      02-12-2020, 10:54 AM   #1431
Red Bread
Drives: Smog machines
Does the 2er still have the same terrible handling of the 1er? $5k might get you a properly sorted suspension. Face it, the Supra is a smaller, better tuned and more focused car. It's been putting up faster track times than the M2C on many tracks. No one has ever said that about an M240i.
I agree that having a manual available is nice, but you'd still have to factor in the price of an LSD, and of course it would be slower. Sure seems like comparing the Supra to an M2C would be a better starting point.
      02-12-2020, 11:45 AM   #1432
stein_325i
Ring Leader of G8X Haters
stein_325i's Avatar
25176
Drives: A Car
You are in a very small minority if you think the 1er doesn't handle well.
      02-12-2020, 11:50 AM   #1433
Red Bread
I owned one for four years. Awful. The 1M fixed it all, but that was just fixing all the things that they dumbed down from the 3er in the first place.
Stupidly harsh, way too stiff rebound control, no LSD, narrower track than it should have had, sway bar ratios were all sub optimal and the absurdly heavy steering. Even the six puck brakes didn't work properly and ate their seals under mild driving.
Every time we had an E9x loaner I realized what a mistake we'd made in picking that car. Worse, I drove my Z3 M Coupe every day. Kind of funny when a car with rear trailing arms and two piston sliding brakes works so much better.
This was with PSS non run flats. The stock RFTs went in a hurry, they just amplified the bad though, removing them helped, but certainly didn't fix anything.
      02-12-2020, 12:23 PM   #1434
N54Yankee
N54Yankee's Avatar
Drives: N54 135|Cobb|M3 control arms
Anyone who’s taken a stock 135 to the track or hit an on-ramp quicker then a SUV finds out pretty quick that they have a tendency to push. Even Randy here talks about its characteristics in stock form. Most owners can admit that they’re not fine handling sports coupes straight from the factory for many of the reasons Red has stated.
A tune quickly, cheaply removes his complaints about unsatisfying top end power and some suspension mods make the push issue almost disappear.
"The Constitution was never construed to authorize Congress to infringe the just liberty of the press, or the rights of conscience; or to prevent the people of the United States, who are peaceable citizens, from keeping their own arms.” Samuel Adams
Red Bread4465.00
      02-12-2020, 01:06 PM   #1435
Red Bread
I didn't complain about the power. That N54 was a peach. Much better than our later N55 and I actually still like it more than the B58. Ours was JB4'ed, but even stock those are still great motors.
      02-12-2020, 01:07 PM   #1436
stein_325i
stein_325i's Avatar
25176
Drives: A Car
I was just referring in general to the car's handling not specifically on track.
      02-12-2020, 01:24 PM   #1437
N54Yankee
N54Yankee's Avatar
I specifically mentioned on-ramps to demonstrate that the handling characteristics also apply for the street. I’ve been around this forum since 2010 before becoming a member when I bought my 135 and many here have complained about the cars street handling shortcomings and made efforts to successfully correct them, I wasn’t just referring to hot shoes on a track.
      02-12-2020, 02:19 PM   #1438
Red Bread
Like I said, just swapping the E9x parts back on helps immensely. I really don't understand why they handicapped the 1er so heavily. Hopefully they didn't do that again to the base 2er.
      02-12-2020, 03:09 PM   #1439
FuriouslyFast
Drives: Miss Daisy
Originally Posted by Fitz335 View Post
Throw a tune on the M240i and they're the same car. 3.8-3.9 second 0-60.
I'm talking st v stock.
No sunroof option for Supra? I'd be out too!
It should have been targa
      02-12-2020, 03:30 PM   #1440
XutvJet
Drives: 2011 Cayman Base, 2016 M235
In BMW's own testing, the M235 on PSS tires and the optional LSD outran the 1M on the Ring. Overall, the M235/240 are better handlers than the 1 series for a multitude of reasons. In a Road Track comparison test, the M235 6MT/LSD was less than 0.5 seconds behind the M2 (N55) 6MT on a 2 mile road course with the same professional driver. The M235 is shod with narrower tires, smaller brakes, and less power than the M2. From the seat of the pants, the M2 feels more dialed in and focused than the M235/240, but the numbers don't show a huge difference. Simply adding 245 width front tires in place of the 225s makes a big difference. Lastly, most M235/240s are Xdrives with open diffs and narrow run flats. The handling would be pretty terrible by sports car standards.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
Red Bread4465.00
      02-12-2020, 03:41 PM   #1441
XutvJet
I continue to scratch my head about this N54 "power". The 2014+ EWG N55 in the M235 makes around 310whp/330wtq stock and the M2 N55 makes around 330whp/370wtq (Dynojet numbers). Even better, the power peaks at 6200rpms and holds 90%+ of that power to 6700rpms. Show me a stock N54 that makes that sort of power or doesn't lose a ton power after 5500rpms. In tuned form (pump gas or ethanol) and assuming you don't swap out turbos, the EWG N55s tends to make a little more HP, more TQ, and it's power band is wider. In general, making for a quicker and faster car.
      02-12-2020, 03:53 PM   #1442
Red Bread
Never seen a stock N55 hold power up high. This is base to base, you should see similar comparisons to the 1M vs M2 non comp curves too. The S55 and S58 clearly don't have these shortcomings.
[IMG]https://cdn.bmwblog.com/wp-content/u...N54-vs-N55.jpg[/IMG]
[IMG]https://cdn.bmwblog.com/wp-content/u...ue-750x500.jpg[/IMG]
      02-12-2020, 04:17 PM   #1443
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
What is "handling" if it's not specifically on track? Track is the ultimate gauge in how a car "handles."
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
      02-12-2020, 04:24 PM   #1444
stein_325i
stein_325i's Avatar
25176
Drives: A Car
Well yes a track may be the "ultimate gauge", but the majority of owners will likely never or rarely take their cars to the track and will end up daily driving them, so I meant handling as to how it is on backroads, and general road driving. Handling is a more general term, when most people discuss a car's handling, it isn't referring to how it does on track. the 1 and 2-series (non-M's) are road cars first, track second.
      02-12-2020, 04:32 PM   #1445
The HACK
The HACK's Avatar
1821
Well yes a track may be the "ultimate gauge", but the majority of owners will likely never or rarely take their cars to the track and will end up daily driving them, so I meant handling as to how it is on backroads, and general road driving. Handling is a more general term, the 1 and 2-series (non-M's) are road cars first, track second.
That's GARBAGE. Only people who have zero clue as to what "handling" means would say that.
A car that handles well on the street should handle the track well, and vice versa. A car that can't "handle" track duties will drive like sh*t on the street, period. There's no magical car that handles great on the street, but can't handle a turn at speed on track.
This is the most asinine thing I've ever heard on here. Different standards for street and track handling? People who don't take their car on the track therefore HANDLING doesn't matter to them because it's only used for the streets?
Might as well all buy and drive Priuses.
Red Bread4465.00
SYT_Shadow11517.00
      02-12-2020, 04:42 PM   #1446
Fitz335
Fitz335's Avatar
26
Drives: 2021 Hockenheim Silver M2C
2007 335i  [10.00]
I hope the Supra is a better car, it is 5k more.
But for 3500 I can put an LSD and Tune on the M240i, have a back seat, sunroof, manual, and have a better car.
If I wanted a pure track car I'd just buy a M2C.
2011 X1
2018 M240i Estoril Blue
2007 335i Jet Black
1992 Eagle Talon TSi
      02-12-2020, 05:00 PM   #1447
stein_325i
stein_325i's Avatar
25176
Drives: A Car
You completely misinterpreted everything I said.
Nowhere did I compare street vs track driving, or say that a car that handles well on street doesn't handle well on track or vice versa, and no where did I say there are different standards for track vs street driving, or that people don't track their cars don't care about a car's handling.
All I said was that yes I agree with you that the track is an ultimate gauge of handling, however I also stated that most owners of cars like the 1,2, or 3-series don't take their cars to track or are buying them primarily for track, nor are these cars built with the track in mind as a priority. Now, that doesn't mean they won't handle well on track, because it still can, I'm just saying most people are not taking them to the track. Most want to have a car that handles well in general driving, thus they judge handling as to how well it drives in general circumstances whether that be on a curvy backroad or highway/general driving.
Handling is used as a general term to how a car feels when driving, when people describe a cars handling they may or may not be referring specifically to track driving. For example, I test drove the M340i and thought that the handling was decent after driving it on some curvy backroads. I did not drive it on a track yet I was able to assess the handling after driving it. Like I said, "handling" is pretty general of a term and can describe a wide variety of things. It can be used whether it be street, track, or both, etc. I advise you read my post clearly because no where does it say what you implicated.
      02-13-2020, 07:49 AM   #1448
FuriouslyFast
Drives: Miss Daisy
Yea & I can make my Hellcat even faster with $3500 too. You are not getting the point
      02-13-2020, 10:44 AM   #1449
Red Bread
Looks like they're announcing a new version today, likely a 4 banger and possibly an available manual.
      02-13-2020, 11:08 AM   #1450
FuriouslyFast
Drives: Miss Daisy
They better announce much better pricing too. It's not a $50k car
      02-13-2020, 12:10 PM   #1451
Red Bread
They netter announce much better pricing too. It's not a $50k car
I don't think they're going to take 50% of the cylinders out and then charge more.
      02-13-2020, 12:18 PM   #1452
Moflow
Moflow's Avatar
Drives: 2020 M2C 6MT
This just in: Toyota, not the same company as Porsche.
Appreciate 4
Conissah1576.00
Red Bread4465.00
stein_325i25176.00
Humdizzle6139.50
