07-14-2014, 12:30 PM | #89 |
Rep 5,262
interesting... did you compare it with the cruise control speed....?
my BC_Digital is off about 1 mph from the cruise control speed which seems odd... maybe the Korrektur is to match BC_digital to cruise control speed... ? |
07-14-2014, 02:45 PM | #90 |
Rep 607
Drives: 2019 BMW M2 Competition
My BC digital is 1 mph off from cruise as well. It is -1 MPH than what cruise said my speed was when I set it. Cruise said 75 mph bc said 74 mph
2019 F87 M2C, Long Beach Blue, Exec, 6MT 2016 F87 M2 - Sold 9/2018 2014 F22 M235i - Sold 5/2016. |
07-14-2014, 02:48 PM | #92 |
Rep 607
I dont believe so, unless it is default. What module is that located under? Is that the speed curvature fix?
07-14-2014, 04:01 PM | #94 |
Rep 607
07-14-2014, 10:38 PM | #95 |
Rep 176
Anyone has an idea?
07-15-2014, 08:31 PM | #96 |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
07-15-2014, 08:56 PM | #98 |
Rep 5,262
added to the sheet
Allow to import routes Yes HU_NBT 3000 NAVI_TRIP_IMPORT nitch_aktiv aktiv now you can do stuff like Trips need to be in BMW format .tar.gz and stored in a usb stick in BMWData\Navigation\Routes folder Then go to Navigation Menu - My trips - Import from USB |
07-16-2014, 01:01 AM | #99 | |
28
Rep 333
Where do I remove 5AC? |
07-16-2014, 02:32 AM | #100 |
Rep 5,262
You don't have to remove 5AC (high beam assist) you need to remove 5AP(Decoding anti-gl. high beam assistant) and VO code FEM_BODY
but that's the same as adding those 3 entries... Are you sure the the high beam wasn't coming on/off individually? The tunnel thing might be only if you have LED high beams Do you have any KAFAS or FLA ecu on your list ? You can try coding the variable light distribution by changing these also (maybe you need this too for the anti-dazzle to work): Variable light distribution Yes FEM_BODY 3073 C_AFS_ENA nitch_aktiv aktiv Variable light distribution Yes FEM_BODY 3073 LUT_FLC_FORWARDLIGHTING_Y 9C 9C B0 9C 9C 9C |
07-16-2014, 11:07 AM | #101 |
28
Rep 333
I'm pretty sure it wasn't just one high beam off, because I also looked at the instr. cluster and noticed the high beam symbol was gone when the high beams went off.
I did code both entries for the variable light distribution, which I presume is the same as removing 8S4? and I have the same low beam effect as shown in your video. Have you tried to change the speed thresholds for the different patterns of low beam? 68mph for highway speed is too high considering the speed limit is only 60. I would like to make it 50mph. Not sure what KAFAS and FLA are, but I think I have FLA. |
07-16-2014, 11:24 AM | #103 |
Rep 5,262
in the same way you have a FEM_BODY on the SVT list check if you have FLA
haven't tried changing the speed thresholds this are the 3 settings for anti-dazzle 3073 C_HBA_ENA 3073 C_HBA_GRHB_ENA 3073 C_HBA_ADAPT_SHUT_ENA One guy also got the FLA module changed DFL_Vehicle: Verbaut but not sure if you have it or not as i don't have it cause i don't have HBA |
07-16-2014, 11:26 AM | #104 |
Rep 5,262
07-16-2014, 11:31 AM | #105 | |
28
Rep 333
07-16-2014, 02:46 PM | #106 |
28
Rep 333
I found another issue with AC after coding. I coded it to remember last AC setting but now when I turn off the engine the AC shuts off before I open the door.
For some reason the auxiliary ventilation is also grayed out after I used it once yesterday and turned it off subsequently. Weird. |
07-16-2014, 02:57 PM | #108 |
28
Rep 333
Under Settings->Climate you'll see Auxiliary Ventlilation or Comfort ventilation (can't remember which one). If you turn it on, it will open the vents and use the fan to vent the car for 30min after you turn off the engine and lock the doors.
The other two options are timers for the same function to work at your designated time in the next 24hours. Last edited by lichenlt; 07-16-2014 at 03:08 PM.. |
07-16-2014, 03:09 PM | #110 |
28
Rep 333
Do you know what might be the problem with the AC shutting off along with the engine?
I should clarify, it's the entire climate control that I wanted to keep on after I turn off the engine and before exiting the car. Last edited by lichenlt; 07-16-2014 at 03:28 PM.. |
