      01-28-2021, 06:39 AM   #133
MrTookies
MrTookies's Avatar
Drives: 2011 E90 328i, 2015 F15 35D
Originally Posted by mrrsharma@yahoo.com View Post
How did you block of this line?? This is the only place I'm stuck on right now....
Also for the exhaust manifold blank plate did you reuse the bmw steel gasket?
You can either buy another price of hose and connect it to the cooling tree or take it all the way back to the middle port of the changeover valve, remove the temp sensor and cap it at the valve and at the cooling tree.
Yes you can reuse the metal gasket in most cases.
      01-31-2021, 03:20 PM   #134
Googone20
Googone20's Avatar
189
Drives: 2015 X5, 2007 M6
I removed it all the way back and just used the OEM caps on the coolant manifold.
2015 BMW X5 35d Msport Carbon Black/Mocha Nappa
2013 Cadillac Escalade Platinum Diamond White Pearl/Cocoa
2007 BMW M6 Sapphire Black Metallic/Black
2005 Ninja 636 Lime Green
      01-31-2021, 03:22 PM   #135
Googone20
Googone20's Avatar
189
Originally Posted by Khedge View Post
Hello,
I have 2018 x5d that i deleted myself. For hybrid turbo look up darkside developments. They are in the UK. I have 2 of the 2873 turbos. I running one on my x5. Still working out the tune but my x5 is running great.
I also have my stock turbo off my x5d too. It has about 15k miles on it.
V/r
Karl
How much power are you making on the Hybrid turbo? I have everything done to mine minus upgrading the turbo, so that may be the next step. I have now been deleted for 15k miles.
      02-02-2021, 02:33 PM   #136
quandary
Drives: X5
Do you have the same high pitched sound at idle as the other video above your post? If not, what is different in yours?
Originally Posted by NPDNELSON View Post
Got it done a few days ago! Love the sound and MO POWA BABEH!
      02-02-2021, 07:40 PM   #137
quandary
Drives: X5
I am starting to purchase the pieces to get this done and would like to get a DOC CAT to reduce the diesel smell and maybe dampen the high pitched idle whine. I'm not familiar with exhaust so I apologize if this is dumb question.
1) Can the existing DOC CAT be used? Is there a modification required e.g. welding any unused holes closed?
2) If the existing one can't be reused, can any DOC CAT be used? There is a big range in price.
3) Is there a recommendation for the DOC CAT?
4) Is there an residual resale value for the pieces that are going to be removed?
5) Can you confirm this is the list of things I need to purchase:
a. Downpipe $350 USD on the Ebay link
b. DOC CAT (assuming I have to buy one) $130 CDN on Amazon with title "4" Inlet/Outlet Universal Fit Catalytic Converter For Truck Diesel High Flow Cat Stainless Steel".
c. EGR Blanking Kit. $100 CDN on Ebay.
d. ECU Tune. $1100 USD from Malone Tuning according to this thread. Can't this simply be done through ISTA-D?
      02-05-2021, 08:45 AM   #138
quandary
Drives: X5
I spoke to the ebay person and he also has a 200 cel CAT that can come with the unit. I have read that CAT for diesel is different. What questions should i ask him to make sure it works with my X5 35d?
      02-07-2021, 12:23 AM   #139
KnudsonM3
MAGA
49
Drives: 99 M3, F15, F80, Ram 3500
If its the same DP as the other just with a cat I would ask him if he's made one before and if he has any pictures.
Personally, I would like to know how much
      02-07-2021, 03:04 PM   #140
quandary
Drives: X5
He says it is a universal 200 CEL high flow CAT for both petrol and diesel. However, I have been reading that the diesel oxidation cat is different inside, so I am inclined to buy just the downpipe and a separate DOC to clamp on. (I'm not sure i trust the statement that the CAT is universal between the diesel and petrol exhasut.) Buying it as pieces will also help if the fit isn't exact since I can use regular pipe and couplings to make it fit. I really don't want to have the smell.
If anyone can recommend a DOC, I would appreciate it. I see many options from Magnaflow but none for the X5; I assume that any will do as long as the pipes are compatible sizes. (Please respond if it is not true.) The downstream pipe will be the OEM size of 2.75 inches.
      02-07-2021, 10:33 PM   #141
quandary
Drives: X5
Sorry for all of the questions but I am learning lots through this forum. The instructional video in this first page is very good. Can someone validate the solution for what I am trying to accomplish:
1) Reduce risk of expensive maintenance caused by clogged intakes.
2) Increased torque.
3) No diesel smell.
Based on what I have read, I can accomplish this using:
a) EGR delete which can be done through coding (which then means I only have to deal with the normal exhaust.
b) oil bypass filter to clean soot that might come back from DPF.
c) ECU tune for more torque.
The removal of the DPF & SCR seems to be time intensive and redundant if one was to add a DOC Catalytic to deal with the smell. (I would argue that the DOC Cat might add the same risk due to clogs and forced regeneration.) DPF & SCR accomplish the same thing, except perhaps a pain filling DEF and ensuring DPF regeneration. Isn't this correct?
So, then the approximate cost of the solution is $500 for the oil bypass kit and a $850 for the tune. The reduced complications and substantially less time seem like the better option.
      02-09-2021, 02:41 PM   #142
Khedge
Drives: 2011 BMW 335d
No sure on power because I have not dyno’d it. The turbo will support 430 but its about the tunning which i am still working on. My actuator is doing some weird stuff from the logging i have been doing.
V/r
Karl
      03-02-2021, 03:20 AM   #143
2011diesel
Drives: 2011 X5 35d
Anyone have their stock DPF/SCR for the F15 x5 that you want to part ways? Looking to return my x5 back to stock and don’t have stock parts.
      03-03-2021, 02:00 AM   #144
x5wntd
Drives: f15 35d
Does anybody know a man /company in LA/OC (CA) which can help me with that? Have a '15 35d and wanna get rid of it. Thanks
      03-03-2021, 03:11 PM   #145
RED_Y_
Drives: 2014 X5 3.5d 2025 X5 40i
You won't be able to pass California smog check if you go this route, you know that, right?
https://www.e90post.com/forums/showthread.php?t=1620218
https://www.e90post.com/forums/showthread.php?t=1508500
https://www.bimmerfest.com/threads/i...r-cal.1278304/
Unless your car is registered in the county which doesn't need smog (my case but I don't plan to drive this car forever so it will be a pain to sell one day) or if you country doesn't require diesel to be smogged (not sure if there are any in Cali). Or if you have "good friends" who would risk their license to get you a pass. Or if you car registered out of state.
x5wntd58.50
      03-03-2021, 06:31 PM   #146
WVUBMWX5
Drives: BMW F15
Originally Posted by 2011diesel View Post
Anyone have their stock DPF/SCR for the F15 x5 that you want to part ways? Looking to return my x5 back to stock and don't have stock parts.
Hi, just curious why you are wanting to return yours back to stock?
      03-24-2021, 02:33 AM   #147
x5wntd
Drives: f15 35d
Anyone can refer a shop/mechanic who can help me with the ABC on my x5 35d ? CA and near states
      03-26-2021, 03:32 AM   #148
x5wntd
Drives: f15 35d
Folks help wanted still
      03-30-2021, 07:12 PM   #149
KnudsonM3
MAGA
49
Washington State has places that can take care of you.
      04-05-2021, 12:25 PM   #150
ManImCool
17
Drives: F15 X5
For people that have deleted, what changes, if any, does this make to oil changes?
Still the same 3-ish recommended brands of diesel oil? Any changes to the miles interval between changes? Any changes to the oil weight?
I've been deleted for about two years now and in that time the dealership has been doing my oil changes ( so I never gave this any thought), but the next one is going to be on my dime.
      04-09-2021, 08:30 AM   #151
x5wntd
Drives: f15 35d
If anyone has available for sale a delete kit for the N57, please let me know
      05-08-2021, 11:28 AM   #152
quandary
Drives: X5
I got my local mechanic to do the work. He said he does this alot but recommended hollowing out the scr, def and letting the coding disable the EGR. His rationale was that I will likely drive the X5 until it is dead and there's not alot of resellers North of Toronto for the parts. $600 cad. He also said the mufflers can stay in place to remove the whine because they are not so restrictive that soot will build up. This will also fool emissions testing since everything looks the same and they would only check for check engine lights if it can't back.
I opted for the dudmd stage 2 tune which was fast and the service is responsive. The application asked for cycling the engine during the remote setup but Dmitriy didn't tell me to. He just paused a few minutes and kept going. The power is better than my tuning box and the torque meter goes up to 560 now.
I'll keep you posted every once in a while as I get more mileage on my tune.
      05-18-2021, 12:19 AM   #153
x5wntd
Drives: f15 35d
Any thoughts? What should I do with those pipes ?
      05-18-2021, 05:52 AM   #154
Googone20
Googone20's Avatar
189
Those can both be eliminated and capped off with factory caps. I just removed everything like that back to the original source, which is that main diverter. This diverter is where coolant splits 4-5 different directions. The caps for these are OEM block off caps, which snap over the open holes after the lines are removed. If I remember correctly you use three different sizes of caps, but 4 total block off caps to complete the job. Two of one size, and one of each of the other two.
