01-06-2019, 02:27 PM | #45 |
134
Rep 395
I tried to code the below in expert mode via Bimmercode on our 2018 X5 and for some reason don't have expert mode in ICMQL module to be able to go in and adjust this.
Also - I was not able to code the number of turn signal blinks either, as I could not find the command that was listed in the cheat sheat on Bimmercode. Thanks for the help! |
01-08-2019, 04:14 AM | #46 | |
Rep 8,364
01-08-2019, 06:24 AM | #47 |
134
Rep 395
Thanks for the feedback. When I went in expert mode for turnsignal, I did not see the command name that was in the cheat, unless I just missed it.
Also - are you not able to code Blind Spot speed through Bimmercode? For some reason it did not have expert mode in that module. Thanks! |
01-08-2019, 11:07 PM | #48 | |
Rep 8,364
There are two. Did you search PIA_DEFAULT_TIP? Last edited by Almaretto; 01-08-2019 at 11:16 PM.. |
01-11-2019, 03:47 PM | #49 | ||||
Rep 258
01-11-2019, 08:58 PM | #50 |
OEM CSL Whore
1250
Rep 1,476
It took me a few weeks to realize I had to push the side of the stalk to activate wiper intervals. Initially I thought my my interval knob was broken 🤣
01-12-2019, 01:19 AM | #52 |
Rep 8,364
01-12-2019, 02:49 AM | #53 | |
Rep 258
01-12-2019, 06:55 AM | #54 |
Rep 8,364
01-12-2019, 10:59 AM | #55 |
Rep 258
I'm trying to get the option to show up on the dash as well.
01-12-2019, 11:53 AM | #56 |
Rep 96
I used Carly exclusively on my X1, but I use Bimmercode to code my X5. Since I'm a DIYer (and there's no free BMW maintenance in Europe) I've kept the Carly and use it on the X5 to reset the maintenance warnings, which I do not believe Bimmercode can do.
I'll be using Esys this weekend to see if I can turn off the "easy exit" adjustment of the steering column. I just want it to move from my profile setting to my wife's, depending on who's driving.
2018 X5 xDrive35i M-Sport - Traded
2013 X1 xDrive35i - Sold 1986 320i - Sold |
03-01-2019, 03:14 AM | #58 |
Rep 2
Hi! I have X5 M50D with Black Cluster. Can't figure out how to set M50D logo. There is no cluster logo option in Bimmercode. I've tried it with advanced setting, but don't understand what to set. There are a lot of options:
X5 X5_med X5_high |
10-17-2020, 02:02 PM | #59 |
Rep 7,480
I was just able to code my 2014 X5 to five blinks using Bimmercode expert mode . I was coding the BDC module...go to: 3068 > BLINKZYKLEN_ANZAHL_TIPP ...then change CUSTOM VALUE to 0x04
10-17-2020, 03:43 PM | #60 |
232
Rep 337
You have older I level, so that function worked for you, and I liked it better as it was possible to choose 3,4 or 5 blinkers. With newer I level software the function is different PIA_DEFAULT_TIPPBLINKEN and you are limited to 1, 3 or 5 blinkers
10-17-2020, 06:21 PM | #61 | |
Rep 7,480
Do you know if the older CIC can be coded? I tried to change my 2013 650iX GC...but it wouldn’t take. It has the FRM (footwell module) and I can find the line of coding in the FRM Module under 3060—> BLINKZYKLEN_ANZAHL_TIPP ...and can change the code line like I did on the X5...but it still blinks only 3 times. I wonder if there’s another line of coding that is required for the FRM module?
10-17-2020, 06:30 PM | #62 | |
232
Rep 337
10-17-2020, 06:57 PM | #63 | |
Rep 7,480
The 2011-12 f12/f12 & 2013 f06/f11/f13 came with the last iteration of the CIC iDrive...the f chassis 6 series got the NBT/ID4 version of iDrive starting with the 2014 model year (in the US market).
10-17-2020, 08:01 PM | #65 |
Rep 19
After a dealer visit to install my mppk, I lost my coded ambient light, 5 blinkers.
I was able to recover my ambient lights with more options in color but my 5 blinkers are gone, can not find them 2016 x5 f15 |
10-23-2020, 01:54 AM | #66 |
Rep 8,364
Parameter changed for blinkers after 2018 firmware.
