10-15-2020, 09:31 AM | #1 |
Rep 1,859
Drives: 23' X7 40i M Sport
Black and White Wheel Center Caps
Has anyone found these for our 72.6mm sized center caps? Everything out there I can find is in a 68mm.
10-15-2020, 06:02 PM | #2 |
Rep 191
Drives: BMW X5
How about some IND carbon floating wheel center caps
https://ind-distribution.com/product...cap-set-72-6mm |
10-15-2020, 07:16 PM | #3 |
Rep 2,511
Emmm, wheels with 72.6 hub bore (older bimmers with 5x120 bolt pattern) have 65mm center caps.
BMW P/N 36122455269 https://www.realoem.com/bmw/enUS/partxref?q=36122455269 https://www.amazon.com/BMW-361224552.../dp/B07T3GTYF6 |
10-15-2020, 08:10 PM | #4 | |
Rep 1,859
https://ind-distribution.com/collect...ed-center-caps
10-16-2020, 10:44 PM | #5 |
Rep 2,511
I sort of trust real OEM more than IND, but I guess they refer to the hub bore size, it is not the same size as center cap bore. I might be wrong though. May be give them a call and ask?
10-17-2020, 12:08 AM | #6 |
Rep 1,179
I have a set of black carbon fiber ones that were on my wheels. I ended up swapping them out for floating ones. If you're ok with carbon fiber ones I can either sell you mine or try and remember where I got them.
10-17-2020, 12:47 AM | #7 |
Rep 1,260
OEM Center caps come in 2 sizes. 56mm (old wheels with PCD 5x112mm) and 65mm (PCD 5x120mm). The OEM F15 wheels are 5x120mm, so you need 65mm Center Caps.
And BTW, center bore is 74.1mm. Last edited by CatalinP; 10-17-2020 at 12:53 AM.. |
10-29-2020, 09:43 PM | #8 |
Rep 1,859
IND saves the day with a custom order, again.
Craftsmanship and painting is beautiful.
10-29-2020, 11:39 PM | #10 |
1636
Rep 2,995
10-30-2020, 08:08 AM | #12 |
Rep 942
Drives: 2016 BMW X5
10-30-2020, 07:15 PM | #13 | |
Rep 1,859
$275
10-30-2020, 08:45 PM | #15 |
Rep 1,859
Well yes, it is crazy. That said I won't put that cheap stick-on Chinese bullsh*t on my car.
