      09-18-2017, 10:16 PM   #89
anon1000
Drives: bmw
Originally Posted by BeeMdblU View Post
yes we see them with wert values only, no more color drop downs
Are you able to change the colors with hex value? Curious if you can still turn yours red?
      09-19-2017, 03:12 PM   #90
anon1000
Drives: bmw
Just tried with eSys and cable. The BDC 3070 shows only 6 groups with 8 layers similar to bimmercode app, and no matter what you change for the values, they wont change the ambient lighting colors anymore. Really disappointing as the Red was a great color at night time. Watch out with new SW updates, you will lose the hellrot color many use for all layers.
      09-21-2017, 04:28 PM   #91
x5stan
Drives: x5
Awesome pics
MrTookies459.00
      09-24-2017, 09:27 PM   #92
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
Originally Posted by wilho View Post
Hi,
Did you ever found a solution for this, I'd also like to get blue colors to stay also after i've opened the door. And no I haven't coded anything yet.
BR
Originally Posted by HZX540e View Post
In my F15 40e when I unlock the using the remote the interior dome (the ones above the doors, not the small light the lights up the over the center of the car) colors light up blue and when I open the doors they turn white. When I went to Group 0 ensemble 2 was weiss but I noticed that layers 1-3 were blau_F15_PHEV and as expected layers 5-8 were inaktiv. Group 0 ensemble 3 was weiss and layers 1-3 were also weiss
Any how, what I would like to do is when I unlock the door the blue dome lights come on (which already happens) ALSO when I open the doors I would like the blue lights to stay on (currently they turn white). What do I change to get the desired outcome?
Sorry no
      10-09-2017, 01:24 PM   #93
lee888
Drives: x5
Hi,
Just saw the ambient light coding,changed the colour to violet(wife’s choice) the dash and top part of doors are in this colour but the lower parts are still in original colour?
How to code the rest to the same all round please anyone?
      10-09-2017, 03:37 PM   #94
sbinshihon
sbinshihon's Avatar
685
Drives: X5 M Sport
Originally Posted by lee888 View Post
Hi,
So you need to change (ENSEMBLE_1_LAYER_1) and (ENSEMBLE_1_LAYER_2) and (ENSEMBLE_1_LAYER_3) That way you can match the three light strips on the dash, doors and the leg area.
      10-09-2017, 11:33 PM   #95
lee888
Drives: x5
Thanks I shall try that out later,I only followed the example coding where it only mentioned layers 1and 2 didn’t realise you had to code the (ENSEMBLE _1LAYER_3) as well?
Lee888
      10-19-2017, 07:25 AM   #96
Woolf
Woolf's Avatar
Drives: X1 Sdrive 18d - F48
Same here. After SW update I get 6 groups with 8 layers...Well group 6 has only two in fact.. Some of them are active, some aren´t.. All in UNK_PARAM_0 or UNK_PARAM_1 form and with hex values (werte) like 00, 9D, DC, 48, FF, 29 etc...
Does anyone know what values to put in order not to get UNKNOWN parameters and actually change the colours? The hex values for all possible colours would be nice... Anyone? Shawn maybe?
Has anyone tried to change this value: AMBIENTE_GELB_ANTEIL_ROT? It should define the percentage of red colour within the orange colour mix of yellow and red.?? It has only one value possible: wert_01 which coresponds to value (wert) 46... Not sure if this is hex or dec value though... Tried to set it to 64 (hex for 100%) and also to 99 - dec... Both result in UNKNOWN parameter when saved... Haven´t tried them out yet in the dark... What value should I put in in order to get more red within the colour mix for orange?
Thanks for the help.
      11-09-2017, 07:35 PM   #97
Nison
Drives: 2021 G05 40iX
i'm in the same shoe... got the SW update today and WTF...
      12-16-2017, 10:47 PM   #98
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by smercki View Post
Hiboys
I have an problem
on F15 2014 with nbt I have upgrade Nbt Evo
All work fine accept switch selection colour
there is no correspondence between the selected colors on the i-drive and the setting
any know how change for correct setting?
Thank you
Are you saying that when you select a color scene in the iDrive menu it doesn't change the ambient lighting? Or something else?
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      12-17-2017, 05:40 PM   #99
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
If I know what you're saying then I think this is what's up. So when you change the colors in the software it WILL NOT change the label or name of the scene. the names in the iDrive menu are defaulted and stay as programmed. You just need to memorize what new color scheme you design to which sub layer
'06 C55 AMG (sold)
      01-11-2018, 06:21 PM   #100
Koer
Drives: F15 X5 2014 Sec. 50i
Same problem here after update, seems the codes were moved elsewhere. Any coder that can help?
      01-22-2018, 09:43 PM   #101
fosterelli
Drives: 2014 X5 xDrive35i M-Sport
I've coded all different groups of colors for ambients - awesome.
However, the DOME settings...
Does this mean you can change the color of the dome (overhead) lights from white to orange? I tried several times but my domes are white after days of trying. Has anyone successfully changed their dome lights, or am I misunderstanding something?
Thanks in advance.
2014 X5 x35 F15
      01-23-2018, 07:21 PM   #102
fosterelli
Bumping this because the suspense is frickin' killing my dome.
2014 X5 x35 F15
      01-23-2018, 07:44 PM   #103
MrTookies
MrTookies's Avatar
Drives: 2011 E90 328i, 2015 F15 35D
I have my dome light coded...and all other layers... haven't had an update done recently but let me check for you all this weekend...
      01-23-2018, 10:51 PM   #104
fosterelli
Thanks. To confirm, your dome lights are not white after coding?
2014 X5 x35 F15
      01-26-2018, 01:34 PM   #105
fosterelli
My last bump to see if anyone knows anything about the dome light coding.
2014 X5 x35 F15
      01-26-2018, 01:37 PM   #106
MrTookies
MrTookies's Avatar
Some of my color configuration have white dome light and some orange... that's the only option possible. And like I said I will look at it this weekend when I get some time.
      01-28-2018, 05:51 PM   #107
fosterelli
Good to know, I figured it must be possible but no one has confirmed dome changes except you...I guess I'll re-study the ambient sections of the tuning threads...because for the life of me I can't get mine to change. Everything else changes as described.
2014 X5 x35 F15
      01-29-2018, 04:45 PM   #108
MrTookies
MrTookies's Avatar
All,
...Alright so I checked my coding and it's still indeed the way I described it in the first post of this thread under "Colors available". Maybe post a pic of what you are seeing or not seeing different? Possibly I can help clarify when I see what's happening...
      01-30-2018, 06:54 PM   #109
fosterelli
So when you say dome, do you mean the ambient overhead "always-on" lighting, or do you mean the dome light you physically push with your hand to turn on/off?
2014 X5 x35 F15
      02-01-2018, 11:19 PM   #110
willconnect
willconnect's Avatar
15
Drives: X5
Also same problem after my F15 came back from Dealer. Changed from 8 to 6 groups and no more color selection. Hopefully some experts can help us all.
