03-20-2016, 01:25 AM | #2201 |
Rep 56
03-20-2016, 03:22 AM | #2202 |
Rep 48
Drives: BMW X5(G05) 2019
I was successful Traffic jam assist in the retrofit by the calibration.
It is very favorite feature. Thanks for all. Last edited by Hideada; 03-20-2016 at 06:04 AM.. |
03-20-2016, 07:37 PM | #2204 |
Rep 40,775
03-23-2016, 12:38 PM | #2205 |
Member
7
Rep 32
Drives: 2014 X5 M-Sport
Trying to code f15
Hi everyone,
Is it possible to get the latest esys download file, PSdZData and token generator for esys? Also, I had the car coded before, any coding that I will do to it now, will it get wiped ? Trying to get the turn signals not to check for burnt bulbs because I have custom led turn signals. Thank you so much. |
03-23-2016, 02:37 PM | #2206 |
Rep 1,181
@shawnsheridan will PM you with software info.
To answer your question, no previous coding will get erased unless you VO-code the car, which you're not doing. You're only FDL-coding for the LED bulb error check.
03-23-2016, 02:38 PM | #2207 | |
Member
7
Rep 32
03-23-2016, 04:13 PM | #2208 | |
Rep 40,775
Now.
03-23-2016, 04:25 PM | #2209 |
Member
7
Rep 32
Thank you ! Will let you know how it works out!
03-23-2016, 08:05 PM | #2211 |
Rep 196
Also if anyone knows of someone whether its a shop or an individual that can do coding in Orange County please let me know. I just got my x5 back from the dealer and all my coding has been erased. I have the cable I bought from Ben but honestly I'm scared to try it on my own for fear of messing something up!
03-23-2016, 08:24 PM | #2212 |
Rep 40,775
PM sent.
03-23-2016, 09:12 PM | #2213 | |
Rep 592
If money is not an issue, drive up to Northern California and I'll hook you up! I only charge 1 bottle of IPA beer per module. Lol. |
03-23-2016, 09:42 PM | #2214 | |
Rep 196
03-23-2016, 09:48 PM | #2215 |
Rep 592
: you'll be fine bro, you'll see. I'm about to restore my FA to factory since Im having my MPPK installed first thing Saturday morning. Got a great deal from an Orange County dealer.
03-23-2016, 11:40 PM | #2216 |
Rep 196
So I tried it and all I could get to work was closing the tailgate via the fob and door button.
The usb video plays but I get the warning once the car is in motion. I couldn't find most of the modules on the cheat sheet, like even the names are missing. I don't have the following modules: HU_NBT 3000 I don't have API_USB_VIDEO and it also wouldn't let me change the werte for the Speedlock min/max to FF. KAFAS2 PMA3 ICAM I can't access BDC_BODY at all. Is this because maybe they just installed new software today and things have changed? Below are some of the errors I received. Any help is greatly appreciated! Thanks in advance! Transaktions-Report: Aktion: Codierdaten lesen CAFD_000017BE_042_100_009 Fehler: CPS read from ECU "ECUId:BDC_BODY_0x40" failed! [C070] openECUConnection for link BDC_BODY_40_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name BDC_BODY_40_ETHERNET doesn't map to an item [1694] Transaktions-Report: Aktion: Codierdaten lesen CAFD_000013D8_003_003_001 Fehler: CPS read from ECU "ECUId:ICM_0x1C" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: ICM_1C_ETHERNET severity: ERROR [2130765072] Transaktions-Report: Aktion: Codierdaten lesen CAFD_00000069_010_002_012 Fehler: CPS read from ECU "ECUId:KOMBI_0x60" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: KOMBI_60_ETHERNET severity: ERROR [2130765072] |
03-23-2016, 11:49 PM | #2218 | |
Rep 592
What version of Esys do u have?
03-24-2016, 12:09 AM | #2222 |
Rep 592
