      03-06-2020, 07:35 AM   #881
Chicane_S54
Chicane_S54's Avatar
37
Drives: F15 X5
Originally Posted by skoold2003 View Post
I guess I should throw my hat in the ring here. My '14 50i needs a new engine because of bottom end knocking...
What were you doing to that thing?
      03-06-2020, 07:42 AM   #882
Chicane_S54
37
Drives: F15 X5
Exclamation
Originally Posted by König Schultz View Post
You need to update this thread with what you're going to have to pay (seems like a steal) and also where we clearly all need to go when our engines shit the bed.
Although the 5.0 are more problematic, BMW engines (with few exceptions) are pretty solid, barring abuse. The inline 6 engines are more or less bullet proof as far as major engine issues. I have:
E24 with an M30 (absolutely buttetproof)
E46 M3 best car that I have ever owned with best engine ever (some douchbags abused the car early in production requiring rod bearing recall and TWS oil switch)
E90 328i, one of the best cars I have ever owned.
And of course the F15 3.5 which, knock on wood, has been the most useful car I have ever owned although I do not like the increased dependency of computerized systems, and some of the early fails are concerning.
I also have had an E36 M3 which was a sold car engine wise as well as many others.
      03-14-2020, 09:37 PM   #883
fengyunjiyue
Drives: 2016 BMW X5 x35i
Bought a pre-owned 2016 X5 x35i with 38k kms recently.
Mechanical fitness assessment shows everything ok dated on Jan 6, but shortly after the engine was replaced. What the difference between short engine and exchange short engine?
Had the car inspected by an independent shop; found a couple of issues such as engine oil leaking and differential oil leaking; had the issues checked and repaired.
Found a oil stain after picking up the car home, verified as transmission oil leaking from transmission cooler orings and got repaired.
Warranty will be expired soon. Should I buy extended warranty? [IMG][/IMG]
      03-15-2020, 12:02 AM   #884
skoold2003
skoold2003's Avatar
2014 X5 50i  [7.50]
Another one bites the dust! I'm looking at it like why buy an extended warranty when the biggest ticket items are brand new now anyway.. and I was told my new motor comes with a two year warranty. I believe that exchange = remanufactured.
      03-15-2020, 03:00 AM   #885
skoold2003
skoold2003's Avatar
2014 X5 50i  [7.50]
I just had to replace the front control arms on my '15 X5 after suddenly getting some serious rattling. The techs said this was due to a lack of lubrication on the parts (which obviously come lubricated and sealed from the factory). Unfortunately it was just out of factory warranty with a little over 4 years. Still not something I was expecting at the 45k mile mark. Contacted BMW NA for service credit but was refused.
So now mine needs a thrust arm bushing (which I believe is the same thing) as well. This thing is becoming a pain in my ass!
      03-15-2020, 08:16 AM   #886
fengyunjiyue
Thanks. I was told there is one year warranty for the new engine.
My Volvo XC70 is 16 years old now and there is no major issues. This 2016 BMW is only 38k kms, and it should not have so many problems; engine failure, output shaft seal leaking, transmission cooler O-ring leaking. But on the other hand, the engine is new with one year warranty and all issues were fixed. Probably I will not proceed with an extended warranty.
      03-15-2020, 08:29 AM   #887
classic_erik
classic_erik's Avatar
Drives: 23' X7 40i M Sport
Anyone experience issues with their exterior door handles where it feels like there is no click or action when you open the door? Almost as if you could just pull the door open. This is more prevalent on the drivers side front door compared to the others most likely due to high use. Note I do not have soft close doors.
      03-15-2020, 12:32 PM   #888
skoold2003
skoold2003's Avatar
2014 X5 50i  [7.50]
Don't get me wrong there are still plenty of things that can go wrong (knock on wood) and make an extended warranty worth it. It just seems less likely after so much has been done already.
      03-15-2020, 05:34 PM   #889
KRS_SN
KRS_SN's Avatar
United Kingdom
13536
Drives: IX,G07
2020 X7  [10.00]
X5  [8.50]
IX  [8.00]
extended warranties on f15 are very pricey (about 1.5k per year). in my opinion far too expensive to justify having them.
      03-15-2020, 10:11 PM   #890
gvarr03
Drives: MY'15 X5 xDrive35d
Leaking shaft pinion seal on the rear differential...
      03-15-2020, 11:18 PM   #891
fengyunjiyue
Seems a common issue. My car is only 38k kms; both output shaft seal leaks.
      03-17-2020, 10:34 PM   #892
BMWofVS
BMWofVS's Avatar
471
Drives: BMW X5
First bimmer
Just picked up a 2017 X5. Not sure if this is a issue or not or some sort of setting. On the pic is the rectangular box on the speedometer normal or some sort of bulb, wiring, or malfunction?
      03-17-2020, 10:43 PM   #893
KingBiscuit
KingBiscuit
Drives: '15 BMW X5x35i/'14 Lexus EX350
I will see mine slightly every now and then. That looks a little too pronounced. Maybe try dimming your dash lights but you wouldn't think you should be having that problem. Still under warranty?
2014 X5 xDrive 35i
      03-17-2020, 10:50 PM   #894
BMWofVS
BMWofVS's Avatar
471
Drives: BMW X5
Yup still under warranty. Ok so that is not normal good to know. Thanks.
      03-17-2020, 10:53 PM   #895
KingBiscuit
KingBiscuit
if it's still under warranty i'd go over it with a fine toothed comb. Might even had an independent guy hook up a really computer to it... not just something at a parts place and make sure you know ALL the codes it's thrown.
2014 X5 xDrive 35i
      03-18-2020, 09:36 AM   #896
BMWofVS
BMWofVS's Avatar
471
Drives: BMW X5
So the bmw dealer I bought it from is telling me that is normal and my X5 does not come with the extended information cluster which is why it has the rectangular outline. Does that make sense? Is that true?
      03-18-2020, 10:05 AM   #897
markslc1
Drives: 2011 1M, 14 X5 x35i
Normal.
      03-18-2020, 10:17 AM   #898
gvarr03
On my X5 it is exactly the same.
      03-18-2020, 11:26 AM   #899
BMWofVS
BMWofVS's Avatar
471
Drives: BMW X5
Originally Posted by markslc1 View Post
Normal.
      03-20-2020, 12:54 PM   #900
XxBBVTMxX
XxBBVTMxX's Avatar
To make story short, soon after I passed 50k warranty, my rear right door started acting up and opening the latch while driving.
I took it to BMW and they wanted to charge me just up of $1600 to replace the door handle and the latch. I told the representative that they were not going to charge me simply because I was over warranty for a few miles for something that is a safety issue.
To go ahead, put it back together, and when a passenger falls out, I'll just get a lawyer. The representative said to please give him 5 minutes that he will call me back. He called back in about 3 minutes and said they will cover it for free and they would need about 48hrs to get the parts and knock it out.
Yeah, not paying for something that's a safety issue guys 🤣.
Other issue I had was that while cleaning the engine bay I noticed the PVC hose (small section) was cracked in the back. Apparently it's a common problem. I put in an oil catch can now so no issues 😎.
KRS_SN13535.50
A-4WD215.00
      03-20-2020, 02:21 PM   #901
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
Good for you👍
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      03-30-2020, 07:22 AM   #902
Chicane_S54
37
Drives: F15 X5
THIS ^^^.
Better to sock that money away in an ETF and then use it if you need it.
