      10-08-2018, 09:26 PM   #89
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1673
Drives: ///Ⓜ️
Originally Posted by r33_RGSport View Post
Originally Posted by F85MTuNED View Post
Where do I purchase bump stops?
I can get you Dinan's.
Ok I'll be ready soon so I'll reach out for whatever I need when I'm ready
IM POOR..
r33_RGSport13885.50
      10-09-2018, 01:53 PM   #90
Kruppa
Drives: 2023 M5 Comp & 2024 X7
One point of clarification I just got directly from H&R as it relates to VTF and the quoted drop range. I have no idea why, but everything they list is for the F15 X5, not the F85 X5M which is 10mm lower. So when you see the drop listed as 1.4" to 2.2" front and 1.2" to 2.0" rear, you deduct 0.4" from that. For people like myself who want a more moderate drop that is great to know that I could lower 1" from where it is now whereas before I thought 1.4" was the minimum.
      10-11-2018, 02:42 PM   #91
HDEddie1
HDEddie1's Avatar
129
Drives: X5 40i, X3M40i, Audi SQ5
Compatible with Rear axle Air Suspension?
This is H&R new product.
I just installed it locally and ride is different than the H&R Sport spring.
It is better.
It is only available for self-leveling suspension, which is standard on X5M/X6M.
My 2016 X5s-drive (2 WD) came with "Adaptive M Suspension + rear axle air suspension". Will the H&R VTF work? Thanks
r33_RGSport13885.50
      10-11-2018, 03:34 PM   #92
Yes, it will work.
PM for everyday DEAL!!
Active Autowerke • KW • H&R • Ohlins • Remus • CSF • SPL and more...
      10-23-2018, 12:16 AM   #93
Dan_Halen
Drives: M4
RG- can you comment on the ride quality of Dinan Vs the Eibach vs the H&R? I saw another post of yours discussing the H&R and eibach some really make the ride noticeably harsher. Can you comment about how Dinan effect the ride quality- from comfort setting to sport+?
      10-23-2018, 09:13 AM   #94
I am not even going to mention Dinan.
Because it is not a lowering spring or even an upgrade.
IMO, it is just a waste of money.
You will not notice the ride quality difference on Dinan vs Stock. If you do, then it is placebo effect.
      10-25-2018, 11:47 PM   #95
Dan_Halen
Drives: M4
Thanks for the feedback
      10-30-2018, 04:45 PM   #96
Johngm45
Drives: 535xi m sport
Looks great. I just added the Vossen HF2 in staggered 22” and think I’m going to do the same
      11-02-2018, 07:44 PM   #97
Logical
Drives: 2014 M5
Here is the listing on eBay. It sits nice too bad we can't figure out how they lowered it
2010 BMW X5 -- https://rover.ebay.com/rover/0/0/0?m...2F132827194270
2017 F86 X6M
2014 F10 M5
2015 F85 X5 M
2015 F86 X6 M (Retired)
2014 F10 M5 (Retired)
2010 E70 X5 M (Retired), 2010 E92 M3 MT (Retired)
2006 E60 M5 (Retired), 2000 E39 M5 MT (Retired)
1999 E39 328i (Retired), 1995 525i (Retired)
1987 325i (Totaled - that was fun!)
      11-03-2018, 02:50 AM   #98
That seems to be H&R lowering spring.
But you can for sure achieves that look by using KW V3 coilover.
      11-03-2018, 07:42 AM   #99
Logical
Drives: 2014 M5
Do these pics look like H&R or KW V3s? The seller keeps suggesting that it's OEM suspension and someone hacked the ECU to lower it via the self leveling. He says he has bmw software tool and it's possible it can be achieved by changing values in the software.
QUOTE=r33_RGSport;23939034]
But you can for sure achieves that look by using KW V3 coilover.[/QUOTE]
2017 F86 X6M
2014 F10 M5
2015 F85 X5 M
      11-03-2018, 01:09 PM   #100
[/QUOTE]
That looks to be a best up OEM.
Not KW V3 for sure.
Try to clean up that spring and I should be able to tell better.
Even with BMW computer, you will only be able to adjust the rear, since it is a self leveling air suspension on the rear.
Computer can't tell spring to change its density, but can tell the compressor to put less air in the air bag.
      04-17-2020, 03:44 PM   #101
Shuja_a
Shuja_a's Avatar
Drives: 2021 X5M Competition
Could you get me a quote of the complete set-up. The kit and all necessary bump stops.
Thank you!
      04-17-2020, 03:53 PM   #102
Thank you!
PM'ed.
Shuja_a70.50
      04-22-2020, 09:46 PM   #103
Jerez_M3
Jerez_M3's Avatar
12
Drives: Jerez Black E92M3
PM'ed.
Could I also get a quote of the complete set-up. The kit and all necessary bump stops. 2016 X5m Thank you!
      04-22-2020, 09:55 PM   #104
PM'ed.
PM'ed.
      05-02-2020, 02:34 AM   #105
Travis1807
Travis1807's Avatar
Drives: 2016 X5M
Originally Posted by elm3 View Post
The kit does not come with bump stops, you have to use the OEM ones. But if you lower the X5M down all the way, which is 2", you will be ridding on your bump stops. Which will cause a harsh ride and a very bouncy ride. As far as the camber, it will tilt the wheels in the negative side of the camber spectrum. Pass the OEM values. The rears have adjustments on camber, but not the fronts. So you will need a camber kit, to be able to adjust the camber back to OEM specs.
How did your camber kit end up working?? I'm in need of one and could use a recommendation, please
2016 X5M
JB4, DME Tune, Full Custom Fab Worx Exhaust w/ Straight Pipes and Cutouts, KW V3, 22" BC Forged Wheels, Brembo BBK on all 4 corners
      05-13-2020, 10:56 PM   #106
elm3
///M Fan
elm3's Avatar
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
2017 BMW / X5M  [9.00]
2009 E92 M3  [10.00]
2004 Yamaha R1  [10.00]
I need to find the brand of the upper control arms that I used to correct the front camber.
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
      05-14-2020, 11:51 AM   #107
KCTiger
Drives: 2016 X5M
Might have seen this in other threads but, with classic_erik 's help, I am getting upper control arms for the rear and adjustable bushings for the front. Now if there is an adjustable control arm out there, that might change my tune. But I would still defer to all you smart and knowledgeable guys out there as I don't have a clue which would be better.
Front: KMAC 193816-5J
Rear: SPC 72115
And in the spirit of information sharing, I was quoted $600 for install on the bushings, $480 on the control arms.
      05-14-2020, 07:23 PM   #108
KCTiger
Drives: 2016 X5M
Got another quote, $800 including alignment. That almost seems too low.
      05-15-2020, 05:31 AM   #109
Travis1807
Travis1807's Avatar
Drives: 2016 X5M
Do you remember what your negative camber was in the front and rear after your initial alignment?
I go next week to get new tires/alignment and have my KW V3 lowered and adjusted. Currently just by looking at my tire wear on the rear my neg. camber is horrible and my fronts look to be in tolerable specs. Just wondering how much neg. camber is to much.
I guess the ? is what would cost less new tires more often or just buying the rear upper control arms. Sounds like the control arms and installation are close to a new set of tires considering I paid less then $600 for the new tires.
let me know what your opinion is or what made you jump on getting the rear upper control arms? thanks
2016 X5M
      05-15-2020, 07:23 AM   #110
KCTiger
Drives: 2016 X5M
It's aesthetics and tire wear for me. I am going to be getting new rims and want a flush not tucked look if I am going to be spending the $$.
Attached is my alignment sheet.
Copyright ©2000 - 2025, vBulletin Solutions Inc.
