08-03-2020, 03:15 PM | #89 | |
Rep 949
08-06-2020, 09:02 AM | #95 |
Rep 1,025
One of my favorite things
Steve::::2012 AW E92::::IG - @sjs0433
08-06-2020, 09:11 AM | #96 |
Rep 1,025
I need to take some photos but I did get the Recaro bucket installed and was able to go for a quick drive.
The switch to the bucket dropped ~20lbs off the car. I think the weight difference between the Sportster and Pole Position on my non scientific scale was 22-23lbs and I'll say the rail components are a wash. I did find a piece on the OE slider that appeared to be not needed so I took it off too. Like others have noted if you just slap the rails on in the same positioning for OE rail you'll end up with a seat that's a bit off center towards the door. What I did was mount both brackets on the side of the rail that put them towards the center of the car (Brey Krause even notates you can install them on the inside or outside of the OE rail) and then due to the width of this seat I also spaced out the most inner rail even farther towards the center using some of the supplied spacers from BK. This seemed to shift the seat just enough inward that it looks centered to me. The seat sits a solid 2" lower than stock and I have it mounted on the highest holes available. The pedals feel easier to use too sitting lower and the whole car just feels different now that I'm lower and more secure. I'm looking forward to getting in a bit more driving with this. Getting in and out does require just a bit more effort but I'm used to getting in and out of this very seat from a S2000 which is lower and has a smaller door opening so it feels pretty easy in the M3.
08-07-2020, 04:19 PM | #98 | |
Rep 148
I recently switched to MCS 2WNR as well and have a few thoughts from my experience. 1) For the trunk trim, I used a drill and then tin snips to cut 'windows' to access the rear shock adjustment knobs. Happy to take photos if you want an idea of what someone else did. 2) I found the factory compression settings to be too soft. I'm on 600/900 springs mind you, but I have the front compression on 8, and rear on 7. I did however find the factory rebound to be too fast and bouncy for road driving, and have that down to 6 now. On the track I run 8/9 for the rebound setting. Enjoy the setup - I'm in love with mine!!
Mods: Akrapovic Evolution System / AlpineMSS Stage 2 Tune / MCS 2WNR / RTD V4 Carbon SSK + DSSR
//steve\\1074.00 |
08-10-2020, 07:45 AM | #99 |
Rep 2,091
Man those brakes look amazing behind the E88's!
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
//steve\\1074.00 |
08-10-2020, 08:20 AM | #100 | ||
Derbo Tuning
3613
Rep 3,031
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
Drifter2090913.50 |
10-27-2020, 03:22 PM | #101 |
Rep 1,025
I've had the car for 1 year now!
I'm long overdue for an update. Recaro Pole Position on BK mount I still love having the Recaro bucket so I haven't swapped it out at all. I have noticed a buzz when the car is idling that seems to be coming from the rail that goes away when I sit in it. I may need to double check all bolts. The BK mount is incredibly sturdy though so very happy with it. I may try to rig up my electric sliders from the OE seats with these but not something I'm in a rush to do. The seat really does make a solid difference in the way the car feels and letting you feel what the car is doing. The downside of running a bucket seat is it's very hard to go back the other way once you've experienced it. I may feel differently if it was a daily driver but it's not. I may look at a Leather Pole Position ABE down the road so that I can have the bucket and something that matches a little better. CarboProject Plenum I got in on the CarboProject plenum group buy and was in the first round. The part looked amazing but for me the sound wasn't anything close to different enough to be worth keeping. When I opened the box I was very excited with what I saw. It seems as though they made a slightly change to comply with TUV regulations and made the lid a bit thicker than previous versions. For the second round they offered an "export" version that had the original thinner lid that likely would have given me the sound I wanted. I will note my car has a BMC filter and at least one other member noted the same thing that with the BMC filter the plenum made almost no change in sound. A bit disappointing as we weren't notified of this change and I'd bet most people bought it for sound, not the look of a carbon lid only. Stock is back on the car and will likely stay until I just buy a full carbon Eventuri or Karbonius. DO88 Transmission Cooler removed I finally removed the DO88 trans cooler and put the stock one back on. This was an item on my list from day 1. I assumed it would be messy and it wasn't at all. I did decide to change the trans fluid while at it so that may have helped. Now that I've driven around the car a few times since I should probably check the fluid level again. Everything feels good. I'll note that for anyone with a manual the OE cooler has a plate blocking airflow to half the unit so if you think you may need/want a little extra cooling it's as simple as remove the bumper and pull the plate. Double the airflow for $0. While I haven't been around these cars for too long I've never once come across a documented issue of trans fluid temps/issues on the manual. I do know it's a serious issue for DCT cars that are tracked but not the case for me. Coolant/Rad hose maintenance I noticed when doing the Carbo plenum that the upper rad hose seemed to have a drop or two of fluid on the bottom where it meets the radiator. It's a cheap part so I'm just going to replace it and do a coolant flush. I also noticed the small hose that runs to the reservoir seemed as if it was leaking from the inside out...not to the point of leaking wet fluid but the end of the hose kind of had dry crusty coolant. I bought a replacement part for that and will just do it all at once. Works for me because I have another part to install that requires pulling the fan and I can do it all in one shot. BBS RIA replacing the E88 I've had my eyes on the RIA for a long time now and despite trying to look at every single picture of them I could find on the Internet I still couldn't decide if I really liked them so I bought a set. I'd love to have kept both but just not in the cards especially when I have a huge list of other wants. Wheels are 18x10 +25 front and 18x10.5 +22 rear. I'm running the same 265/35 and 295/30 Michelin Cup2 tires that came off the E88. I've always personally preferred the one piece/monoblock wheel to a multi-piece wheel. That said now having had both I think for the E9x I ever so slightly prefer the multi-piece. I have a few other ideas and I could possibly end up on E88s down the road again. For now I think I'll hold off until these tires are dead. A few shots of how the car sits today What's Next? Near future I'll do some kind of primary cat deletes and get the Stage 2 upgrade for Epic tune that's on the car now. I picked up some Rouge Engineering pulleys as well so I'll do those when I fix the radiator hose. Aside from that it's going to be some basic maintenance. For 2021 I'd like to work on the car a bit less and drive it more. Hoping to do 1-2 track days.
10
e92BMW///M3126.00 reidetailing643.50 911r907.50 SAMM3Y3086.50 E90M3velocity339.00 Rusty_Schackleford501.50 ///Mobbin1478.00 roastbeef11593.00 Drifter2090913.50 slcook541863.00 |
10-28-2020, 05:58 AM | #104 |
Rep 1,025
It's pointless for a manual trans car. No one has ever reported cooling issues with the manual trans. BMW even has half of it blocked from the factory. If you think it needs more cooling, just pull the block off plate and you've doubled airflow through it so that's what I did. It also adds a bit of weight up front which is the last place I want it. I'd argue it's negligible as it's probably less than 5lbs but still, principal of it all.
10-30-2020, 12:39 AM | #105 |
Rep 12
Drives: 2011 BMW M3 E90 ZCP
Wow, truly impressive build. I really enjoyed reading your awesome journey. What’s next?
11-20-2020, 09:45 AM | #108 | |
Rep 1,025
If you aren't racing I'd seriously look at the non FIA certified ABE version you can only buy out of Europe. It's a little more every day friendly. Just a little extra room at the hips and I believe the upper part of the seat is just a little more open/flat than the standard.
Drifter2090913.50 |
11-20-2020, 09:56 AM | #109 |
Rep 1,025
I did also finally replace my leaking upper radiator hose. I still can't see what was wrong with it. I just started to notice a drip or two under the car on occasion and found that the bottom of the hose where it meets the radiator felt wet. It's a cheap part though so why not.
While I had the hose off I pulled the rad fan too so I could install the Rouge Engineering pulleys so we'll see if those make any difference at all driving the car. Install was pretty simple/straightforward on those. Parts quality looks good too.
wyatth3553.00 Drifter2090913.50 |
11-20-2020, 10:10 AM | #110 |
Rep 2,672
Just came across this thread, great photos throughout and great looking car!
I also have an alpine white E92 and silver RIA's so I may be a bit biased, hah.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
//steve\\1074.00 Drifter2090913.50 |
