (so it resyncs - it will return to normal within seconds to minutes and the code will disappear). Regarding VLD - you have to change it to whatever is related to F015_enable etc. That will give you the important Werte = 9C9C9C - this tells you it's activated. If I were you, do all the window coding (some are aktiv and some are not - you will know by checking them) to guarantee that the side mirrors fold correctly with respect to timing and keyfob.
01-04-2015, 08:22 PM | #887 |
Rep 13
I was coding VLD and Enhanced Bluetooth (6NS) today, and accidentally chose ALL ECUs to be coded, instead of only BDC_BODY and HU_NBT, respectively.
Car showed a lot of warning messages, but everything drove fine and operated ok afterwards. Have I done any harm to the electronics or codes? I am thinking that I likely just reset all ECUs and folders to their default settings? |
01-04-2015, 08:26 PM | #888 | |
Rep 3,990
01-04-2015, 08:39 PM | #889 |
Rep 265
k just finished my coding session. Here's my notes:
The B&O menu didn't do anything. I noticed several Audio related options, especially related to "eq-set". I'm just wondering if the right combination of audio sets and variants in the 4 or so related audio settings will do the trick..... I could not get Eco-pro Sailing option to come up. I did not have a DME module only a DME2 and the DME2 did not have the options listed in the cheat sheet. Comfort access closes the mirrors without a 1.5 second hold. Pretty instantaneous. The logo tach display seems to only either display M550d (x5 mid/high) or nothing (BMW/MPM). Did not bother to try the X6 setting. The multiband EQ is my coding goal!! |
01-04-2015, 08:45 PM | #890 | |
Rep 3,990
Here's the full ECO PRO SAILING coding. I just went over it with Trojanlaw , and the second ICM code doesn't exist. HU_NBT SAILING_COUNTER: aktiv [01] EFF_DYN_SAILING: aktiv [01] EGS Segeln: aktiv [01] ICM C_Segeln_vorhanden: enable [01] IcmKod_B_AuskuppelnOK: aktiv [01] KOMBI SEGELN_ENABLE: aktiv
01-05-2015, 12:07 AM | #893 | ||
Rep 1,771
As for VLD, "F015_enable" is in C_AFS_ENA, but I am referring to LUT_FLC_FORWARDLIGHTING_Y. Cheat Sheet says default value should be "F015_ohne_AFS" but my default value is F015_ohne_AFS, F045_ohne_AFS, F056_ohne_AFS, I001_ohne_AFS, M013_ohne_AFS This is why I didn't want to touch that. I couldn't tell if I am supposed to remove all those and replace it with F015_mit_AFS or keep everything else and replace only the first value. Strike all above, Mat3333 confirmed here that they automatically change when you select, though his and subsequent screen shots show M013_ohne_AFS missing in their lists. http://f15.bimmerpost.com/forums/sho...&postcount=715 I know if I did VO coding, I wouldn't need to worry about that, and I can just come back and check this, but after all the FDL coding, honestly I don't want to go through all those again by losing them with VO coding. I am going to read back to VLD posts, maybe this is mentioned. I always assumed I'd do VO coding, but now that I did VLD, I will have to re-read some of those. Yep, I did all window codes and folding works great! Quote:
Like opasha said, I hope your car is all back to normal.
2024 X3 m40i
01-05-2015, 12:39 AM | #894 | |
Rep 13
The car is running normal and fine. There appeared to be no error codes that required clearing with the Transmitter. |
01-05-2015, 01:31 AM | #895 | |
Rep 3,990
hyde , good stuff .
Also, a reminder again for everyone. NEVER hit the button that says CODE DEFAULT VALUES (this is close to bricking your car - always leads to issues)
01-05-2015, 02:58 AM | #896 | |
Rep 37
Would you please send me the download link for PSdZData files 54.2. Thanks! |
01-05-2015, 02:59 AM | #897 |
Rep 3,990
PM sent .
01-06-2015, 01:58 AM | #900 | |
Rep 13
Dumb question but, does VLD require the rear-view mirror camera in order to operate correctly? I only have Driver Assistance Package and Surround View standalone, but not the Driver Assistance Plus. |
01-06-2015, 03:18 AM | #901 |
Rep 37
Hi Opasha,
I have tried to upgrade the PSDZdata by delete the old PSDZdata folder and copy the extracted folder to the c:\Data path, but when I load E-sys, the PSDZ version still stays at 5.0.1 not 5.4.2. Would you please advice. Thanks! |
01-06-2015, 11:01 AM | #902 | |
Rep 3,990
I can help you via Team Viewer (PM me your id and temporary pw). My advice is to make sure that the data folder was renamed to psdzdata.
